Salta al contenuto principale
Merch Source Projector Entertainment II Motherboard
Cosa ti serve
  1. Merch Source Projector Entertainment II Motherboard, Outer Casing: passo 1, immagine 1 di 2 Merch Source Projector Entertainment II Motherboard, Outer Casing: passo 1, immagine 2 di 2
    • Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
    Chiedi a FixBot
    Aggiungi Commento
  2. Merch Source Projector Entertainment II Motherboard: passo 2, immagine 1 di 1
    • Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
    • The bottom right panel screw does not come completely out the panel door.
    Chiedi a FixBot
    Aggiungi Commento
  3. Merch Source Projector Entertainment II Motherboard: passo 3, immagine 1 di 2 Merch Source Projector Entertainment II Motherboard: passo 3, immagine 2 di 2
    • Using your hands, gently pry the top and bottom of the projector casing apart.
    Chiedi a FixBot
    Aggiungi Commento
  4. Merch Source Projector Entertainment II Motherboard, Motherboard: passo 4, immagine 1 di 2 Merch Source Projector Entertainment II Motherboard, Motherboard: passo 4, immagine 2 di 2
    • Use the plastic opening tool to gently disengage the ribbon cable from its back housing.
    • Once the ribbon cable is disengaged gently pull the cable off the motherboard.
    • Once the housing is disengaged, the ribbon cable should slide out easy. Do not pull too hard on the ribbon cable as it is very fragile.
    Chiedi a FixBot
    Aggiungi Commento
  5. Merch Source Projector Entertainment II Motherboard: passo 5, immagine 1 di 2 Merch Source Projector Entertainment II Motherboard: passo 5, immagine 2 di 2
    • Unscrew the three 6 mm screws from the motherboard with the Phillips #0 screwdriver.
    • Be sure not to damage any of the wires atached to the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  6. Merch Source Projector Entertainment II Motherboard: passo 6, immagine 1 di 2 Merch Source Projector Entertainment II Motherboard: passo 6, immagine 2 di 2
    • Solder off all of the connections on the motherboard with a soldering iron.
    • Once connections are soldered off, the motherboard should be detached and ready for replacement.
    • Need some help? Follow this guide to learn soldering basics.
    • While soldering the metal connections can get very hot. Never touch the iron with your hand. also make sure that the projector is fully turned off and not plugged in.
    • If there is hot glue on top on the connection with the motherboard, you will need to peel it off using your fingers.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Michael Tan
Membro da: 01/08/15
590 Reputazione
3 guide realizzate
3Commenti sulla guida
Was wondering if you could help me identify a microchip on the board by the speaker?
Brad Langland - Rispondi Condividi
Where can I get parts for the projector? I think my board is cooked.
Delgtm - Rispondi Condividi
mine acts like it does not recognize the rca cords. help
Kamela Mitchell - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 25
Tutti i Tempi: 2,371
