Salta al contenuto principale
Panoramica video
Questo smontaggio non è una guida di riparazione. Per riparare il tuo OnePlus 8 Pro, usa il nostro manuale di assistenza.
    Considerazioni finali
    • The battery can be removed first, once you open the phone. It’s only lightly adhered and comes with a pull tab for easy removal.
    • Many components are modular and can be individually replaced.
    • Display replacements, which are the most common repairs, are not prioritized in the design.
    • The primary access point for all repairs, the rear panel, is firmly glued in place.
    Punteggio di riparabilità
    4
    Riparabilità 4 su 10
    (10 è il più facile da riparare)
5Commenti sulla guida
No wallpaper? Please!
rafboricua - Rispondi Condividi
When I was disassembling OP8 Pro in order to replace my display, I did not pay attention there are screws with different sizes . If I use a wrong screw, it can damage new display. Can you help me ? Do you have correct screw sequence point each size?
Claudio Varizo - Rispondi Condividi
Long screws go to upper side (where motherboard and cameras places) and short screws are for bottom side. Two shortest screws hold the usb connector
geordead - Rispondi Condividi
I sure do miss the days when the teardowns/ came with pictures so that I can see the locations of screws and such in between steps. :\
Guess I'll go find something by someone else for help.
Kediil - Rispondi Condividi
Is the ub-c charging port replaceable and where can i get the part?
Timothy Tarr - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 8
Ultimi 7 giorni: 27
Ultimi 30 giorni: 120
Tutti i Tempi: 32,195
