Salta al contenuto principale
Nokia 6085h Front LCD Display
Cosa ti serve
  1. Nokia 6085h Front LCD Display, Battery: passo 1, immagine 1 di 1
    • Flip over the phone so that the back is facing up.
    • Pressing your thumb against the back cover, slide the cover off of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  2. Nokia 6085h Front LCD Display: passo 2, immagine 1 di 1
    • Remove the phone's battery.
    Chiedi a FixBot
    Aggiungi Commento
  3. Nokia 6085h Front LCD Display, Front LCD Display: passo 3, immagine 1 di 3 Nokia 6085h Front LCD Display, Front LCD Display: passo 3, immagine 2 di 3 Nokia 6085h Front LCD Display, Front LCD Display: passo 3, immagine 3 di 3
    • With the phone closed, run a plastic opening tool along the seam of the top half of the phone.
    • Make sure to disconnect each of the five clips before proceeding to the next step.
    • There are two clips on each side of the phone and one on the top.
    Chiedi a FixBot
    Aggiungi Commento
  4. Nokia 6085h Front LCD Display: passo 4, immagine 1 di 2 Nokia 6085h Front LCD Display: passo 4, immagine 2 di 2
    • Remove the four 3.2 mm screws from the front panel using a T6 Torx screwdriver.
    • The fourth screw is located under a fold in the ribbon cable.
    Chiedi a FixBot
    Aggiungi Commento
  5. Nokia 6085h Front LCD Display: passo 5, immagine 1 di 3 Nokia 6085h Front LCD Display: passo 5, immagine 2 di 3 Nokia 6085h Front LCD Display: passo 5, immagine 3 di 3
    • Starting in the lower right corner, slowly begin to lift the tape that is holding down the front LCD and cables.
    • Be careful around the two ribbon cables attached to the tape. These cables are fragile.
    • Lift the tape from the board.
    Chiedi a FixBot
    Aggiungi Commento
  6. Nokia 6085h Front LCD Display: passo 6, immagine 1 di 1
    • Using a plastic opening tool, lift the ribbon cable connection below the front LCD.
    Chiedi a FixBot
    Aggiungi Commento
  7. Nokia 6085h Front LCD Display: passo 7, immagine 1 di 3 Nokia 6085h Front LCD Display: passo 7, immagine 2 di 3 Nokia 6085h Front LCD Display: passo 7, immagine 3 di 3
    • Using a plastic opening tool, slowly pry the LCD display from the bottom, releasing it from the glue that is holding it to the board.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 4-46, Amido Fall 2010 Membro di Cal Poly, Team 4-46, Amido Fall 2010
CPSU-AMIDO-F10S4G46
4 Membri
21 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 10
Ultimi 30 giorni: 34
Tutti i Tempi: 1,649
