Salta al contenuto principale
Nintendo GameCube Controller Joystick Replacement
Cosa ti serve
  1. Nintendo GameCube Controller Joystick Replacement, Back Panel: passo 1, immagine 1 di 1
    • Place the controller (buttons down) on a solid surface.
    • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
    Chiedi a FixBot
    Aggiungi Commento
  2. Nintendo GameCube Controller Joystick Replacement: passo 2, immagine 1 di 1
    • Gently lift the back panel up, separating it from the front panel.
    • Some of the buttons may fall out if they are knocked around.
    Chiedi a FixBot
    Aggiungi Commento
  3. Nintendo GameCube Controller Joystick Replacement, Z Button: passo 3, immagine 1 di 2 Nintendo GameCube Controller Joystick Replacement, Z Button: passo 3, immagine 2 di 2
    • Grab the Z-button by the peg with tweezers and lift it out of the controller.
    • During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
    Chiedi a FixBot
    Aggiungi Commento
  4. Nintendo GameCube Controller Joystick Replacement, Circuit Board: passo 4, immagine 1 di 1
    • Carefully unhook the cable that is looped around the peg.
    Chiedi a FixBot
    Aggiungi Commento
  5. Nintendo GameCube Controller Joystick Replacement: passo 5, immagine 1 di 1
    • Lift the circuit board out of the controller.
    • Do not grab the rumble motor to lift the circuit board as shown in the picture. It will in many cases just remove the rumble motor. Instead, grab the edges of the board.
    Chiedi a FixBot
    Aggiungi Commento
  6. Nintendo GameCube Controller Joystick Replacement, Joystick: passo 6, immagine 1 di 2 Nintendo GameCube Controller Joystick Replacement, Joystick: passo 6, immagine 2 di 2
    • Grab the base of the grey cover and pull it off.
    • During reassembly, make sure the slots inside the joy stick line up so they can fit back together.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 32 persone hanno completato questa guida.
Sean Michel
Membro da: 01/14/13
2.750 Reputazione
8 guide realizzate
Cal Poly, Team 19-44, Regan Winter 2013 Membro di Cal Poly, Team 19-44, Regan Winter 2013
CPSU-REGAN-W13S19G44
4 Membri
34 guide realizzate
13Commenti sulla guida
Great guide, but I'm looking to buy replacement joysticks and I can't find them anywhere. Where would I find those?
Joe Freedman - Rispondi Condividi
When I removed the joystick it would come off. The plastic was stuck too hard to the joystick so I accidentally broke it in half. Is there anyway to glue it back together?
Mattias Wirsenius - Rispondi Condividi
@Tyler Lovejoy - That's already part of the controller.
@Joe Freedman - Try Amazon.com
@Mattias Wirsenius - At this point it would be best to buy a new controller.
builderman1q2w3e4r - Rispondi Condividi
This guide is quite unhelpful; it tells you how to remove the stick but not how to repair it. My controller's joystick has sunken into the controller and stays slightly tilted if i move it to the right. Yet when I go to the "rogue joystick" portion of the troubleshooting guide, it tells me to repair the joystick if it's not correctly attached to the motherboard. Seriously, there needs to be a more in-depth guide if such repairs are possible.
J DC - Rispondi Condividi
without taking the controller completely apart, pull the joystick straight up with your hand
McRedstoneYT - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 25
Ultimi 7 giorni: 115
Ultimi 30 giorni: 505
Tutti i Tempi: 110,285
