Salta al contenuto principale
Pentax Super Program Front Block Removal
Cosa ti serve
  1. Pentax Super Program Front Block Removal, Remove film advance lever: passo 1, immagine 1 di 3 Pentax Super Program Front Block Removal, Remove film advance lever: passo 1, immagine 2 di 3 Pentax Super Program Front Block Removal, Remove film advance lever: passo 1, immagine 3 di 3
    • Remove the rubber decorative cap. It is attached with contact cement underneath. Isopropyl Alcohol may be used to soften the adhesive.
    • Unscrew the lock nut using a spanner wrench. The lock nut is reverse threaded.
    • Lift off the advance lever.
    • Remove the spring washer.
    • Remove one shim washer.
    Chiedi a FixBot
    Aggiungi Commento
  2. Pentax Super Program Front Block Removal, Remove mode dial: passo 2, immagine 1 di 2 Pentax Super Program Front Block Removal, Remove mode dial: passo 2, immagine 2 di 2
    • Set the mode dial to the 'L' position.
    • Use a spanner wrench to unscrew the dial lock nut.
    • Lift off the mode dial.
    Chiedi a FixBot
    Aggiungi Commento
  3. Pentax Super Program Front Block Removal, Remove exposure compensation dial: passo 3, immagine 1 di 3 Pentax Super Program Front Block Removal, Remove exposure compensation dial: passo 3, immagine 2 di 3 Pentax Super Program Front Block Removal, Remove exposure compensation dial: passo 3, immagine 3 di 3
    • Place a rigid object in the fork.
    • Unscrew the rewind lever.
    • Use a spanner wrench to remove the lock nut.
    • Lift off the exposure compensation dial.
    Chiedi a FixBot
    Aggiungi Commento
  4. Pentax Super Program Front Block Removal, Remove top cover screws: passo 4, immagine 1 di 3 Pentax Super Program Front Block Removal, Remove top cover screws: passo 4, immagine 2 di 3 Pentax Super Program Front Block Removal, Remove top cover screws: passo 4, immagine 3 di 3
    • Remove two screws on either side of the eye piece.
    • Remove two screws on either side of the lens mount.
    Chiedi a FixBot
    Aggiungi Commento
  5. Pentax Super Program Front Block Removal, Remove top cover: passo 5, immagine 1 di 3 Pentax Super Program Front Block Removal, Remove top cover: passo 5, immagine 2 di 3 Pentax Super Program Front Block Removal, Remove top cover: passo 5, immagine 3 di 3
    • Remove one screw by the exposure compensation dial.
    • Use a spanner wrench to remove the lock nut under the advance lever.
    • Lift off the top cover slowly. It is still attached by one wire.
    • Unsolder one gray flash sync wire.
    Chiedi a FixBot
    Aggiungi Commento
  6. Pentax Super Program Front Block Removal, Remove bottom cover: passo 6, immagine 1 di 1
    • Remove three M1.7 x 3 mm screws.
    • Remove bottom cover.
    Chiedi a FixBot
    Aggiungi Commento
  7. Pentax Super Program Front Block Removal, Remove front leatherette panels: passo 7, immagine 1 di 3 Pentax Super Program Front Block Removal, Remove front leatherette panels: passo 7, immagine 2 di 3 Pentax Super Program Front Block Removal, Remove front leatherette panels: passo 7, immagine 3 di 3
    • Use a nickel or other large coin to remove the hand grip.
    • Drip isopropyl alcohol along the edge of the leatherette to soften the adhesive.
    • Use a dull scraper to lift one corner and pull off the panel.
    • Repeat on the rewind side of the camera.
    • Installation Notes: Use contact cement to reattach the leatherette after the camera has been fully reassembled and tested.
    Chiedi a FixBot
    Aggiungi Commento
  8. Pentax Super Program Front Block Removal, Detach flex PCB with adjustment pots: passo 8, immagine 1 di 2 Pentax Super Program Front Block Removal, Detach flex PCB with adjustment pots: passo 8, immagine 2 di 2
    • Remove one M1.7 x 4.5 mm screw.
    • Remove one slotted screw.
    • Use isopropyl alcohol to soften the adhesive under the flex PCB.
    • Gently lift the PCB until it is free from the camera body.
