Salta al contenuto principale
Palm TX Battery Pack Replacement
Cosa ti serve
  1. Palm TX Battery Pack Replacement, Back Panel: passo 1, immagine 1 di 2 Palm TX Battery Pack Replacement, Back Panel: passo 1, immagine 2 di 2
    • Orient the device so that the display faces forward.
    • Remove the stylus from the right side.
    Chiedi a FixBot
    Aggiungi Commento
  2. Palm TX Battery Pack Replacement: passo 2, immagine 1 di 1
    • Turn over the device so that the back panel faces forward.
    • Use a T5 Torx screwdriver to remove the four 6.35mm corner screws.
    Chiedi a FixBot
    Aggiungi Commento
  3. Palm TX Battery Pack Replacement: passo 3, immagine 1 di 2 Palm TX Battery Pack Replacement: passo 3, immagine 2 di 2
    • Rotate the device so that the display faces forward.
    • Insert a plastic opening tool with the angled tip pointing downward into the crevice on the left side of the device.
    • Pry along the crevice to loosen the back panel.
    • Repeat this process for the right side.
    Chiedi a FixBot
    Aggiungi Commento
  4. Palm TX Battery Pack Replacement: passo 4, immagine 1 di 2 Palm TX Battery Pack Replacement: passo 4, immagine 2 di 2
    • Carefully pry the back panel to open the device.
    • Be careful not to break the wire that connects the battery pack to the motherboard.
    • When reassembling, snap the back panel back into place and then insert the top cover.
    Chiedi a FixBot
    Aggiungi Commento
  5. Palm TX Battery Pack Replacement: passo 5, immagine 1 di 2 Palm TX Battery Pack Replacement: passo 5, immagine 2 di 2
    • Use a plastic opening tool to peel the battery pack from the back panel.
    • The battery pack is glued to the back panel so removing it may require considerable effort.
    Chiedi a FixBot
    Aggiungi Commento
  6. Palm TX Battery Pack Replacement, Battery Pack: passo 6, immagine 1 di 2 Palm TX Battery Pack Replacement, Battery Pack: passo 6, immagine 2 di 2
    • Use a soldering iron to disconnect the battery wires from the motherboard.
    • For soldering instructions, you can view the Soldering Guide.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Cal Poly, Team 1-15, Amido Winter 2011 Membro di Cal Poly, Team 1-15, Amido Winter 2011
CPSU-AMIDO-W11S1G15
4 Membri
9 guide realizzate
1Commento della guida
In step 1 - Also remove the cover hinge by sliding downwards
In step 3 - there are actually 2 crevices on the left side of the device. Use the larger, which originally held the cover hinge (the smaller crevice seems to remove the facia)
Jack - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 14
Ultimi 30 giorni: 65
Tutti i Tempi: 8,521
