Salta al contenuto principale
Mini Digital Oscilloscope DIY Soldering Kit Assembly
Cosa ti serve
  1. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Prepare your equipment: passo 1, immagine 1 di 2 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Prepare your equipment: passo 1, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    iFixit Safety Glasses
    $3.99
  2. Mini Digital Oscilloscope DIY Soldering Kit Assembly: passo 2, immagine 1 di 1
    • Your oscilloscope kit contains the following parts:
    • Circuit board
    • Case
    • Microcontroller (aka CPU)
    • Resistors & capacitors
    • Power inductor
    • External interfaces
    • OLED display and display connectors
  3. Mini Digital Oscilloscope DIY Soldering Kit Assembly: passo 3, immagine 1 di 2 Mini Digital Oscilloscope DIY Soldering Kit Assembly: passo 3, immagine 2 di 2
    • Each resistor and capacitor (besides the three 2 kΩ resistors) are unique, and must be installed in their correct spot on the board. The 10 μF and 22 nF capacitors look identical apart from the packaging labeled 103. Use tweezers to remove each component's packaging before soldering.
    • LED
    • 1W/10 kΩ (103) resistor
    • 10 kΩ (103) resistor
    • 2 kΩ (202) resistors
    • 10 μF capacitor
    • 10 nF (103) capacitor
    • 22 nF capacitor
  4. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Prepare the board: passo 4, immagine 1 di 1
    Silicone Work Mat
    $9.95
    • Set down the circuit board on your work mat/surface so the front (the side labeled MiNi-DSO at the top) is facing up.
  5. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Prepare to solder: passo 5, immagine 1 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Prepare to solder: passo 5, immagine 2 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Prepare to solder: passo 5, immagine 3 di 3
    FixHub | Power Series Smart Soldering Iron
    $79.95
    • Put on your safety glasses.
    • Turn on your soldering iron. If your soldering iron has temperature control:
    • Set it to 300 °C (~570 °F) if you're using leaded solder
    • Set it to 375 °C (~700 °F) if you're using lead-free solder
    • Clean the tip of your soldering iron. If you're using a cellulose sponge, wet the sponge with distilled water until damp and quickly wipe the tip across it. If you're using brass wool, stab the tip into the wire a few times.
    • Melt a small glob of solder onto the tip of the iron. This is called "tinning the tip" and will help with heat transfer.
    • You'll likely see some wispy smoke as you melt solder. This is mostly the rosin-core flux that's built into the solder wire. Flux helps molten solder flow, but gets vaporized over time.
  6. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the first resistor: passo 6, immagine 1 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the first resistor: passo 6, immagine 2 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the first resistor: passo 6, immagine 3 di 3
    • In this step, you're going to pre-load one of the resistor's pads on the board with solder. This will make it easier to solder the resistor.
    • Press the iron's tip against one of the solder pads in the outline labeled R4 for a few seconds to heat it.
    • If you heat the circuit board continuously for more than 10 seconds, the excessive heat may damage the solder pad.
    • Feed the solder wire into the heated area until there's a small glob of solder on the pad.
    • The solder should melt onto the pad within a few seconds. If the solder doesn't adhere to the pad, apply flux to the pad or increase the temperature.
    • Remove the solder wire first, then remove the soldering iron from the pad.
  7. Mini Digital Oscilloscope DIY Soldering Kit Assembly: passo 7, immagine 1 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly: passo 7, immagine 2 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly: passo 7, immagine 3 di 3
    • Place the largest 10 kΩ resistor (labeled 103) in the outline labeled R4 on the board.
    • For a handy surface-mount resistor value calculator, click here. All the resistors in this kit are 3 digit EIA (Electronic Industries Alliance).
    • Re-heat the solder while holding the resistor in its outline until the molten solder envelops the end (shiny) cap.
    • All the resistors through Step 13 are symmetrical and can be soldered in either orientation.
    • If the solder won't envelop the cap, add some flux or a little fresh solder and try again.
    • Remove the iron, then remove the tweezers once the solder has cooled.
