Salta al contenuto principale
Numark N4 USB Port Replacement
Cosa ti serve
    1. Numark N4 USB Port Replacement, Numark N4 Disassembly: passo 1, immagine 1 di 1
      • Turn the Numark N4 over so that the bottom panel is facing upwards.
      • Loosen and remove the 17 12mm screws from the bottom panel using a Phillips #2 screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    2. Numark N4 USB Port Replacement: passo 2, immagine 1 di 1
      • Using your fingers, gently pull apart the two panels of the device until you feel resistance from the cables.
      Chiedi a FixBot
      Aggiungi Commento
    3. Numark N4 USB Port Replacement: passo 3, immagine 1 di 1
      • Using your fingers, gently unplug the larger ribbon cable as pictured.
      Chiedi a FixBot
      Aggiungi Commento
    4. Numark N4 USB Port Replacement: passo 4, immagine 1 di 1
      • Using your fingers, gently unplug the smaller ribbon cable as pictured.
      Chiedi a FixBot
      Aggiungi Commento
    5. Numark N4 USB Port Replacement: passo 5, immagine 1 di 1
      • Using your fingers, gently unplug the yellow and red cable as pictured.
      Chiedi a FixBot
      Aggiungi Commento
    6. Numark N4 USB Port Replacement: passo 6, immagine 1 di 1
      • Open the two panels completely, gently placing each side on your working area to avoid damage to the buttons on the outside face.
      Chiedi a FixBot
      Aggiungi Commento
    1. Numark N4 USB Port Replacement, USB Port: passo 7, immagine 1 di 1
      • Loosen and remove the five 12mm screws from the circuit board using a Phillips #2 screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    2. Numark N4 USB Port Replacement: passo 8, immagine 1 di 1
      • Carefully remove the circuit board from its housing.
      Chiedi a FixBot
      Aggiungi Commento
    3. Numark N4 USB Port Replacement: passo 9, immagine 1 di 1
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
USF Tampa, Team S13-G11, Cagle Fall 2017 Membro di USF Tampa, Team S13-G11, Cagle Fall 2017
USFT-CAGLE-F17S13G11
4 Membri
24 guide realizzate
1Commento della guida
i we like to get the new board of dis numark n4
daniel benson - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 10
Ultimi 30 giorni: 47
Tutti i Tempi: 3,079
