Salta al contenuto principale
Microsoft Surface Pro 8 Kickstand Replacement
Cosa ti serve
    1. Microsoft Surface Pro 8 Kickstand Replacement, Before you begin: passo 1, immagine 1 di 1
      • Before starting your repair, unplug all cables and fully shut down your Surface Pro.
      Chiedi a FixBot
      Aggiungi Commento
    1. Microsoft Surface Pro 8 Kickstand Replacement, Open the kickstand: passo 2, immagine 1 di 2 Microsoft Surface Pro 8 Kickstand Replacement, Open the kickstand: passo 2, immagine 2 di 2
      • Open the kickstand to about 90 degrees.
      Chiedi a FixBot
      Aggiungi Commento
    1. Microsoft Surface Pro 8 Kickstand Replacement, Remove the hinge screws: passo 3, immagine 1 di 3 Microsoft Surface Pro 8 Kickstand Replacement, Remove the hinge screws: passo 3, immagine 2 di 3 Microsoft Surface Pro 8 Kickstand Replacement, Remove the hinge screws: passo 3, immagine 3 di 3
      • While holding the kickstand behind the hinge with your finger, use a Torx Plus 3IP screwdriver to remove the 2.4 mm‑long screw from each hinge (two total).
      Chiedi a FixBot
      Aggiungi Commento
    2. Microsoft Surface Pro 8 Kickstand Replacement, Lower the kickstand: passo 4, immagine 1 di 2 Microsoft Surface Pro 8 Kickstand Replacement, Lower the kickstand: passo 4, immagine 2 di 2
      • Firmly grip the hinges and kickstand between your thumb and index fingers.
      • Lower the kickstand down to about 45 degrees.
      • This may take a bit of force. Be careful not to pinch your thumbs.
      Chiedi a FixBot
      Aggiungi Commento
    3. Microsoft Surface Pro 8 Kickstand Replacement, Unlatch the hinges: passo 5, immagine 1 di 3 Microsoft Surface Pro 8 Kickstand Replacement, Unlatch the hinges: passo 5, immagine 2 di 3 Microsoft Surface Pro 8 Kickstand Replacement, Unlatch the hinges: passo 5, immagine 3 di 3
      • The hinges slot into recesses on the kickstand. You need to slide the kickstand out of the hinges before you can fully remove it.
      • Firmly secure the device to your work surface with one hand.
      • With your free hand, pull the kickstand out slightly and rotate it up so both hinges slide out.
      • During reassembly, make sure both hinges slide fully into their recesses on the kickstand.
      Chiedi a FixBot
      Aggiungi Commento
    4. Microsoft Surface Pro 8 Kickstand Replacement, Remove the kickstand: passo 6, immagine 1 di 2 Microsoft Surface Pro 8 Kickstand Replacement, Remove the kickstand: passo 6, immagine 2 di 2
      • Pull the kickstand out until both foam tabs slide out.
      • If you're having trouble, make sure both hinges are fully out of their recesses on the kickstand.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Spencer Day
Membro da: 09/14/22
197.796 Reputazione
1.243 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 15
Ultimi 30 giorni: 89
Tutti i Tempi: 219
