Salta al contenuto principale
Nintendo GameCube Controller Buttons Replacement
Cosa ti serve
  1. Nintendo GameCube Controller Buttons Replacement, Back Panel: passo 1, immagine 1 di 1
    • Place the controller (buttons down) on a solid surface.
    • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
    Chiedi a FixBot
    Aggiungi Commento
  2. Nintendo GameCube Controller Buttons Replacement: passo 2, immagine 1 di 1
    • Gently lift the back panel up, separating it from the front panel.
    • Some of the buttons may fall out if they are knocked around.
    Chiedi a FixBot
    Aggiungi Commento
  3. Nintendo GameCube Controller Buttons Replacement, Z Button: passo 3, immagine 1 di 2 Nintendo GameCube Controller Buttons Replacement, Z Button: passo 3, immagine 2 di 2
    • Grab the Z-button by the peg with tweezers and lift it out of the controller.
    • During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
    Chiedi a FixBot
    Aggiungi Commento
  4. Nintendo GameCube Controller Buttons Replacement, Circuit Board: passo 4, immagine 1 di 1
    • Carefully unhook the cable that is looped around the peg.
    Chiedi a FixBot
    Aggiungi Commento
  5. Nintendo GameCube Controller Buttons Replacement: passo 5, immagine 1 di 1
    • Lift the circuit board out of the controller.
    • Do not grab the rumble motor to lift the circuit board as shown in the picture. It will in many cases just remove the rumble motor. Instead, grab the edges of the board.
    Chiedi a FixBot
    Aggiungi Commento
  6. Nintendo GameCube Controller Buttons Replacement, Buttons: passo 6, immagine 1 di 2 Nintendo GameCube Controller Buttons Replacement, Buttons: passo 6, immagine 2 di 2
    • Remove the rubber backing that covers the buttons.
    Chiedi a FixBot
    Aggiungi Commento
  7. Nintendo GameCube Controller Buttons Replacement: passo 7, immagine 1 di 3 Nintendo GameCube Controller Buttons Replacement: passo 7, immagine 2 di 3 Nintendo GameCube Controller Buttons Replacement: passo 7, immagine 3 di 3
    Strumento utilizzato in questo passaggio:
    • Use tweezers to lift buttons out of their sockets.
    • When putting the buttons back, make sure the slots properly fit back together.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 20 persone hanno completato questa guida.
Sean Michel
Membro da: 01/14/13
2.750 Reputazione
8 guide realizzate
Cal Poly, Team 19-44, Regan Winter 2013 Membro di Cal Poly, Team 19-44, Regan Winter 2013
CPSU-REGAN-W13S19G44
4 Membri
34 guide realizzate
3Commenti sulla guida
Is there a way I can buy the buttons separably? I lost a the X button and it's gone missing and i wanna buy one :(
tp4yourbunghole - Rispondi Condividi
u can either get a 2 dollar full button set on ebay by searching ngc buttons or u can buy from battle beaver customs for 1 dollar
dariuscorrfz - Rispondi Condividi
How do you put the back back on?
Steven Enns - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 39
Ultimi 30 giorni: 197
Tutti i Tempi: 32,983
