Salta al contenuto principale
Nintendo Switch OLED Model Shield Plate Replacement
Cosa ti serve
  1. Nintendo Switch OLED Model Shield Plate Replacement, Release the Joy Con controller locking tabs: passo 1, immagine 1 di 3 Nintendo Switch OLED Model Shield Plate Replacement, Release the Joy Con controller locking tabs: passo 1, immagine 2 di 3 Nintendo Switch OLED Model Shield Plate Replacement, Release the Joy Con controller locking tabs: passo 1, immagine 3 di 3
    • Before you begin this repair, make sure the device is completely powered off.
    • Press and hold down the small round button on the back of the Joy Con controller.
    • While you hold down the button, slide the controller upward.
  2. Nintendo Switch OLED Model Shield Plate Replacement, Remove the Joy Con controllers: passo 2, immagine 1 di 3 Nintendo Switch OLED Model Shield Plate Replacement, Remove the Joy Con controllers: passo 2, immagine 2 di 3 Nintendo Switch OLED Model Shield Plate Replacement, Remove the Joy Con controllers: passo 2, immagine 3 di 3
    • Continue sliding the Joy Con upward until it's completely removed from the console.
    • Repeat this same process for the other Joy Con.
  3. Nintendo Switch OLED Model Shield Plate Replacement, Remove the top screw: passo 3, immagine 1 di 2 Nintendo Switch OLED Model Shield Plate Replacement, Remove the top screw: passo 3, immagine 2 di 2
    • Use a Phillips driver, or a JIS driver, to remove the 2 mm-long screw securing the top of the rear case to the frame.
    • To prevent these tight screws from stripping, apply firm downward force, work slowly, and try another JIS or Phillips driver if the screws won't come out.
  4. Nintendo Switch OLED Model Shield Plate Replacement, Remove the bottom screws: passo 4, immagine 1 di 2 Nintendo Switch OLED Model Shield Plate Replacement, Remove the bottom screws: passo 4, immagine 2 di 2
    • Use a Phillips driver to remove the two 2 mm-long screws securing the bottom of the rear case to the frame.
  5. Nintendo Switch OLED Model Shield Plate Replacement, Remove the right screw: passo 5, immagine 1 di 2 Nintendo Switch OLED Model Shield Plate Replacement, Remove the right screw: passo 5, immagine 2 di 2
    • Use a Phillips driver to remove the 3.8 mm screw securing the right Joy-Con sensor rail to the rear case.
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try another JIS 000 or PH 000 driver if the screws won't come out.
  6. Nintendo Switch OLED Model Shield Plate Replacement, Remove the left screw: passo 6, immagine 1 di 2 Nintendo Switch OLED Model Shield Plate Replacement, Remove the left screw: passo 6, immagine 2 di 2
    • Use a Phillips driver to remove the 3.8 mm screw securing the left Joy-Con sensor rail to the rear case.
  7. Nintendo Switch OLED Model Shield Plate Replacement, Open the kickstand: passo 7, immagine 1 di 2 Nintendo Switch OLED Model Shield Plate Replacement, Open the kickstand: passo 7, immagine 2 di 2
    • Use your finger to flip up the kickstand on the back of the device.
    • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
  8. Nintendo Switch OLED Model Shield Plate Replacement, Remove the back-side screws: passo 8, immagine 1 di 2 Nintendo Switch OLED Model Shield Plate Replacement, Remove the back-side screws: passo 8, immagine 2 di 2
    • Use a Y00 screwdriver to remove the two 4.3 mm screws securing the rear case to the frame.
  9. Nintendo Switch OLED Model Shield Plate Replacement, Remove the rear case: passo 9, immagine 1 di 3 Nintendo Switch OLED Model Shield Plate Replacement, Remove the rear case: passo 9, immagine 2 di 3 Nintendo Switch OLED Model Shield Plate Replacement, Remove the rear case: passo 9, immagine 3 di 3
    • Lift the rear case up from the top of the device and remove it.
    • If you're having trouble removing the case, use an opening pick to pry up the plastic clips.
  10. Nintendo Switch OLED Model Shield Plate Replacement, Remove the shield plate's tape: passo 10, immagine 1 di 2 Nintendo Switch OLED Model Shield Plate Replacement, Remove the shield plate's tape: passo 10, immagine 2 di 2
    • Use the flat end of a spudger to separate a corner of the tape from the shield plate.
  11. Nintendo Switch OLED Model Shield Plate Replacement: passo 11, immagine 1 di 3 Nintendo Switch OLED Model Shield Plate Replacement: passo 11, immagine 2 di 3 Nintendo Switch OLED Model Shield Plate Replacement: passo 11, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Use tweezers, or your fingers, to peel back and remove the tape.
    • Store the tape in a clean space for reinstallation.
  12. Nintendo Switch OLED Model Shield Plate Replacement, Disconnect the primary Wi-Fi antenna: passo 12, immagine 1 di 2 Nintendo Switch OLED Model Shield Plate Replacement, Disconnect the primary Wi-Fi antenna: passo 12, immagine 2 di 2
    • Use tweezers, or your fingers, to pull up and disconnect the primary Wi-Fi antenna's coaxial cable.
    • During reassembly, these can be tricky to reconnect. One at a time, hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  13. Nintendo Switch OLED Model Shield Plate Replacement, Reroute the primary antenna's coaxial cable: passo 13, immagine 1 di 3 Nintendo Switch OLED Model Shield Plate Replacement, Reroute the primary antenna's coaxial cable: passo 13, immagine 2 di 3 Nintendo Switch OLED Model Shield Plate Replacement, Reroute the primary antenna's coaxial cable: passo 13, immagine 3 di 3
    • Use tweezers, or your fingers, to reroute the primary antenna's coaxial cable out of its slots in the shield plate.