  8. Mini Digital Oscilloscope DIY Soldering Kit Assembly: passo 8, immagine 1 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly: passo 8, immagine 2 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly: passo 8, immagine 3 di 3
    • In this step, you're going to heat the solder pad and the resistor's end cap so that they'll readily melt the solder wire.
    • Press the tip against the second R4 solder pad and the resistor's second end cap for a few seconds to heat them both. Angle the tip so it has maximum contact with the pad and cap.
    • If you heat them continuously for more than 10 seconds, the excessive heat may damage the solder pad or resistor.
    • Feed the solder wire into the heated area until there's a small glob of solder surrounding the end cap.
  9. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Check your work: passo 9, immagine 1 di 1
    • Congratulations—you've soldered the resistor to the board!
    • If one of the solder joints doesn't make contact with an end cap, reheat the cap and add more solder. If the solder isn't flowing neatly, apply flux to the joint before adding more solder.
    • Check if any solder has unintentionally bridged with a different pad. If so, carefully use your iron to heat the solder between the pads and separate the bridge. If the bridge doesn't want to separate, desolder it and try again.
  10. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the second resistor: passo 10, immagine 1 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the second resistor: passo 10, immagine 2 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the second resistor: passo 10, immagine 3 di 3
    • Press the iron's tip against one of the board's R2 solder pads for a few seconds to heat it.
  11. Mini Digital Oscilloscope DIY Soldering Kit Assembly: passo 11, immagine 1 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly: passo 11, immagine 2 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly: passo 11, immagine 3 di 3
    • Place the smaller 10 kΩ resistor (labeled 103) in the outline labeled R2 on the board.
    • Press the soldering iron's tip onto the edge of the solder pad while holding the resistor in its outline, so that its end caps (the shiny parts) are resting on the circuit board's pads.
  12. Mini Digital Oscilloscope DIY Soldering Kit Assembly: passo 12, immagine 1 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly: passo 12, immagine 2 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly: passo 12, immagine 3 di 3
    • Press the tip against the second R2 solder pad and the resistor's second end cap for a few seconds to heat them both. Angle the tip so it has maximum contact with the pad and cap.
    • Feed the solder wire into the heated area until there's a small glob of solder surrounding the second end cap.
  13. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the remaining resistors: passo 13, immagine 1 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the remaining resistors: passo 13, immagine 2 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the remaining resistors: passo 13, immagine 3 di 3
    • Repeat this process to solder the three 2 kΩ resistors (labeled 202) in the outlines labeled R3, R1, and R5 on the front of the board.
  14. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the capacitors: passo 14, immagine 1 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the capacitors: passo 14, immagine 2 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the capacitors: passo 14, immagine 3 di 3
    • Repeat the process to solder the three capacitors to the front of the board:
    • The large capacitor in the outline labeled C1
    • The capacitor labeled 103 on its packaging in the outline labeled C2
    • The 22 nF capacitor (with no label on its packaging) in the outline labeled C3
  15. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the LED: passo 15, immagine 1 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the LED: passo 15, immagine 2 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the LED: passo 15, immagine 3 di 3
    • Press the iron's tip against the circuit board's LED solder pad for a few seconds to heat it, then feed the solder wire into the heated area until there's a small glob of solder on the pad.
    • Place the LED in the outline labeled LED on the board, with the white (non-green) side aligned with the "+" symbol.
    • The green markings indicate the negative (-) side.
    • Solder the LED's first end cap to the board.
    • The LED's contact pads are underneath it, so the solder joint doesn't need to cover the entire end.
  16. Mini Digital Oscilloscope DIY Soldering Kit Assembly: passo 16, immagine 1 di 2 Mini Digital Oscilloscope DIY Soldering Kit Assembly: passo 16, immagine 2 di 2
    • Press the tip against the second LED solder pad and feed the solder wire into the heated area until there's a small glob of solder contacting the end cap.
  17. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the microcontroller: passo 17, immagine 1 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the microcontroller: passo 17, immagine 2 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the microcontroller: passo 17, immagine 3 di 3
    • In this step, you're going to apply solder to one of the microcontroller pads to help with alignment when you solder it to the board.
