Salta al contenuto principale
MacBook Air 13" Early 2020 Fan Replacement
Cosa ti serve
  1. MacBook Air 13" Early 2020 Fan Replacement, Remove the screws securing the lower case: passo 1, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Magnetic Project Mat
    $19.95
    Compra
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook Air before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.1 mm screws
    • Six 2.6 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your MacBook.
  2. MacBook Air 13" Early 2020 Fan Replacement, Remove the lower case: passo 2, immagine 1 di 3 MacBook Air 13" Early 2020 Fan Replacement, Remove the lower case: passo 2, immagine 2 di 3 MacBook Air 13" Early 2020 Fan Replacement, Remove the lower case: passo 2, immagine 3 di 3
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
  3. MacBook Air 13" Early 2020 Fan Replacement, Disconnect the battery: passo 3, immagine 1 di 1
    • Peel back the tape covering the battery connector enough to reveal the connector underneath.
  4. MacBook Air 13" Early 2020 Fan Replacement: passo 4, immagine 1 di 2 MacBook Air 13" Early 2020 Fan Replacement: passo 4, immagine 2 di 2
    • Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board.
  5. MacBook Air 13" Early 2020 Fan Replacement, Disconnect the right speaker: passo 5, immagine 1 di 2 MacBook Air 13" Early 2020 Fan Replacement, Disconnect the right speaker: passo 5, immagine 2 di 2
    • Slide the pointed end of a spudger underneath the speaker cable and pry straight up to disconnect it.
  6. MacBook Air 13" Early 2020 Fan Replacement, Disconnect the audio board: passo 6, immagine 1 di 2 MacBook Air 13" Early 2020 Fan Replacement, Disconnect the audio board: passo 6, immagine 2 di 2
    • Use a T4 Torx driver to remove the three 1.4 mm screws securing the audio board connector cover.
    • Remove the audio board connector cover.
  7. MacBook Air 13" Early 2020 Fan Replacement: passo 7, immagine 1 di 2 MacBook Air 13" Early 2020 Fan Replacement: passo 7, immagine 2 di 2
    • Use the flat end of a spudger to pry the audio board connector straight up to disconnect it from the board.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  8. MacBook Air 13" Early 2020 Fan Replacement: passo 8, immagine 1 di 3 MacBook Air 13" Early 2020 Fan Replacement: passo 8, immagine 2 di 3 MacBook Air 13" Early 2020 Fan Replacement: passo 8, immagine 3 di 3
    • Use the flat end of a spudger to pry the Touch ID cable straight up to disconnect it from the audio board.
    • Continue to slide the spudger underneath the Touch ID cable to release it from the audio board.
    • The Touch ID cable is secured to the audio board with some light adhesive.
  9. MacBook Air 13" Early 2020 Fan Replacement, Remove the audio board: passo 9, immagine 1 di 1
    • Use a T4 Torx driver to remove the three screws securing the audio board:
    • Two 4.3 mm screws
    • One 2.4 mm screw
  10. MacBook Air 13" Early 2020 Fan Replacement: passo 10, immagine 1 di 1
    • Remove the audio board.
  11. MacBook Air 13" Early 2020 Fan Replacement, Disconnect the fan: passo 11, immagine 1 di 1
    • Use a pair of tweezers to peel back the black tape covering the fan cable connector.
  12. MacBook Air 13" Early 2020 Fan Replacement: passo 12, immagine 1 di 3 MacBook Air 13" Early 2020 Fan Replacement: passo 12, immagine 2 di 3 MacBook Air 13" Early 2020 Fan Replacement: passo 12, immagine 3 di 3
    • Use the pointed end of a spudger to lift up the small locking flap on the fan cable's ZIF connector.
    • Slide the fan cable out of its connector.
    • If possible, grip the cable by the tape, not by the cable itself.
  13. MacBook Air 13" Early 2020 Fan Replacement, Separate the audio board cable: passo 13, immagine 1 di 3 MacBook Air 13" Early 2020 Fan Replacement, Separate the audio board cable: passo 13, immagine 2 di 3 MacBook Air 13" Early 2020 Fan Replacement, Separate the audio board cable: passo 13, immagine 3 di 3
    • Slide an opening pick underneath the audio board cable to separate it from the fan.
    • The cable is secured with some light adhesive.
    • If the adhesive is stubborn, do not force the pick. Lightly heat the cable using an iOpener or a hair dryer to soften the adhesive.
  14. MacBook Air 13" Early 2020 Fan Replacement, Remove the fan screws: passo 14, immagine 1 di 1
    • Use a T4 Torx driver to remove the three 2.7 mm screws securing the fan.
  15. MacBook Air 13" Early 2020 Fan Replacement, Remove the fan: passo 15, immagine 1 di 1
    • Lift the fan out of the case to remove it.
Conclusione
Altre 2 persone hanno completato questa guida.
Carsten Frauenheim
Membro da: 03/10/20
113.712 Reputazione
338 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
16.817 Guide realizzate
Un commento
Thank you very much. This helped me a lot when my fan started making buzzing noise an$ had the change it.
francis Bahenduzi - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 11
Ultimi 7 Giorni: 69
Ultimi 30 Giorni: 351
Tutti i Tempi: 8,045