    Chiedi a FixBot
    Aggiungi Commento
  9. Pentax Super Program Front Block Removal, Unsolder motor drive connections: passo 9, immagine 1 di 2 Pentax Super Program Front Block Removal, Unsolder motor drive connections: passo 9, immagine 2 di 2
    • Unsolder red wire for positive battery.
    • Unsolder green wire.
    • Unsolder orange wire for motor drive shutter release.
    • Unsolder purple wire for wind completion switch.
    Chiedi a FixBot
    Aggiungi Commento
  10. Pentax Super Program Front Block Removal, Remove tripod mount: passo 10, immagine 1 di 2 Pentax Super Program Front Block Removal, Remove tripod mount: passo 10, immagine 2 di 2
    • Remove one M1.7 x 5 mm screw.
    • Remove one countersunk M1.7 x 5.5 mm screw.
    • Lift the contact terminal free from its seat.
    • Remove the tripod mount.
    Chiedi a FixBot
    Aggiungi Commento
  11. Pentax Super Program Front Block Removal, Detach ISO resistor assembly: passo 11, immagine 1 di 2 Pentax Super Program Front Block Removal, Detach ISO resistor assembly: passo 11, immagine 2 di 2
    • Remove one M1.7 x 4 mm screw.
    • Loosen one slotted screw (this will remain connected to the assembly).
    • Lift the ISO resistor assembly off the rewind post. It is still attached by a flex PCB.
    Chiedi a FixBot
    Aggiungi Commento
  12. Pentax Super Program Front Block Removal, Detach mode dial unit: passo 12, immagine 1 di 3 Pentax Super Program Front Block Removal, Detach mode dial unit: passo 12, immagine 2 di 3 Pentax Super Program Front Block Removal, Detach mode dial unit: passo 12, immagine 3 di 3
    • Remove one M1.7 x 2.5 mm screw. It is only accessible when the mode dial is in the 'L' position.
    • Lift the LCD out of the way. It is still attached by a flex PCB.
    • Remove one slotted post.
    Chiedi a FixBot
    Aggiungi Commento
  13. Pentax Super Program Front Block Removal, Unsolder flash sync wires: passo 13, immagine 1 di 1
    • Unsolder two gray wires.
    Chiedi a FixBot
    Aggiungi Commento
  14. Pentax Super Program Front Block Removal, Unsolder shutter wires: passo 14, immagine 1 di 2 Pentax Super Program Front Block Removal, Unsolder shutter wires: passo 14, immagine 2 di 2
    • Unsolder white wire.
    • Unsolder brown wire.
    • Unsolder red wire.
    Chiedi a FixBot
    Aggiungi Commento
  15. Pentax Super Program Front Block Removal, Unscrew mirror box: passo 15, immagine 1 di 2 Pentax Super Program Front Block Removal, Unscrew mirror box: passo 15, immagine 2 di 2
    • Remove two M1.7 x 2.5 mm screws.
    • Remove one M1.7 x 3.5 mm screw under the bottom plate.
    • Some versions of the camera may have an additional screw under the tripod mount that needs to be removed.
    Chiedi a FixBot
    Aggiungi Commento
  16. Pentax Super Program Front Block Removal, Unscrew front board: passo 16, immagine 1 di 2 Pentax Super Program Front Block Removal, Unscrew front board: passo 16, immagine 2 di 2
    • Wind the advance lever to put the shutter and mirror box in the charged state.
    • Remove four M1.9 x 5 mm screws.
    Chiedi a FixBot
    Aggiungi Commento
  17. Pentax Super Program Front Block Removal, Remove mirror box and front board: passo 17, immagine 1 di 1
    • Make sure the mode dial unit and ISO selector unit are free from their mounting points.
    • Wiggle the mirror box and front board free.
    • Watch for wire snags as you pull it free.
    • Check for loose shim washers on the front board and note their position.
    Chiedi a FixBot
    Aggiungi Commento
  18. Pentax Super Program Front Block Removal, Installation Notes: Front Block: passo 18, immagine 1 di 1
    • Shutter should be in the charged state.
    • Mirror box should be in released state.
    • Pay close attention to wire routing during install.
    • To test the actuation of the mirror and shutter, wind the camera, then insert a tool into this slot and push the release lever to the left.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Sam Gustafson
Membro da: 09/01/22
14.384 Reputazione
78 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 40
Tutti i Tempi: 365