    • Press the iron's tip against the board's bottom left microcontroller solder pad for a few seconds to heat it.
    • Since these pads are so close together, it's easy for the solder to adhere to multiple pads. This is fine as long as the pads aren't bridged to each other.
  18. Mini Digital Oscilloscope DIY Soldering Kit Assembly: passo 18, immagine 1 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly: passo 18, immagine 2 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly: passo 18, immagine 3 di 3
    • Repeat the last step to apply solder to the board's top right microcontroller solder pad.
  19. Mini Digital Oscilloscope DIY Soldering Kit Assembly: passo 19, immagine 1 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly: passo 19, immagine 2 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly: passo 19, immagine 3 di 3
    $3.99
    • Orient the microcontroller with its outline (labeled U1) on the circuit board, so the circle on microcontroller is on top of the circle on the board.
    • The indented circle on the microcontroller should be facing the same corner as the dot next to the U1 label on the board.
    • Align all 44 pins are aligned with their respective pads on the board.
    • Ensure the microcontroller is aligned both vertically AND horizontally. Once multiple pads are soldered, it is extremely difficult to remove the microcontroller and try again.
    • Hold the microcontroller still with tweezers and re-heat the solder from the last two steps to solder it to the board.
    • If you have polyimide tape, you can use it to hold the microcontroller still while you solder the first two leads.
  20. Mini Digital Oscilloscope DIY Soldering Kit Assembly: passo 20, immagine 1 di 1
    • This process is both difficult and time-consuming. Take your time and be extra careful not to overheat the solder pads or pins. Avoid using desoldering wick to desolder the leads, as it could easily destroy the pads.
    • Press the tip against another solder pad and feed the solder wire into the heated area until there's a small solder joint on the pin.
    • Check if any solder unintentionally bridged with a different joint. If so, carefully use your iron to heat the solder between the joints and separate the bridge. If the bridge doesn't want to separate, desolder it using a desoldering pump and try again. Be careful not to overheat the pins or the pads while desoldering.
    • Repeat this process for all of the remaining microcontroller pins.
  21. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Insert the USB port: passo 21, immagine 1 di 2 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Insert the USB port: passo 21, immagine 2 di 2
    • Align the USB port with the outline labeled USB on the front of the board.
    • Insert the leads of the USB port into their four holes on the board, so it sits flush.
  22. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the USB port: passo 22, immagine 1 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the USB port: passo 22, immagine 2 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the USB port: passo 22, immagine 3 di 3
    • Flip the board over so the pins are facing up.
    • Press down with the tip of your iron on the one of the USB port's solder pads closest to the edge and solder the USB port's first pin.
    • Solder the remaining USB port pins.
  23. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Insert the UART connector: passo 23, immagine 1 di 2 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Insert the UART connector: passo 23, immagine 2 di 2
    • Align the UART connector with the outline labeled UART on the front of the board.
    • Insert the shorter pins of the UART connector into their four holes on the board, so it sits flush.
  24. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the UART connector: passo 24, immagine 1 di 2 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the UART connector: passo 24, immagine 2 di 2
    • Solder the UART connector to the board.
  25. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the power inductor: passo 25, immagine 1 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the power inductor: passo 25, immagine 2 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the power inductor: passo 25, immagine 3 di 3
    • Press the iron's tip against the circuit board's L1 solder pad for a few seconds to heat it, then feed the solder wire into the heated area until there's a small glob of solder on the pad.
    • Re-heat the solder while holding the inductor in its outline, so that its end caps (the sides with the notches) are resting on the circuit board's pads.
    • The power inductor is symmetrical and can be soldered in either orientation, as long as the notches are above the pads.
  26. Mini Digital Oscilloscope DIY Soldering Kit Assembly: passo 26, immagine 1 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly: passo 26, immagine 2 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly: passo 26, immagine 3 di 3
    • Press the tip against the power inductor's second solder pad and the power inductor's second end cap for a few seconds to heat them both. Angle the tip so it has maximum contact with the pad and cap.
