Salta al contenuto principale
Motorola Moto G5 Battery Replacement
Cosa ti serve
  1. Motorola Moto G5 Battery Replacement, Back Cover: passo 1, immagine 1 di 2 Motorola Moto G5 Battery Replacement, Back Cover: passo 1, immagine 2 di 2
    • Insert your fingernail or the flat end of a spudger into the notch on the bottom edge of the phone near the charging port.
    • Pry with your fingernail or twist the spudger to release the back cover from the phone.
  2. Motorola Moto G5 Battery Replacement: passo 2, immagine 1 di 3 Motorola Moto G5 Battery Replacement: passo 2, immagine 2 di 3 Motorola Moto G5 Battery Replacement: passo 2, immagine 3 di 3
    • Insert the flat end of a spudger into the seam and slide it along the bottom edge to release the clips holding the back cover to the phone.
  3. Motorola Moto G5 Battery Replacement: passo 3, immagine 1 di 3 Motorola Moto G5 Battery Replacement: passo 3, immagine 2 di 3 Motorola Moto G5 Battery Replacement: passo 3, immagine 3 di 3
    • Continue sliding the flat end of the spudger along the seam for the remaining sides of the phone.
  4. Motorola Moto G5 Battery Replacement: passo 4, immagine 1 di 2 Motorola Moto G5 Battery Replacement: passo 4, immagine 2 di 2
    • Lift the back cover and remove it from the phone.
    • To reinstall the back cover, align the cover with the phone and squeeze along the edges to snap the clips back into place.
  5. Motorola Moto G5 Battery Replacement, Battery: passo 5, immagine 1 di 2 Motorola Moto G5 Battery Replacement, Battery: passo 5, immagine 2 di 2
    • Insert your fingernail or the flat end of the spudger into the notch below the battery.
    • Pry with your fingernail or spudger until you free the battery from its recess.
  6. Motorola Moto G5 Battery Replacement: passo 6, immagine 1 di 1
    • Remove the battery.
    • When installing the battery, make sure the battery's contacts line up with the three gold pins on the top right.
Conclusione
After completing this guide, calibrate your newly-installed battery.
Repair didn’t go as planned? Check out our Motorola Moto G5 Answers community for troubleshooting help.
Altre 9 persone hanno completato questa guida.
Arthur Shi
Membro da: 01/03/18
252.816 Reputazione
526 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
16.817 Guide realizzate
5 Commenti
this is not the g5 replacement procedure. it will not work.need to remove screen.
Tom Tercek - Replica
@Tom Tercek - You are in a huge mistake. This is the Motorola Moto G5 phone and the battery is removable and as shown on the pics, very easy to replace.
prishylets - Replica
is it also possible with moto g5s?
Jojo Blublub - Replica
Unfortunately, the G5S does not have an easily replaceable battery.
Arthur Shi -
Hi, I'm looking for parts for Moto G5, specifically an intern plastic cover that goes over the charge port.
Leonardo - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 67
Ultimi 30 Giorni: 431
Tutti i Tempi: 39,161
