Salta al contenuto principale
Marshall Stanmore II Tweeter Assembly Replacement
Cosa ti serve
  1. Marshall Stanmore II Tweeter Assembly Replacement, Rear Panel: passo 1, immagine 1 di 2 Marshall Stanmore II Tweeter Assembly Replacement, Rear Panel: passo 1, immagine 2 di 2
    • Turn off the device and unplug the cable from the wall and the speaker.
    • Lay the speaker with the back panel facing up on a flat, stable work surface.
    Chiedi a FixBot
    Aggiungi Commento
  2. Marshall Stanmore II Tweeter Assembly Replacement: passo 2, immagine 1 di 2 Marshall Stanmore II Tweeter Assembly Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #2 screwdriver to remove the ten 20.5 mm screws that secure the rear panel to the chassis.
    Chiedi a FixBot
    Aggiungi Commento
  3. Marshall Stanmore II Tweeter Assembly Replacement: passo 3, immagine 1 di 2 Marshall Stanmore II Tweeter Assembly Replacement: passo 3, immagine 2 di 2
    • Carefully lift the rear panel and let it rest on an object, like a stack of books, to avoid straining the cables.
    • Do not attempt to fully remove the panel, as this will damage the connections inside.
    Chiedi a FixBot
    Aggiungi Commento
  4. Marshall Stanmore II Tweeter Assembly Replacement, Tweeter Assembly: passo 4, immagine 1 di 2 Marshall Stanmore II Tweeter Assembly Replacement, Tweeter Assembly: passo 4, immagine 2 di 2
    • Carefully pull back the translucent plastic sheathing on the two silver tweeter connectors.
    Chiedi a FixBot
    Aggiungi Commento
  5. Marshall Stanmore II Tweeter Assembly Replacement: passo 5, immagine 1 di 3 Marshall Stanmore II Tweeter Assembly Replacement: passo 5, immagine 2 di 3 Marshall Stanmore II Tweeter Assembly Replacement: passo 5, immagine 3 di 3
    • Using your fingernail or tweezers, apply precise pressure to the small latch in the middle of the connector and gently pull upwards to disconnect the connector.
    • Repeat for the second connector.
    Chiedi a FixBot
    Aggiungi Commento
  6. Marshall Stanmore II Tweeter Assembly Replacement: passo 6, immagine 1 di 2 Marshall Stanmore II Tweeter Assembly Replacement: passo 6, immagine 2 di 2
    • Use a Torx T20 screwdriver to remove the three 20.5 mm screws that secure the tweeter.
    • Lift the tweeter assembly from its housing.
    Chiedi a FixBot
    Aggiungi Commento
  7. Marshall Stanmore II Tweeter Assembly Replacement: passo 7, immagine 1 di 1
    • The felt seal is removable. If there is no seal on the tweeter, it may be stuck to the cutout on the speaker frame.
    • Repeat steps 4-6 to remove the second tweeter if necessary.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
1Commento della guida
Do you know the tweeter spec? Or similar brand to install?
Leonardo Hernández - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 8
Ultimi 30 giorni: 36
Tutti i Tempi: 805
