Salta al contenuto principale
Nvidia Shield Tablet Motherboard Replacement
Cosa ti serve
    1. Nvidia Shield Tablet Motherboard Replacement, Rear Case: passo 1, immagine 1 di 2 Nvidia Shield Tablet Motherboard Replacement, Rear Case: passo 1, immagine 2 di 2
      • First, remove the stylus from your tablet.
      Chiedi a FixBot
      Aggiungi Commento
    2. Nvidia Shield Tablet Motherboard Replacement: passo 2, immagine 1 di 3 Nvidia Shield Tablet Motherboard Replacement: passo 2, immagine 2 di 3 Nvidia Shield Tablet Motherboard Replacement: passo 2, immagine 3 di 3
      Strumento utilizzato in questo passaggio:
      Anti-Static Wrist Strap
      $7.95
      • Set the tablet so the buttons, microSD, and stylus port are facing you.
      • Open the microSD slot.
      • Using the flat end of the spudger tool, carefully pry open the case starting from the microSD slot, slowly sliding the spudger along the inside edge of the case.
      • You may want to put on your anti-static wrist strap at this point as the motherboard will be vulnerable to physical touch and electrostatic shock after the casing is removed.
      Chiedi a FixBot
      Aggiungi Commento
    3. Nvidia Shield Tablet Motherboard Replacement: passo 3, immagine 1 di 2 Nvidia Shield Tablet Motherboard Replacement: passo 3, immagine 2 di 2
      • As you remove your case, be aware of small clips along the edges.
      • Finally, set the old casing aside.
      Chiedi a FixBot
      Aggiungi Commento
    1. Nvidia Shield Tablet Motherboard Replacement, Motherboard: passo 4, immagine 1 di 1
      $7.95
      • Carefully use the precision tweezers to unplug the ribbon cable.
      • Be sure to have your anti-static wrist strap on for this procedure.
      Chiedi a FixBot
      Aggiungi Commento
    2. Nvidia Shield Tablet Motherboard Replacement: passo 5, immagine 1 di 3 Nvidia Shield Tablet Motherboard Replacement: passo 5, immagine 2 di 3 Nvidia Shield Tablet Motherboard Replacement: passo 5, immagine 3 di 3
      • Remove the two 6.5 mm Phillips #00 screws and seven 3.0 mm Phillips #00 screws.
      Chiedi a FixBot
      Aggiungi Commento
    3. Nvidia Shield Tablet Motherboard Replacement: passo 6, immagine 1 di 3 Nvidia Shield Tablet Motherboard Replacement: passo 6, immagine 2 di 3 Nvidia Shield Tablet Motherboard Replacement: passo 6, immagine 3 di 3
      • Use a pair of tweezers to disconnect the three black antenna cables from the motherboard.
      • Use the flat end of the spudger tool to carefully pry up the motherboard.
      • In the first Shield, the stylus ribbon cable is located under the right side of board. While there are 2 additional cables for the cameras underneath the left end of the board. Be sure to loosen the cameras before lifting the board.
      Chiedi a FixBot
      Aggiungi Commento
    4. Nvidia Shield Tablet Motherboard Replacement: passo 7, immagine 1 di 2 Nvidia Shield Tablet Motherboard Replacement: passo 7, immagine 2 di 2
      • Desolder the positive and negative battery cables from the motherboard.
      • Make sure to note which wire goes where, you don't want to re-solder the wires backwards!
      • The motherboard should now come free.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 6 persone hanno completato questa guida.
Molly Bauer
Membro da: 08/27/15
1.478 Reputazione
6 guide realizzate
USF Tampa, Team 2-2, Blackwell Fall 2015 Membro di USF Tampa, Team 2-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G2
3 Membri
11 guide realizzate
9Commenti sulla guida
Where do you obtain a new motherboard?
imprintcave - Rispondi Condividi
The real question is more about how to find a new shield tablet motherboard ??
willixlive - Rispondi Condividi
where can i buy the motherboard
Gurjot Dhaliwal - Rispondi Condividi
waar kan ik een nieuw shield moederbord kopen?
tom1vangestel - Rispondi Condividi
Hello, I'm looking for a description of the various ribbon connectors on the motherboard.
I'm also looking for a hint to solve a problem I have after replacing the screen+digitizer: the right side (half) of the touch screen does'n work.
Laurent Zanoni - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 14
Ultimi 30 giorni: 67
Tutti i Tempi: 10,346