    • Feed the solder wire into the heated area until there's a small glob of solder joining the second end cap to its pad.
    • The power inductor's contact pads are underneath it, so the solder joint doesn't need to cover the entire end.
  27. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Insert the test rings: passo 27, immagine 1 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Insert the test rings: passo 27, immagine 2 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Insert the test rings: passo 27, immagine 3 di 3
    • Use tweezers to pick up one of the test rings and squeeze its leads together.
    • Insert the test ring leads into the hole labeled PWM on the front of the board.
  28. Mini Digital Oscilloscope DIY Soldering Kit Assembly: passo 28, immagine 1 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly: passo 28, immagine 2 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly: passo 28, immagine 3 di 3
    • Repeat this process for the other test ring in the hole labeled SIN.
  29. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the test rings: passo 29, immagine 1 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the test rings: passo 29, immagine 2 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the test rings: passo 29, immagine 3 di 3
    • Flip the board over so the test rings' leads are facing up.
    • Solder the test rings to the board.
  30. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Insert the toggle switch: passo 30, immagine 1 di 2 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Insert the toggle switch: passo 30, immagine 2 di 2
    • Align the toggle switch with the outline labeled ON on the front of the board, with the switch itself facing outwards.
    • Insert the switch's five pins into their holes in the board.
  31. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the toggle switch: passo 31, immagine 1 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the toggle switch: passo 31, immagine 2 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the toggle switch: passo 31, immagine 3 di 3
    • Flip the board so the toggle switch's pins are facing up.
    • Solder the toggle switch to the board.
  32. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Insert the female header strip: passo 32, immagine 1 di 2 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Insert the female header strip: passo 32, immagine 2 di 2
    • Align the OLED female header strip with the outline labeled OLED on the board.
    • Insert the header's seven pins into their holes in the board.
  33. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the female header strip: passo 33, immagine 1 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the female header strip: passo 33, immagine 2 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the female header strip: passo 33, immagine 3 di 3
    • Flip the board over so the header strip's pins are facing up.
    • Solder the female header strip to the board.
  34. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Insert the terminal block: passo 34, immagine 1 di 2 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Insert the terminal block: passo 34, immagine 2 di 2
    • Align the terminal block with the outline labeled INPUT on the front of the board, with the terminal interface facing outwards.
    • Insert the block's two pins into their holes in the board.
  35. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the terminal block: passo 35, immagine 1 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the terminal block: passo 35, immagine 2 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the terminal block: passo 35, immagine 3 di 3
    • Flip the board over so the terminal block's pins are facing up.
    • Solder the terminal block to the board.
  36. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Insert the first adjustable resistor: passo 36, immagine 1 di 2 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Insert the first adjustable resistor: passo 36, immagine 2 di 2
    • Align the first adjustable resistor (labeled W204 on the top) with the outline labeled RP1 on the front of the board. The gold knob should be closest to the microcontroller.
    • The adjustable resistors are not symmetrical. The protruding edges and adjustable knob need to be aligned with their respective outline.
    • Insert the resistor's three pins into their holes in the board.
  37. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the first adjustable resistor: passo 37, immagine 1 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the first adjustable resistor: passo 37, immagine 2 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the first adjustable resistor: passo 37, immagine 3 di 3
    • Flip the board over so the resistor's pins are facing up.
    • Solder the first adjustable resistor to the board.
  38. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Insert the second adjustable resistor: passo 38, immagine 1 di 2 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Insert the second adjustable resistor: passo 38, immagine 2 di 2
    • Align the second adjustable resistor (labeled W501 on the top) with the outline labeled RP2 on the front of the board. The gold knob should be closest to the microcontroller.
  39. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the second adjustable resistor: passo 39, immagine 1 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the second adjustable resistor: passo 39, immagine 2 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the second adjustable resistor: passo 39, immagine 3 di 3
    • Solder the second adjustable resistor to the board.
