Introduzione
Use this guide to remove or replace the Surface Connect port/charging port in your Microsoft Surface Laptop 4 (15-inch).
If your battery is swollen, take appropriate precautions.
Some photos in this guide are from a different model and may contain slight visual discrepancies, but they won't affect the guide procedure.
Cosa ti serve
Unplug all cables and fully shut down your laptop.
Close the screen and lay your laptop down with the rear case facing up to access the four rubber feet.
The back feet recesses are closest to the back edge of the laptop.
The front feet recesses are closest to the front edge of the laptop.
Attrezzo utilizzato in questo passaggio:Tesa 61395 Tape$5.99
The rear feet have a single center clip.
The front feet have three clips and can only be reinserted one way.
If the existing feet no longer adhere to the frame, remove the old adhesive and apply a small amount of Tesa Tape where the old adhesive was.
Attrezzo utilizzato in questo passaggio:FixMat$36.95
Use a T5 Torx driver to remove the four 3 mm screws securing the upper case.
Grip the top edge of the upper case above the keyboard and lift straight up to release it.
Lift the bottom edge of the upper case up and away from the laptop, taking care to not strain the ribbon cable underneath.
Insert the pointed end of a spudger under one edge of the magnet connector and pry up to disconnect it.
Remove the upper case and set it keyboard-side down on a clean surface.
Use a T5 Torx driver to remove the 2.7 mm screw securing the SSD.
Use the flat end of spudger to flip open the gold locking arm on the Surface Connect port motherboard connector.
Grip the Surface Connect port cable and pull it away from its connector to disconnect it.
Use a T3 Torx driver to remove the four screws securing the Surface Connect port cover:
Two 2.0 mm screws
Two 2.2 mm screws
Use a T3 Torx driver to remove the two 3 mm screws securing the Surface Connect port.
Pull the Surface Connect port away from the edge of the chassis and remove it.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting or check out our Answers community for help.
