Salta al contenuto principale
MacBook Air 2022 (M2) Left Speaker Replacement
Cosa ti serve
  1. MacBook Air 2022 (M2) Left Speaker Replacement, Prepare your Macbook Air for disassembly: passo 1, immagine 1 di 3 MacBook Air 2022 (M2) Left Speaker Replacement, Prepare your Macbook Air for disassembly: passo 1, immagine 2 di 3 MacBook Air 2022 (M2) Left Speaker Replacement, Prepare your Macbook Air for disassembly: passo 1, immagine 3 di 3
    • Before you begin, discharge your battery below 25%, as a charged lithium-ion battery can be dangerous if accidentally punctured.
    • Power off your MacBook Air and unplug all cables.
    • Close the display and flip the laptop upside down. Keep the lid closed until you've physically disconnected the battery.
  2. MacBook Air 2022 (M2) Left Speaker Replacement, Unfasten the lower case: passo 2, immagine 1 di 2 MacBook Air 2022 (M2) Left Speaker Replacement, Unfasten the lower case: passo 2, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    FixMat
    $31.41
    • Use a P5 Pentalobe driver to remove the four 6.4 mm screws securing the lower case:
    • Two screws with a short threaded portion near the hinges
    • Two screws with a long threaded portion near the front of the MacBook
  3. MacBook Air 2022 (M2) Left Speaker Replacement, Insert an opening pick: passo 3, immagine 1 di 3 MacBook Air 2022 (M2) Left Speaker Replacement, Insert an opening pick: passo 3, immagine 2 di 3 MacBook Air 2022 (M2) Left Speaker Replacement, Insert an opening pick: passo 3, immagine 3 di 3
    • Apply a suction handle to the center of the lower case's front edge.
    • Pull up on the suction handle with strong, steady force to create a small gap between the lower case and the frame.
    • Insert an opening pick into the gap.
  4. MacBook Air 2022 (M2) Left Speaker Replacement, Release the snapping clips: passo 4, immagine 1 di 3 MacBook Air 2022 (M2) Left Speaker Replacement, Release the snapping clips: passo 4, immagine 2 di 3 MacBook Air 2022 (M2) Left Speaker Replacement, Release the snapping clips: passo 4, immagine 3 di 3
    • During the next two steps you'll feel and hear four snapping clips release. If a clip doesn't release, insert your opening pick farther and try again.
    • Slide the pick to the bottom right corner to release the first clip.
    • Slide the pick around the corner and up the right edge to release the next clip.
  5. MacBook Air 2022 (M2) Left Speaker Replacement: passo 5, immagine 1 di 3 MacBook Air 2022 (M2) Left Speaker Replacement: passo 5, immagine 2 di 3 MacBook Air 2022 (M2) Left Speaker Replacement: passo 5, immagine 3 di 3
    • Insert the opening pick in the original gap created with the suction handle.
    • Slide the opening pick to the bottom left corner and up the left edge to release the two remaining snapping clips.
  6. MacBook Air 2022 (M2) Left Speaker Replacement, Release the sliding tabs: passo 6, immagine 1 di 3 MacBook Air 2022 (M2) Left Speaker Replacement, Release the sliding tabs: passo 6, immagine 2 di 3 MacBook Air 2022 (M2) Left Speaker Replacement, Release the sliding tabs: passo 6, immagine 3 di 3
    • Four sliding tabs along the back edge of the MacBook firmly secure the lower case. Separating these tabs requires a lot of force—consider using gloves to protect your hands from the sharp edges of the lower case.
    • Keep the lower case flat and firmly pull it straight away from the back edge, one corner at a time, to disengage the sliding tabs.
    • Don't pull up until the cover is completely separated.
  7. MacBook Air 2022 (M2) Left Speaker Replacement, Remove the lower case: passo 7, immagine 1 di 3 MacBook Air 2022 (M2) Left Speaker Replacement, Remove the lower case: passo 7, immagine 2 di 3 MacBook Air 2022 (M2) Left Speaker Replacement, Remove the lower case: passo 7, immagine 3 di 3
    • Remove the lower case.
    • During reassembly:
    • Set the lower case in place and align the sliding tabs with the screw heads they slide over. Press down and slide the lower case toward the back edge to engage the tabs—it'll stop sliding as the tabs engage.
    • When one side is engaged, it may push the other out of alignment. Check both sides as you push, there should be no gap along the back edge.
    • Once the lower case is flush with the frame, press down firmly along the perimeter to engage the four snapping clips.
    • You'll hear and feel a distinct click as each clip snaps into place.