  40. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Insert the encoder knob: passo 40, immagine 1 di 2 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Insert the encoder knob: passo 40, immagine 2 di 2
    • Align the encoder knob with the outline labeled EC11 on the front of the board. Orient it so the three leads at the top correspond with the three holes on the board under the MiNi-DSO label.
    • Insert the encoder's seven pins into their holes in the board.
  41. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the encoder knob: passo 41, immagine 1 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the encoder knob: passo 41, immagine 2 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the encoder knob: passo 41, immagine 3 di 3
    • Flip the board over so the encoder's pins are facing up.
    • Solder the encoder knob to the board.
  42. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Insert the male display connector: passo 42, immagine 1 di 2 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Insert the male display connector: passo 42, immagine 2 di 2
    • In this step, you'll be soldering the male display connector onto the display board.
    • Align the male OLED display connector into the outline on the back of the display board. The shorter pins should be facing the board.
    • Insert the connector's seven shorter pins into their holes in the board.
  43. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the male display connector: passo 43, immagine 1 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the male display connector: passo 43, immagine 2 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Solder the male display connector: passo 43, immagine 3 di 3
    • Flip the display board over so the connector's leads are facing up.
    • Solder the OLED display connector to the display board.
  44. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Install the display: passo 44, immagine 1 di 2 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Install the display: passo 44, immagine 2 di 2
    • Align the display's male pins with its female connector on the front of the board, so the display itself is over the microcontroller.
    • Push the pins fully into the connector.
  45. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Test your oscilloscope: passo 45, immagine 1 di 2 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Test your oscilloscope: passo 45, immagine 2 di 2
    • Before connecting the oscilloscope to power, visually inspect your work to make sure there are no bridged or incomplete solder joints to avoid damaging components.
    • Only the two pads labeled BAT should be empty.
    • Connect the oscilloscope to a power source with the included Micro USB cable.
  46. Mini Digital Oscilloscope DIY Soldering Kit Assembly: passo 46, immagine 1 di 2 Mini Digital Oscilloscope DIY Soldering Kit Assembly: passo 46, immagine 2 di 2
    • If your toggle switch is off, slide it to the ON position to power up your oscilloscope. You should see the display turn on and show "MiniDSO" at the top.
    • If the oscilloscope doesn't power on, check your joints to make sure none are bridged, damaged, or incomplete.
  47. Mini Digital Oscilloscope DIY Soldering Kit Assembly: passo 47, immagine 1 di 2 Mini Digital Oscilloscope DIY Soldering Kit Assembly: passo 47, immagine 2 di 2
    • Once the oscilloscope boots up, you should see a screen with a graph. Rotate the encoder knob to test its functionality.
    • Turn off the oscilloscope and unplug its USB cable once you've verified its functionality.
  48. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Trim the leads: passo 48, immagine 1 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Trim the leads: passo 48, immagine 2 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Trim the leads: passo 48, immagine 3 di 3
    • Use your flush cutters to trim the test ring leads until they're no longer poking up past the solder joint from the back of the board.
  49. Mini Digital Oscilloscope DIY Soldering Kit Assembly: passo 49, immagine 1 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly: passo 49, immagine 2 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly: passo 49, immagine 3 di 3
    • Repeat the last step to trim all the leads until they're no longer poking up past their solder joint from the back of the board.
  50. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Clean the board: passo 50, immagine 1 di 2 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Clean the board: passo 50, immagine 2 di 2
    • This is a great time to clean up any residue left from the solder. Apply some isopropyl alcohol to the solder joints and wipe with a lint-free cloth to soak up the flux and alcohol residue.
  51. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Case components: passo 51, immagine 1 di 1
    • The remaining steps show how to assemble the oscilloscope's case.
    • The case contains the following parts:
    • 1x Bottom acrylic
    • 1x Top acrylic
    • 4x 11 mm screws
    • 4x 7 mm screws
    • 4x Nuts
    • 4x Standoff posts
  52. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Remove the acrylic film: passo 52, immagine 1 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Remove the acrylic film: passo 52, immagine 2 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Remove the acrylic film: passo 52, immagine 3 di 3
    • Use your fingernail or tweezers to peel up an edge of the bottom acrylic's protective film and peel it off.
