Salta al contenuto principale
Microsoft Surface Pro 7 Kickstand Replacement
Cosa ti serve
  1. Microsoft Surface Pro 7 Kickstand Replacement, Open the kickstand: passo 1, immagine 1 di 3 Microsoft Surface Pro 7 Kickstand Replacement, Open the kickstand: passo 1, immagine 2 di 3 Microsoft Surface Pro 7 Kickstand Replacement, Open the kickstand: passo 1, immagine 3 di 3
    • Lift the kickstand to expose the hinge screws.
  2. Microsoft Surface Pro 7 Kickstand Replacement, Remove the kickstand screws: passo 2, immagine 1 di 2 Microsoft Surface Pro 7 Kickstand Replacement, Remove the kickstand screws: passo 2, immagine 2 di 2
    • Remove the four 2.7 mm T3 screws—two on each side of the kickstand.
  3. Microsoft Surface Pro 7 Kickstand Replacement, Close the kickstand: passo 3, immagine 1 di 3 Microsoft Surface Pro 7 Kickstand Replacement, Close the kickstand: passo 3, immagine 2 di 3 Microsoft Surface Pro 7 Kickstand Replacement, Close the kickstand: passo 3, immagine 3 di 3
    • Move the kickstand back down to a flat position.
    • The hinges are stiff and you may need to use some force to get it down.
  4. Microsoft Surface Pro 7 Kickstand Replacement, Remove the kickstand: passo 4, immagine 1 di 3 Microsoft Surface Pro 7 Kickstand Replacement, Remove the kickstand: passo 4, immagine 2 di 3 Microsoft Surface Pro 7 Kickstand Replacement, Remove the kickstand: passo 4, immagine 3 di 3
    • Remove the kickstand from the back cover.
    • There are two adhesive tabs in the middle of the kickstand that disengage most easily when the kickstand is pulled directly downward from the device.
    • Be sure to insert these tabs when reinstalling the new kickstand before replacing the screws.
Conclusione
Sam Omiotek
Membro da: 02/25/19
76.055 Reputazione
288 Guide realizzate
2 Commenti
One of the hinges broke on my Surface Pro 6.
1. I removed the broken hinge, closed the kickstand and duct taped the seam.
2. I opened the kickstand wide and duct taped the seam.
The single hinge and duct tape seem to be working!
"Spare the duct tape, spoil the job." - Red Green
P Best - Replica
What are the parts used for this fix?
Andrea Shaw - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 42
Ultimi 30 Giorni: 202
Tutti i Tempi: 7,051
