Salta al contenuto principale
Moto Z Battery Replacement
Solo Prerequisita
Questa guida è destinata a essere usata solo come prerequisito per altre guide. Da sola è incompleta.
Cosa ti serve
  1. Moto Z Battery Replacement, Battery: passo 1, immagine 1 di 3 Moto Z Battery Replacement, Battery: passo 1, immagine 2 di 3 Moto Z Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Use tweezers to peel the black tape securing the battery to the frame.
    • If your replacement battery did not come with this piece of tape, transfer it from the old battery to the replacement battery.
  2. Moto Z Battery Replacement: passo 2, immagine 1 di 1
    • Lay a heated iOpener on the back of the phone as shown for as least 90 seconds.
  3. Moto Z Battery Replacement: passo 3, immagine 1 di 3 Moto Z Battery Replacement: passo 3, immagine 2 di 3 Moto Z Battery Replacement: passo 3, immagine 3 di 3
    • Using a pair of tweezers or your fingers, grab the black battery pull tab and slowly pull it upwards until the corner is loose.
    • Do not fully remove the battery as it is still connected by a flex cable.
  4. Moto Z Battery Replacement: passo 4, immagine 1 di 2 Moto Z Battery Replacement: passo 4, immagine 2 di 2
    • Follow this step only if your battery tab has broken. Otherwise, skip to the next step.
    • Insert a spudger into the bottom edge of the battery and slowly pry the corner up.
  5. Moto Z Battery Replacement: passo 5, immagine 1 di 3 Moto Z Battery Replacement: passo 5, immagine 2 di 3 Moto Z Battery Replacement: passo 5, immagine 3 di 3
    • Carefully swing the battery towards the right edge.
    • Lay the battery flat against the work surface while taking care not to strain the battery cable.
  6. Moto Z Battery Replacement: passo 6, immagine 1 di 3 Moto Z Battery Replacement: passo 6, immagine 2 di 3 Moto Z Battery Replacement: passo 6, immagine 3 di 3
    • Use the point of a spudger to pry up the battery connector bracket.
    • The bracket is held in place by some adhesive and tabs.
    • Remove the battery connector bracket.
    • When you reinstall the bracket, make sure to align the tabs on the bracket with the indents on the left edge of the frame.
  7. Moto Z Battery Replacement: passo 7, immagine 1 di 2 Moto Z Battery Replacement: passo 7, immagine 2 di 2
    • Using the point of a spudger, pry up the battery connector from its socket.
  8. Moto Z Battery Replacement: passo 8, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Tesa 61395 Tape
    $5.99
    Compra
    • Remove the battery.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • To install a new battery:
    • Remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    • Apply pre-cut adhesive strips or double-sided tape to the exposed, silver part of the battery compartment, not on the black foam layer.
    • Press the battery firmly into place for 5-10 seconds.
Conclusione
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Motorola Moto Z Answers community for troubleshooting help.
Arthur Shi
Membro da: 01/03/18
252.818 Reputazione
526 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
16.817 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 83
