Salta al contenuto principale
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Magic Trackpad, usa il nostro manuale di assistenza.
  1. Magic Trackpad Teardown, Magic Trackpad Teardown: passo 1, immagine 1 di 3 Magic Trackpad Teardown, Magic Trackpad Teardown: passo 1, immagine 2 di 3 Magic Trackpad Teardown, Magic Trackpad Teardown: passo 1, immagine 3 di 3
    • The Magic Trackpad is the first full desktop trackpad that supports a full set of gestures, including click, scroll, swipe, and rotate, all available at the tip of your fingers.
    • Requirements:
    • Mac desktop or laptop.
    • Bluetooth connectivity.
    • Mac OS X 10.6.4 or later.
    • And of course, batteries! (Apple Battery Charger not included).
    • As the rumors confirmed, the Magic Trackpad is designated Model A1339.
    Chiedi a FixBot
    Aggiungi Commento
  2. Magic Trackpad Teardown: passo 2, immagine 1 di 3 Magic Trackpad Teardown: passo 2, immagine 2 di 3 Magic Trackpad Teardown: passo 2, immagine 3 di 3
    • The Magic Trackpad is 80% larger than the trackpad included in current MacBook Pro models.
    • It features the same aluminum design as its wireless keyboard counterpart, allowing for the perfect union of typing and gestures.
    • Let us not forget the main attraction, which is the 0.5 mm thick, capacitive touch, wear-resistant glass surface.
    • That's all good, but what lies inside?
    Chiedi a FixBot
    Aggiungi Commento
  3. Magic Trackpad Teardown: passo 3, immagine 1 di 3 Magic Trackpad Teardown: passo 3, immagine 2 di 3 Magic Trackpad Teardown: passo 3, immagine 3 di 3
    • Removing the batteries is about as straightforward as it can get. Give a twist to the battery door and the two AA batteries slide right out.
    • Check out those square threads! While square threads have the highest mechanical efficiency of all lead screws, their difficulty of manufacturing makes them prohibitive for most applications.
    • Kudos, Apple, for sweating the details.
    Chiedi a FixBot
    Aggiungi Commento
  4. Magic Trackpad Teardown: passo 4, immagine 1 di 3 Magic Trackpad Teardown: passo 4, immagine 2 di 3 Magic Trackpad Teardown: passo 4, immagine 3 di 3
    • Time to get our hands dirty!
    • Use a plastic opening tool to pry the lower panel away from the adhesive securing around its left, right, and top edges.
    • Don't pry up along the bottom. There are a bunch of retaining clips.
    • After slicing through most of the adhesive, the lower panel lifts right off.
    Chiedi a FixBot
    Aggiungi Commento
  5. Magic Trackpad Teardown: passo 5, immagine 1 di 3 Magic Trackpad Teardown: passo 5, immagine 2 di 3 Magic Trackpad Teardown: passo 5, immagine 3 di 3
    • And there's......not really that much to this thing.
    • After a good amount of quasi-non-destructive prying, the inner spacer can be removed from the trackpad.
    • This spacer prevents the highly unlikely event of squeezing the lower panel against the logic board hard enough to damage it.
    Chiedi a FixBot
    Aggiungi Commento
  6. Magic Trackpad Teardown: passo 6, immagine 1 di 3 Magic Trackpad Teardown: passo 6, immagine 2 di 3 Magic Trackpad Teardown: passo 6, immagine 3 di 3
    • Next, disconnect the two ribbon cables connecting the capacitive touch pad to the logic board.
    • These things are ridiculously thin and are stuck to the underside of the touch pad. If you plan to remove them, proceed with caution.
    Chiedi a FixBot
    Aggiungi Commento
  7. Magic Trackpad Teardown: passo 7, immagine 1 di 2 Magic Trackpad Teardown: passo 7, immagine 2 di 2
    • We've noticed a trend about Apple's newer products: thin and pretty = not user serviceable. The Magic Trackpad is no exception.
    • After using a heat gun to warm up the adhesive, the touch pad can be carefully pried off the aluminum chassis.
    • This is not for the faint of heart. A copious amount of heat, guitar picks, and plastic opening tools were required to make this thing budge.
    Chiedi a FixBot
    Aggiungi Commento
  8. Magic Trackpad Teardown: passo 8, immagine 1 di 2 Magic Trackpad Teardown: passo 8, immagine 2 di 2
    • After being freed from the adhesive securing it to the chassis, the touch pad can be easily removed.
    • The Magic Trackpad has a unique way of triggering the mouse button. As you press down on the top surface of the Trackpad, the two rubber feet near its front edge push up on the hinged plate and set screw (shown in orange) attached to the chassis. This squeezes the electronic mouse button switch (shown in red), producing the characteristic "click".
    Chiedi a FixBot
    Aggiungi Commento
  9. Magic Trackpad Teardown: passo 9, immagine 1 di 2 Magic Trackpad Teardown: passo 9, immagine 2 di 2
    • To completely remove the logic board, you must first de-solder the four wires leading to the battery connector/status LED.
    • After removing two Phillips screws, the logic board can be separated from the chassis.
    Chiedi a FixBot
    Aggiungi Commento
  10. Magic Trackpad Teardown: passo 10, immagine 1 di 2 Magic Trackpad Teardown: passo 10, immagine 2 di 2
    • At the heart of the Magic Trackpad's logic board lies a Broadcom BCM2042 for Bluetooth connectivity.
    • This is the same chip used by the Magic Mouse for data transmission.
    • We found a Broadcom BCM5974 touch screen controller chip that provides Multi-touch functionality.
    • This is the same chip you'll find in the iPhone, iPod Touch, and MacBook Air.
    • Also, an SST 25WF020 provides 2 Mbit of serial flash memory.
    • This appears to be a TI CD3238, which has been identified by Hearst as a RS232 line driver/receiver. It was also in the original iPhone with a BCM5973A.
    • The back of the logic board features nothing but blackness and glue.
    Chiedi a FixBot
    Aggiungi Commento
  11. Magic Trackpad Teardown: passo 11, immagine 1 di 1
    • And there it lies: the Magic Trackpad in nine difficult-to-disassemble pieces.
    • Keep an eye on our teardown page for an inside look at the latest gadgets!
    Chiedi a FixBot
    Aggiungi Commento
23Commenti sulla guida
A great tear down. One question: Where is the bluetooth antenna? Is it just etched into the circuit board?
Doug - Rispondi Condividi
Good question. It looks like the curved traces along the top of the board seen on step 10 could be the antenna, and they lead to a small metal pressure contact that mates into the aluminum chassis. My guess is that the chassis of the trackpad and/or those curved traces serve as the antenna.
Andrew Bookholt - Rispondi Condividi
Step 3c, I was expecting to see an Apple-branded battery instead of a bunny-battery. When you get the Apple batteries, is there any reason to tear one of those apart to see if Apple is merely re-labeling someone else's battery or if they actually are building AA batteries?
plink53 - Rispondi Condividi
Apple does not produce batteries, as much as they don’t produce LCD panels or SoC chips - at best, they design them or define specs, but mostly just source it from suppliers, such as Samsung (and SDI), LG and Desay. It makes no financial sense to be a one stop shop - and that’s why Trump’s Nevo-mercantilism is a sure fail. Sorry about the politics - it’s a *charged* topic lolz ;)
Idan - Rispondi Condividi
Step 10, "2Mbit of serial flash memory" This means this device might be capable of storing/receiving data from the attached computer. It will be something we get to investigate to see what type of data it holds to see how it has to be treated in a government setting.
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 34
Ultimi 30 giorni: 221
Tutti i Tempi: 266,239
