Salta al contenuto principale
Netgear WGR614v9 Capacitor Replacement
Cosa ti serve
    1. Netgear WGR614v9 Capacitor Replacement, Lower Case: passo 1, immagine 1 di 1
      • Rotate the device so that the bottom is facing up.
      Chiedi a FixBot
      Aggiungi Commento
    2. Netgear WGR614v9 Capacitor Replacement: passo 2, immagine 1 di 2 Netgear WGR614v9 Capacitor Replacement: passo 2, immagine 2 di 2
      • Lift up all four rubber pads on the bottom of the router with the plastic opening tool.
      • Be careful not to pull the rubber pads all the way out when lifting as they are difficult to reinsert.
      Chiedi a FixBot
      Aggiungi Commento
    3. Netgear WGR614v9 Capacitor Replacement: passo 3, immagine 1 di 2 Netgear WGR614v9 Capacitor Replacement: passo 3, immagine 2 di 2
      • Unscrew the four 11.8 mm T-8 torx screws from the bottom of the router.
      Chiedi a FixBot
      Aggiungi Commento
    4. Netgear WGR614v9 Capacitor Replacement: passo 4, immagine 1 di 1
      • Lift the bottom casing straight up from the router.
      Chiedi a FixBot
      Aggiungi Commento
    1. Netgear WGR614v9 Capacitor Replacement, Motherboard: passo 5, immagine 1 di 1
      • Remove the clear plastic casing by lifting it straight up from the router.
      Chiedi a FixBot
      Aggiungi Commento
    2. Netgear WGR614v9 Capacitor Replacement: passo 6, immagine 1 di 2 Netgear WGR614v9 Capacitor Replacement: passo 6, immagine 2 di 2
      • Separate the motherboard from the top shell by lifting it straight up from the router.
      Chiedi a FixBot
      Aggiungi Commento
    1. Netgear WGR614v9 Capacitor Replacement, Capacitor: passo 7, immagine 1 di 2 Netgear WGR614v9 Capacitor Replacement, Capacitor: passo 7, immagine 2 di 2
      • Rotate the motherboard so that the top is facing up.
      • Set the motherboard on a flat clean surface.
      Chiedi a FixBot
      Aggiungi Commento
    2. Netgear WGR614v9 Capacitor Replacement: passo 8, immagine 1 di 2 Netgear WGR614v9 Capacitor Replacement: passo 8, immagine 2 di 2
      • The capacitor can be found at the location shown.
      Chiedi a FixBot
      Aggiungi Commento
    3. Netgear WGR614v9 Capacitor Replacement: passo 9, immagine 1 di 2 Netgear WGR614v9 Capacitor Replacement: passo 9, immagine 2 di 2
      • Rotate the motherboard so that the bottom is facing up.
      • Locate the two soldered contacts of the capacitor.
      Chiedi a FixBot
      Aggiungi Commento
    4. Netgear WGR614v9 Capacitor Replacement: passo 10, immagine 1 di 3 Netgear WGR614v9 Capacitor Replacement: passo 10, immagine 2 di 3 Netgear WGR614v9 Capacitor Replacement: passo 10, immagine 3 di 3
      • Rotate the motherboard 180 degrees.
      • Do not refer to the pictures in this step for proper de-soldering and soldering techniques. They are for illustration purposes only.
      • Refer to this link for proper de-soldering and soldering techniques.
      • Pull the capacitor from the other side of the circuit board once the solder is liquified.
      • To replace the capacitor, orient the negative side of the capacitor (indicated by a white stripe and a negative sign) so that it aligns with the shaded white region of the circle indicating the capacitor's position on the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Kyle Moore
Membro da: 10/03/11
95 Reputazione
Una guida realizzata
Cal Poly, Team 21-24, Maness Fall 2011 Membro di Cal Poly, Team 21-24, Maness Fall 2011
CPSU-MANESS-F11S21G24
4 Membri
11 guide realizzate
1Commento della guida
looks like that's a 220microF at 25V right ?
probably better to replace it with a similar 220microF, but with higher voltage rating.
email_etran - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 12
Ultimi 30 giorni: 43
Tutti i Tempi: 3,802
