Salta al contenuto principale
MSI GS63VR 6RF Stealth Pro Battery Replacement
Cosa ti serve
  1. MSI GS63VR 6RF Stealth Pro Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Use a Phillips screwdriver to remove the 15 screws securing the back cover.
    • Insert an opening tool or spudger in the seam and pry along the perimeter to loosen the back cover.
    • Do not insert the opening too too far into the back edge (with "Stealth" written on it), or you may damage the power LED.
    • The back cover is secured with clips. Too much pressure from the spudger can break the clips, but some flex is not dangerous.
    • Remove the back cover.
  2. MSI GS63VR 6RF Stealth Pro Battery Replacement: passo 2, immagine 1 di 1
    • Disconnect the battery by carefully pulling its connector towards the battery.
    • Pull parallel to the battery, not straight up.
  3. MSI GS63VR 6RF Stealth Pro Battery Replacement: passo 3, immagine 1 di 2 MSI GS63VR 6RF Stealth Pro Battery Replacement: passo 3, immagine 2 di 2
    • The battery is attached to the laptop with a strong adhesive.
    • Lift the battery from laptop.
    • Be careful not to bend the or puncture the battery, as that may cause a fire hazard.
Conclusione
For optimal performance, after completing this guide, calibrate your newly installed battery.
Altre 4 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 54
Tutti i Tempi: 7,082
