Salta al contenuto principale
Merch Source Projector Entertainment II Cooling Fan Replacement
Cosa ti serve
  1. Merch Source Projector Entertainment II Cooling Fan Replacement, Outer Casing: passo 1, immagine 1 di 2 Merch Source Projector Entertainment II Cooling Fan Replacement, Outer Casing: passo 1, immagine 2 di 2
    • Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
    Chiedi a FixBot
    Aggiungi Commento
  2. Merch Source Projector Entertainment II Cooling Fan Replacement: passo 2, immagine 1 di 1
    • Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
    • The bottom right panel screw does not come completely out the panel door.
    Chiedi a FixBot
    Aggiungi Commento
  3. Merch Source Projector Entertainment II Cooling Fan Replacement: passo 3, immagine 1 di 2 Merch Source Projector Entertainment II Cooling Fan Replacement: passo 3, immagine 2 di 2
    • Using your hands, gently pry the top and bottom of the projector casing apart.
    Chiedi a FixBot
    Aggiungi Commento
  4. Merch Source Projector Entertainment II Cooling Fan Replacement, Cooling Fan: passo 4, immagine 1 di 2 Merch Source Projector Entertainment II Cooling Fan Replacement, Cooling Fan: passo 4, immagine 2 di 2
    • Locate the 80 mm fan and slide upward straight out of the housing.
    Chiedi a FixBot
    Aggiungi Commento
  5. Merch Source Projector Entertainment II Cooling Fan Replacement: passo 5, immagine 1 di 2 Merch Source Projector Entertainment II Cooling Fan Replacement: passo 5, immagine 2 di 2
    • Unsolder the red and black connections off of the motherboard.
    • If there are zip ties around the cables, they will need to be cut to remove the fan.
    • Need some help? Follow this guide to learn soldering basics.
    • While soldering the metal connections will get very hot. Never touch the iron with your hand.
    • Make sure that the projector is fully turned off and not plugged in. Allow up to 30 minutes for projector to cool down.
    • If there is hot glue within the connection in on the motherboard, you will need to peel it off simply using your fingers.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Stephanie
Membro da: 01/08/15
282 Reputazione
3 guide realizzate
Cal Poly, Team 18-3, Maness Winter 2015 Membro di Cal Poly, Team 18-3, Maness Winter 2015
CPSU-MANESS-W15S18G3
3 Membri
4 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 24
Tutti i Tempi: 2,799
