Salta al contenuto principale
Nook BNRV300 Power Button Replacement
Cosa ti serve
    1. Nook BNRV300 Power Button Replacement, Power Button: passo 1, immagine 1 di 3 Nook BNRV300 Power Button Replacement, Power Button: passo 1, immagine 2 di 3 Nook BNRV300 Power Button Replacement, Power Button: passo 1, immagine 3 di 3
      • Power off your Nook before working on your device. Hold the power button for about 5 seconds and select the “Power Off” option.
      • Turn the Nook over to find the power button along the back upper edge.
      • Wedge the spudger between the top of the power button and the upper edge of the device.
      • Push the tool down to pry the button up and off.
      Chiedi a FixBot
      Aggiungi Commento
    2. Nook BNRV300 Power Button Replacement: passo 2, immagine 1 di 1
      • Using your fingers, take off the power button.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
2Commenti sulla guida
My power button is not responding. Presumably I have to let the power drain because it won't shut off. Do i replace the button or the sensor beneath it?
Lydia Rice - Rispondi Condividi
Check the comments on each step. There are some adjustments to the process to properly and safely take this apart.
dl200010 - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 8
Ultimi 30 giorni: 28
Tutti i Tempi: 1,420