  14. Nintendo Switch OLED Model Shield Plate Replacement, Unfasten the primary Wi-Fi antenna: passo 14, immagine 1 di 2 Nintendo Switch OLED Model Shield Plate Replacement, Unfasten the primary Wi-Fi antenna: passo 14, immagine 2 di 2
    • Use a Phillips driver to remove the two 4.4 mm screws securing the primary Wi-Fi antenna to the shield plate.
  15. Nintendo Switch OLED Model Shield Plate Replacement, Remove the primary Wi-Fi antenna: passo 15, immagine 1 di 3 Nintendo Switch OLED Model Shield Plate Replacement, Remove the primary Wi-Fi antenna: passo 15, immagine 2 di 3 Nintendo Switch OLED Model Shield Plate Replacement, Remove the primary Wi-Fi antenna: passo 15, immagine 3 di 3
    • Insert an opening pick between the primary Wi-Fi antenna and the shield plate.
    • Pry up with the pick to separate the primary Wi-Fi antenna from the shield plate.
  16. Nintendo Switch OLED Model Shield Plate Replacement: passo 16, immagine 1 di 2 Nintendo Switch OLED Model Shield Plate Replacement: passo 16, immagine 2 di 2
    • Remove the primary Wi-Fi antenna.
  17. Nintendo Switch OLED Model Shield Plate Replacement, Disconnect the secondary Wi-Fi antenna: passo 17, immagine 1 di 2 Nintendo Switch OLED Model Shield Plate Replacement, Disconnect the secondary Wi-Fi antenna: passo 17, immagine 2 di 2
    • Use tweezers, or your fingers, to pull up and disconnect the secondary Wi-Fi antenna's coaxial cable.
  18. Nintendo Switch OLED Model Shield Plate Replacement, Reroute the secondary Wi-Fi antenna's coaxial cable: passo 18, immagine 1 di 2 Nintendo Switch OLED Model Shield Plate Replacement, Reroute the secondary Wi-Fi antenna's coaxial cable: passo 18, immagine 2 di 2
    • Use the point of a spudger to reroute the secondary Wi-Fi antenna's coaxial cable from its slot in the frame.
  19. Nintendo Switch OLED Model Shield Plate Replacement, Unfasten the secondary Wi-Fi antenna: passo 19, immagine 1 di 2 Nintendo Switch OLED Model Shield Plate Replacement, Unfasten the secondary Wi-Fi antenna: passo 19, immagine 2 di 2
    • Use a Phillips driver to remove the 4.4 mm screw securing the secondary Wi-Fi antenna to the shield plate.
  20. Nintendo Switch OLED Model Shield Plate Replacement, Remove the secondary Wi-Fi antenna: passo 20, immagine 1 di 3 Nintendo Switch OLED Model Shield Plate Replacement, Remove the secondary Wi-Fi antenna: passo 20, immagine 2 di 3 Nintendo Switch OLED Model Shield Plate Replacement, Remove the secondary Wi-Fi antenna: passo 20, immagine 3 di 3
    • Insert an opening pick between the secondary Wi-Fi antenna and the shield plate.
    • Pry up with the pick to separate the secondary Wi-Fi antenna from the shield plate.
    • Don't attempt to completely remove the antenna yet, as its coaxial cable is still routed through the frame.
  21. Nintendo Switch OLED Model Shield Plate Replacement: passo 21, immagine 1 di 3 Nintendo Switch OLED Model Shield Plate Replacement: passo 21, immagine 2 di 3 Nintendo Switch OLED Model Shield Plate Replacement: passo 21, immagine 3 di 3
    • Use the point of a spudger to reroute the secondary Wi-Fi antenna's coaxial cable out of its slot in the frame.
    • Remove the secondary Wi-Fi antenna.
  22. Nintendo Switch OLED Model Shield Plate Replacement, Unfasten the shield plate: passo 22, immagine 1 di 2 Nintendo Switch OLED Model Shield Plate Replacement, Unfasten the shield plate: passo 22, immagine 2 di 2
    • Use a Phillips driver to remove the six 4.4 mm screws securing the shield plate to the frame.
  23. Nintendo Switch OLED Model Shield Plate Replacement: passo 23, immagine 1 di 2 Nintendo Switch OLED Model Shield Plate Replacement: passo 23, immagine 2 di 2
    • Use your fingers to lift the top of the shield plate up and away from the frame.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • Remove the shield plate.
    • A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. Whenever the shield plate is removed, refer to our thermal paste guide to remove the old thermal compound and replace it with an appropriate compound, such as K5 Pro, during reassembly.
Conclusione
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch OLED Answers community for help.
Alex Diaz-Kokaisl
Membro da: 01/16/22
161.981 Reputazione
769 Guide realizzate
iFixit Membro di iFixit
Staff
118 Membri
19.410 Guide realizzate
3 Commenti
My question is, where do I get replacement screws? Are the shield screws the same size as the regular switch?
Ren Aokawa - Replica
Hi Ren.
Unfortunately, we don't sell the screws alongside the replacement shield. The regular Switch has different screws as well, but you might find some on eBay. I'm not sure how effective Nintendo's customer service is here, but you could give it a shot to find out the type of screws.
Alex Diaz-Kokaisl -
Where do I even by the oled heat plate from I keep finding normal switch or this %#*@ tutorial
Irritating llama - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 32
Ultimi 30 Giorni: 136
Tutti i Tempi: 4,137
