Introduzione
Use this guide to replace the BR2032 coin cell battery in your Mac Studio (2023).
The coin cell battery (sometimes referred to as CMOS or RTC battery) helps maintain system settings when your device isn't connected to power.
Some signs you may need to replace the battery:
- The date and time are incorrect after your Mac has been turned off for an extended period of time.
- Your Mac isn't waking up from sleep or hibernation on schedule.
- Your Mac is experiencing startup problems.
Before starting this repair, read through Apple's troubleshooting guides on startup issues and intermittent shutdown or system instability and try the solutions that don't require taking apart your device.
Cosa ti serve
Completely shut down your Mac Studio.
Unplug all cables from your device.
Flip your Mac Studio over and lay it down so the bottom faces up and the SD card slot and two front USB‑C ports are facing you.
Heat an iOpener and lay it over one of the bottom cover screws for two minutes to soften the adhesive near the screw—this is where you'll insert a spudger in the next step.
Insert the point of a spudger under the pad's inner edge, near the screw you applied heat to in the previous step.
Use the spudger to lift the pad and separate the adhesive.
Insert the flat end of a spudger under the pad.
Slide the spudger under the entire pad to separate the remaining adhesive.
Attrezzo utilizzato in questo passaggio:Tesa 61395 Tape$2.99
If the adhesive strips are still sticky, you can reuse them.
Use the flat end of a spudger and your fingers to scrape up and remove the old adhesive strips.
Use isopropyl alcohol and a microfiber cloth to remove the old adhesive residue.
Apply the new adhesive strips to the bottom cover and remove their liners.
Firmly press the bottom cover screw pad into its recess to secure it.
Attrezzo utilizzato in questo passaggio:FixMat$31.41
Use a T10 Torx screwdriver to remove the four 8 mm‑long screws securing the bottom cover.
Insert the point of a spudger in one of the bottom cover's ventilation holes and lift the cover until you can grab it with your fingers.
Remove the bottom cover.
Use a T10 Torx screwdriver to remove the six screws securing the power supply:
Four 6 mm‑long screws
Two 7 mm‑long screws with washers
Flip your Mac Studio around so the rear ports are facing you.
Firmly hold the power supply with one hand and lift up the edge near the power cord port.
With your free hand, pinch the head of the power cord port connector to unclip it and pull straight down to disconnect the cable.
Carefully tilt the power supply away from the power cord port so it's at a 90-degree angle.
Keep the power supply tilted up for the next step.
With your free hand, pinch the head of the power supply connector to unclip it and pull straight away from the socket to disconnect the cable.
Flip your Mac Studio around so the SD card reader and two front USB‑C ports are facing you.
Use a T6 Torx screwdriver to remove the eight screws securing the internal frame:
Seven 5 mm‑long screws
One 4 mm‑long screw
Slowly lift the internal frame straight up and remove it, making sure no cables get snagged.
Use a T5 Torx screwdriver to remove the two 12 mm‑long screws securing the speaker.
Lift the inner edge of the speaker and stand it upright so you can access its connector on the logic board.
Insert the point of a spudger under the speaker connector's plastic head and carefully lift it straight up and out of its socket.
Use a T5 Torx screwdriver to remove the two 4 mm‑long screws securing the coin cell battery housing.
Insert the flat end of a spudger between the coin cell battery and its housing.
Twist the spudger to unclip the battery.
Remove the battery.
Insert the battery into its housing with the positive (+) side facing down.
1Commento della guida
Fantastic manual, even with the tools for sale. Perfect, and thank you! But What a flop in the design of the Mac Studio itself - come on! Replacing a battery? Seriously? What were they thinking? Did they hire the same person who invented the recharging point on your mouse should be the downside?
