Introduzione
Use this guide to replace the logic board in your MacBook Air 15" 2023.
To maintain Touch ID functionality, you must also replace your Touch ID sensor with a new one that's paired to the replacement logic board. If your new logic board doesn't come with a paired Touch ID sensor, you'll lose functionality. The MacBook Air's original Touch ID sensor is uniquely paired to the logic board at the factory. Without Apple’s proprietary calibration process, even a genuine replacement Touch ID sensor from another MacBook Air won’t work.
Cosa ti serve
Unplug all cables and fully power off your MacBook.
Close the display and lay your MacBook upside down. Keep your laptop closed until you've physically disconnected the battery.
Use a P5 pentalobe screwdriver to remove the four 6.4 mm‑long screws securing the lower case.
Apply a suction handle to the center of the lower case's front edge.
Pull up on the suction handle to create a gap between the lower case and the frame.
Insert an opening pick into the gap.
Slide the pick to the bottom right corner to release the first clip.
Slide the pick around the corner and up the right edge to release the next two clips.
Keep the lower case flat and firmly pull it straight away from the back edge, one corner at a time, to disengage the sliding tabs.
Remove the lower case.
Set the lower case in place and align the sliding tabs with the screw heads they slide over. Press down and slide the lower case toward the back edge to engage the tabs—it'll stop sliding as the tabs engage.
Once the lower case is flush with the frame, press down firmly along the perimeter to engage the six snapping clips.
Use blunt nose tweezers or your fingers to remove the piece of tape covering the battery connector cover.
Use a T3 Torx screwdriver to remove the two 1.5 mm‑long screws securing the battery connector cover.
Remove the cover.
Use an opening pick to pry up and disconnect the battery connector.
Use a T3 Torx screwdriver to remove the following screws:
Two 2.6 mm‑long screws securing the left hinge cover
Two 1.5 mm‑long screws securing the speaker cable cover
Use the point of a spudger to pry up and disconnect the right speaker press connector.
Use a T5 Torx screwdriver to remove the two screws securing the top edge of the right speaker:
One 2.7 mm‑long screw
One 5.5 mm‑long screw
Use a T6 Torx screwdriver to remove the 3.5 mm‑long screw securing the bottom edge of the speaker.
Lift the speaker's left edge over the frame and slide it to the left to remove it.
Two 2.6 mm‑long screws securing the right hinge cover
Insert the point of a spudger into one of the right hinge cover's screw holes.
Push the hinge cover away from the back edge to dislodge it.
Remove the hinge cover.
Use the point of a spudger to pry up and disconnect the left speaker press connector.
Use a T5 Torx screwdriver to remove the two screws securing the top edge of the left speaker:
Lift the speaker's right edge over the frame and slide it to the right to remove it.
Use a T3 Torx screwdriver to remove the two 1.5 mm‑long screws securing the antenna cables cover.
Remove the cover.
Insert one arm of a pair of angled tweezers under the metal neck of one of the antenna connectors and lift straight up to disconnect it.
Disconnect the other antenna.
Use a T5 Torx screwdriver to remove the two 5.5 mm‑long screws securing the antenna bar.
Use tweezers or your fingers to remove the foam pad from the cover.
Use a T3 Torx screwdriver to remove the four 1.5 mm‑long screws securing the display and camera cables cover.
Remove the cover.
Use a spudger to pry up and disconnect the display and camera cable press connectors.
Use a T3 Torx screwdriver to remove the two 2.8 mm‑long screws securing the display and camera cables to the frame.
Use blunt nose tweezers or your fingers to remove the foam pad and two pieces of tape:
The headphone jack press connector cover's foam pad
The trackpad cable tape
The MagSafe and Thunderbolt connector cover tape
Pull the trackpad cable away from its cover to separate the adhesive securing it.
Use a T3 Torx screwdriver to remove the six 1.5 mm‑long screws securing the interconnect, trackpad, and MagSafe/Thunderbolt connector covers.
Remove the three connector covers.
Use a spudger to pry up and disconnect all seven press connectors from the logic board:
One for the interconnect cable
One for the trackpad cable
One for the microphone array cable
Four on the right side of the logic board for the MagSafe, Thunderbolt and Hall effect sensor cables
Use a T3 Torx screwdriver to remove the two screws on the upper left edge of the logic board:
One 2.6 mm‑long screw
One 4.7 mm‑long screw
Use a T5 Torx screwdriver to remove the six remaining screws securing the logic board:
Three 3.1 mm‑long screws
Two 3.8 mm‑long screws
One 3.6 mm‑long screw
Grip the right side of the logic board and remove it.
Lower the logic board into place, making sure no cables get stuck underneath.
Carefully check the edges of the logic board to see if any cables got stuck underneath. If any did, use the point of a spudger to gently pull them out.
Altre 2 persone hanno completato questa guida.