    • Repeat this process for the film on the other side.
  53. Mini Digital Oscilloscope DIY Soldering Kit Assembly: passo 53, immagine 1 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly: passo 53, immagine 2 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly: passo 53, immagine 3 di 3
    • Repeat the previous step to remove the top acrylic's protective films.
  54. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Install the screws: passo 54, immagine 1 di 2 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Install the screws: passo 54, immagine 2 di 2
    • Insert one of the 11 mm screws into a hole in the bottom acrylic.
  55. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Install the nuts: passo 55, immagine 1 di 2 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Install the nuts: passo 55, immagine 2 di 2
    • Thread one of the nuts onto the screw until it's finger-tight.
    • Don't use tools to tighten the nut to avoid damaging the acrylic.
    • You can hold the screw with your finger or a screwdriver while tightening to ensure a snug fit.
  56. Mini Digital Oscilloscope DIY Soldering Kit Assembly: passo 56, immagine 1 di 1
    • Repeat this process for the remaining three holes in the bottom acrylic.
  57. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Install the bottom case: passo 57, immagine 1 di 2 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Install the bottom case: passo 57, immagine 2 di 2
    • Align the circuit board's four corner holes with the screws protruding from the bottom acrylic. Orient the board so the back is facing the bottom acrylic.
    • Insert the four screws through their holes until the board sits flush with the nuts on the bottom case.
  58. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Install the stand-offs: passo 58, immagine 1 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Install the stand-offs: passo 58, immagine 2 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Install the stand-offs: passo 58, immagine 3 di 3
    • Thread one of the standoff posts onto a screw protruding from the board until it's finger-tight against the board.
    • Don't use additional tools to tighten the standoff posts to avoid damaging the board.
    • Repeat this process for the other three standoff posts & screws.
  59. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Remove the display film: passo 59, immagine 1 di 2 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Remove the display film: passo 59, immagine 2 di 2
    • Grab the plastic pull tab on the OLED display's protective film and peel it off.
  60. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Align the top case: passo 60, immagine 1 di 1
    • Align the top acrylic with the four standoff posts' screw holes, the adjustable resistor knobs, and the terminal block screws.
  61. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Attach the top case: passo 61, immagine 1 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Attach the top case: passo 61, immagine 2 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Attach the top case: passo 61, immagine 3 di 3
    • Use a screwdriver to screw one of the 7 mm screws into a standoff post until it's roughly finger-tight.
    • Screw the last three screws into the remaining standoff posts.
  62. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Install the knob cover: passo 62, immagine 1 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Install the knob cover: passo 62, immagine 2 di 3 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Install the knob cover: passo 62, immagine 3 di 3
    • Align the hole in the bottom of the knob cover with the encoder knob.
    • Insert the knob cover onto the encoder knob and push it down until it bottoms out.
  63. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Connect the USB cable: passo 63, immagine 1 di 2 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Connect the USB cable: passo 63, immagine 2 di 2
    • Reconnect the Micro USB cable to the oscilloscope.
  64. Mini Digital Oscilloscope DIY Soldering Kit Assembly, Turn on the oscilloscope: passo 64, immagine 1 di 2 Mini Digital Oscilloscope DIY Soldering Kit Assembly, Turn on the oscilloscope: passo 64, immagine 2 di 2
    • Congratulations! You now have a functioning mini oscilloscope.
    • Toggle the switch to the ON position to power up your oscilloscope.
Conclusione
You've taken a great step toward mastering the valuable and versatile skill of surface-mount and through-hole soldering. With this kit under your belt, you're well-equipped to tackle various electronics projects and repairs. Remember, practice makes perfect, so don't hesitate to experiment and refine your techniques.
To learn more soldering skills, click here.
If you need additional help, check out our Answers community.
Altre 13 persone hanno completato questa guida.
Nick Schultz
Membro da: 03/24/24
37.772 Reputazione
226 Guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
23.781 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 18
Ultimi 7 Giorni: 96
Ultimi 30 Giorni: 353
Tutti i Tempi: 5,430