  8. MacBook Air 2022 (M2) Left Speaker Replacement, Remove the battery connector cover: passo 8, immagine 1 di 1
    • Use a T3 Torx driver to remove the two 1.5 mm screws securing the battery connector cover.
  9. MacBook Air 2022 (M2) Left Speaker Replacement: passo 9, immagine 1 di 2 MacBook Air 2022 (M2) Left Speaker Replacement: passo 9, immagine 2 di 2
    • Remove the battery connector cover.
  10. MacBook Air 2022 (M2) Left Speaker Replacement, Disconnect the battery: passo 10, immagine 1 di 2 MacBook Air 2022 (M2) Left Speaker Replacement, Disconnect the battery: passo 10, immagine 2 di 2
    • Use an opening pick to pry up and disconnect the battery press connector.
    • To reconnect a press connector, align it over the socket and gently press down on one side until it clicks into place, then press down on the other side. It might take a few tries to align the connector.
  11. MacBook Air 2022 (M2) Left Speaker Replacement, Unfasten the speaker cable covers: passo 11, immagine 1 di 1
    • The left speaker will be on your right-hand side when working on the MacBook, as it's laying upside down.
    • Use a T3 Torx driver to remove the four 1.5 mm screws securing the left speaker cable covers.
  12. MacBook Air 2022 (M2) Left Speaker Replacement, Remove the speaker cable covers: passo 12, immagine 1 di 3 MacBook Air 2022 (M2) Left Speaker Replacement, Remove the speaker cable covers: passo 12, immagine 2 di 3 MacBook Air 2022 (M2) Left Speaker Replacement, Remove the speaker cable covers: passo 12, immagine 3 di 3
    • Remove the two speaker cable covers.
  13. MacBook Air 2022 (M2) Left Speaker Replacement, Disconnect the speaker cables: passo 13, immagine 1 di 2 MacBook Air 2022 (M2) Left Speaker Replacement, Disconnect the speaker cables: passo 13, immagine 2 di 2
    • Use the pointed end of a spudger to pry up and disconnect the left speaker press connector.
  14. MacBook Air 2022 (M2) Left Speaker Replacement: passo 14, immagine 1 di 2 MacBook Air 2022 (M2) Left Speaker Replacement: passo 14, immagine 2 di 2
    • Use a pair of tweezers to grip the right antenna connector, as close to its base as possible.
    • Lift straight up to disconnect the cable.
    • The antenna connectors on the logic board are very fragile. When disconnecting the cables, pull straight up—don’t bend them to the side.
    • To reattach antenna connectors like these, align the connector over its socket and press down with the flat end of a spudger. The connector should snap into place. This can be tricky and may take a few tries.
  15. MacBook Air 2022 (M2) Left Speaker Replacement, Unfasten the right hinge cover: passo 15, immagine 1 di 1
    • Use a 3IP Torx Plus driver to remove the 2.6 mm screw securing the right hinge cover.
  16. MacBook Air 2022 (M2) Left Speaker Replacement, Remove the right hinge cover: passo 16, immagine 1 di 3 MacBook Air 2022 (M2) Left Speaker Replacement, Remove the right hinge cover: passo 16, immagine 2 di 3 MacBook Air 2022 (M2) Left Speaker Replacement, Remove the right hinge cover: passo 16, immagine 3 di 3
    • Grip the right hinge cover with blunt nose tweezers.
    • Pull the cover toward the bottom of the laptop and upward to free it from its recess.
    • Pull up and remove the hinge cover.
  17. MacBook Air 2022 (M2) Left Speaker Replacement, Unfasten the speaker: passo 17, immagine 1 di 1
    • Remove the three screws securing the left speaker:
    • Two 5.6 mm 4IP Torx Plus screws
    • One 3.5 mm T5 Torx screw
  18. MacBook Air 2022 (M2) Left Speaker Replacement, Remove the speaker: passo 18, immagine 1 di 2 MacBook Air 2022 (M2) Left Speaker Replacement, Remove the speaker: passo 18, immagine 2 di 2
    • Lift the left speaker straight up and remove it.
Conclusione
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting or check out our Answers community for help.
Altre 2 persone hanno completato questa guida.
Spencer Day
Membro da: 09/14/22
149.317 Reputazione
995 Guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
23.608 Guide realizzate
1Commento della guida
hi, i wonder if after a replacement and the speaker still sounds distorted maybe it could be cuz of missing/loose screws? i dont know because i still feel anxious about having to open it up myself, like the one that opened it was a techinician that i sent the m2 with him to repair.
pina the dall sheep - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 44
Ultimi 30 Giorni: 135
Tutti i Tempi: 3,561
