Salta al contenuto principale
Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement
Cosa ti serve
  1. Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement, Remove the rear cover: passo 1, immagine 1 di 2 Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement, Remove the rear cover: passo 1, immagine 2 di 2
    • Before removing the battery, power off your Moto E4.
    • Remove the plastic cover by gently prying it up from the notch at the bottom right corner of the phone.
    • With the phone face down, lift the battery up by the labeled tab and remove it from the device.
  2. Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement, Remove the motherboard cover: passo 2, immagine 1 di 2 Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement, Remove the motherboard cover: passo 2, immagine 2 di 2
    • The battery is shown inserted in the Moto E4, but it should be removed before performing the following step.
    • Remove all nine 4 mm Phillips screws from the top plastic cover.
  3. Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement: passo 3, immagine 1 di 2 Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement: passo 3, immagine 2 di 2
    • Gently pry up the plastic cover using a plastic opening tool.
    • Start by inserting the tool under the cover's right edge, as indicated by the first picture.
    • Pry up, and continue prying around the rest of the cover in a counter clockwise path.
    • Once loose, remove the plastic cover from the phone.
  4. Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement: passo 4, immagine 1 di 3 Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement: passo 4, immagine 2 di 3 Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement: passo 4, immagine 3 di 3
    • This step can be skipped if you are only removing the front-facing camera. For all other repairs, continue as follows.
    • Disconnect the rear-facing camera by prying straight up on the connector on its right side.
    • Remove the rear-facing camera from the Moto E4.
  5. Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement, Remove the motherboard: passo 5, immagine 1 di 2 Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement, Remove the motherboard: passo 5, immagine 2 di 2
    • Disconnect the display cable by prying it straight up from the motherboard.
  6. Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement: passo 6, immagine 1 di 2 Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement: passo 6, immagine 2 di 2
    • Unlock the ZIF connector for the side buttons by prying up the black locking flap opposite the cable.
    • Pull the cable carefully toward the edge of the phone to slide it from its socket.
  7. Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement: passo 7, immagine 1 di 2 Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement: passo 7, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Disconnect the antenna cable by sliding a plastic pry tool or fine tweezers under the wire close to its socket, and then prying straight up.
  8. Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement: passo 8, immagine 1 di 1
    • Remove the two 3.1 mm long Phillips screws securing the motherboard.
  9. Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement: passo 9, immagine 1 di 2 Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement: passo 9, immagine 2 di 2
    • Grab the top edge of the motherboard and lift to hinge it upward (but don't try to fully remove it). While doing so, keep all other cables clear of the motherboard.
    • Use a spudger or other fine-tip pry tool to pry off and disconnect the last remaining ribbon cable on the underside of the motherboard.
    • Remove the Moto E4 motherboard.
  10. Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement, Detach the grounding cable: passo 10, immagine 1 di 1
    • The screen's grounding cable is adhered to the frame near the top of the phone.
    • Use a plastic opening tool to carefully separate the cable until it detaches.
  11. Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement, Apply heat to the edge of the phone: passo 11, immagine 1 di 1
    • Heat an iOpener and apply it to the left edge of the screen for one minute to help soften the adhesive securing the screen.
    • A hair dryer, heat gun, or hot plate may also be used.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  12. Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement, Create an opening gap: passo 12, immagine 1 di 3 Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement, Create an opening gap: passo 12, immagine 2 di 3 Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement, Create an opening gap: passo 12, immagine 3 di 3
    • Apply a suction cup to the screen, near the heated edge of the phone.
    • Pull on the suction cup with strong, steady force to create a gap between the screen and frame.
    • Insert the point of an opening pick into the gap.
    • Due to the strong adhesive, this may take multiple attempts. If you have trouble, heat the edge for another minute and try again.
  13. Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement, Slice through the screen adhesive: passo 13, immagine 1 di 3 Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement, Slice through the screen adhesive: passo 13, immagine 2 di 3 Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement, Slice through the screen adhesive: passo 13, immagine 3 di 3
    • Slide the opening pick along the left edge to slice through the adhesive.
    • As you push the pick into the phone, you may feel it press against the edge of the LCD underneath the glass. If you angle the point of the pick downwards, you can slide the pick underneath the edge of the LCD.
  14. Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement: passo 14, immagine 1 di 3 Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement: passo 14, immagine 2 di 3 Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement: passo 14, immagine 3 di 3
    • Apply a heated iOpener to the bottom edge of the phone for a minute to soften the adhesive.
    • Use an opening pick to slice through the adhesive at the bottom edge of the phone.
    • The adhesive here is as thick as the bezel. Be sure to slice deep enough to cut through all of the adhesive.
  15. Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement: passo 15, immagine 1 di 2 Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement: passo 15, immagine 2 di 2
    • Continue heating and slicing along the right and top edges of the phone.
    • Leave an opening pick in the seam to prevent the adhesive from resealing.
  16. Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement, Detach the screen from the phone: passo 16, immagine 1 di 2 Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement, Detach the screen from the phone: passo 16, immagine 2 di 2
    • Lift up the bottom edge of the screen by a few degrees and slice any remaining adhesive.
  17. Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement: passo 17, immagine 1 di 3 Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement: passo 17, immagine 2 di 3 Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement: passo 17, immagine 3 di 3
    • The screen cable is still adhered to the frame.
    • Grasp the phone near the top edge and slowly separate the screen and the display cable from the frame.
    • As you lift the screen away, thread the grounding cable and the screen cable through their respective cutouts.
  18. Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement, Remove the screen: passo 18, immagine 1 di 1
    • Remove the screen.
    • Compare your screen with the replacement part. You may need to transfer certain components such as the earpiece bezel to your replacement part.
  19. Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement, Prepare the replacement screen: passo 19, immagine 1 di 3 Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement, Prepare the replacement screen: passo 19, immagine 2 di 3 Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement, Prepare the replacement screen: passo 19, immagine 3 di 3
    • This step shows how to prepare your replacement screen for installation.
    • If your replacement screen came with the digitizer cable disconnected, be sure to connect it before installation:
    • Use a spudger to flip up the digitizer cable ZIF socket's locking bar, located on the back of the screen near the top right corner.
    • Peel off the small square plastic liner under the digitizer cable to expose the adhesive.
    • Press the cable down against the back of the screen.
    • Carefully feed the cable into the digitizer cable socket until the white bar printed on the cable is barely visible.
    • Flip the socket's locking bar down to secure the cable in place.
    • Peel all plastic liners from the replacement screen.
  20. Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement, Prepare the phone frame: passo 20, immagine 1 di 2 Motorola Moto E4 Screen (No Fingerprint Sensor) Replacement, Prepare the phone frame: passo 20, immagine 2 di 2
    Tesa 61395 Tape
    $5.99
    • Before you install a replacement screen, be sure to remove all traces of adhesive from the phone frame. Use high concentration (>90%) isopropyl alcohol to help remove stubborn adhesive.
    • For best results, reassemble your phone and test your repair before sealing the new display in place.
    • Be sure to guide both the display cable and the grounding cable through their respective frame cutouts.
    • To attach your replacement screen, apply a custom-cut adhesive strip to the frame, or use a strong double-sided tape such as Tesa 61395.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Motorola E4 Answers community for help.
Arthur Shi
Membro da: 01/03/18
282.802 Reputazione
587 Guide realizzate
iFixit Membro di iFixit
Staff
118 Membri
19.465 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,947
