Salta al contenuto principale
Logitech G915 Wireless (Clicky) Battery Replacement
Cosa ti serve
  1. Logitech G915 Wireless (Clicky) Battery Replacement, Prepare your keyboard for disassembly: passo 1, immagine 1 di 3 Logitech G915 Wireless (Clicky) Battery Replacement, Prepare your keyboard for disassembly: passo 1, immagine 2 di 3 Logitech G915 Wireless (Clicky) Battery Replacement, Prepare your keyboard for disassembly: passo 1, immagine 3 di 3
    • Slide the power switch on the top edge of the keyboard to the OFF (left) position.
    • A red indicator should be visible beneath the switch.
    • Unplug all cables from the keyboard.
    • Lay the keyboard down with the feet facing up on a clean work surface.
    • If your work surface might scratch the keyboard, place a soft towel under it.
  2. Logitech G915 Wireless (Clicky) Battery Replacement, Remove the sticker: passo 2, immagine 1 di 2 Logitech G915 Wireless (Clicky) Battery Replacement, Remove the sticker: passo 2, immagine 2 di 2
    • The Logitech sticker hides two battery cover screws.
    • Heat an iOpener and lay it on the Logitech sticker for one minute.
    • Alternatively, you can use a hair dryer to heat the sticker. Make sure it's on the Low setting to avoid warping the plastic.
  3. Logitech G915 Wireless (Clicky) Battery Replacement: passo 3, immagine 1 di 3 Logitech G915 Wireless (Clicky) Battery Replacement: passo 3, immagine 2 di 3 Logitech G915 Wireless (Clicky) Battery Replacement: passo 3, immagine 3 di 3
    • If you don't want to remove the whole sticker, you can just peel up the bottom left and right corners until you can access the screws.
    • Use a spudger or your fingernail to peel up a corner of the sticker until you can grip it with your fingers.
    • Peel up the sticker with your fingers and remove it.
  4. Logitech G915 Wireless (Clicky) Battery Replacement, Remove the battery cover screws: passo 4, immagine 1 di 2 Logitech G915 Wireless (Clicky) Battery Replacement, Remove the battery cover screws: passo 4, immagine 2 di 2
    • Use a Phillips screwdriver to remove the two 4 mm‑long screws securing the battery cover.
  5. Logitech G915 Wireless (Clicky) Battery Replacement, Remove the USB receiver: passo 5, immagine 1 di 3 Logitech G915 Wireless (Clicky) Battery Replacement, Remove the USB receiver: passo 5, immagine 2 di 3 Logitech G915 Wireless (Clicky) Battery Replacement, Remove the USB receiver: passo 5, immagine 3 di 3
    • If you have a USB receiver stored in the battery cover compartment, use your finger to slide it out and remove it.
  6. Logitech G915 Wireless (Clicky) Battery Replacement, Reposition the battery cover: passo 6, immagine 1 di 3 Logitech G915 Wireless (Clicky) Battery Replacement, Reposition the battery cover: passo 6, immagine 2 di 3 Logitech G915 Wireless (Clicky) Battery Replacement, Reposition the battery cover: passo 6, immagine 3 di 3
    • Plastic clips secure the edges of the battery cover.
    • Insert your finger into the USB receiver compartment on the battery cover.
    • Pull up the bottom edge of the cover to release the clips.
    • Don't try to fully remove the cover yet, as it's still connected by the battery cable.
    • Gently pull the cover to the right so you can access the battery connector on the left side of the recess.
  7. Logitech G915 Wireless (Clicky) Battery Replacement, Disconnect the battery: passo 7, immagine 1 di 2 Logitech G915 Wireless (Clicky) Battery Replacement, Disconnect the battery: passo 7, immagine 2 di 2
    • Use a pair of angled tweezers to firmly grip the battery connector.
    • Hold the tweezers with your fingers as close to the connector as possible to get a firm grip.
    • Slide the connector straight out of its socket.
    • If you're having trouble, gently rock the connector side-to-side to help loosen it.
  8. Logitech G915 Wireless (Clicky) Battery Replacement, Remove the battery cover: passo 8, immagine 1 di 1
    • Remove the battery cover.
    • Congratulations on completing disassembly! The remaining steps will show you how to install your replacement battery and reassemble your device.
  9. Logitech G915 Wireless (Clicky) Battery Replacement, Install the new battery: passo 9, immagine 1 di 3 Logitech G915 Wireless (Clicky) Battery Replacement, Install the new battery: passo 9, immagine 2 di 3 Logitech G915 Wireless (Clicky) Battery Replacement, Install the new battery: passo 9, immagine 3 di 3
    • If your replacement battery comes attached to a new battery cover, skip the next three steps. Otherwise, follow the next three steps to remove the old battery from the cover and install your new one.
    • Light adhesive secures the battery to its cover.
    • Gently slide the flat end of a spudger under one of the short edges of the battery and lift to separate the adhesive.
    • Be very careful not to puncture the battery, as it can leak dangerous chemicals or catch fire.
    • Remove the battery from its cover.
  10. Logitech G915 Wireless (Clicky) Battery Replacement: passo 10, immagine 1 di 3 Logitech G915 Wireless (Clicky) Battery Replacement: passo 10, immagine 2 di 3 Logitech G915 Wireless (Clicky) Battery Replacement: passo 10, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Tesa 61395 Tape
    $5.99
    • Cut a piece of double-sided tape so it fits on the line of squares on the inside of the battery cover.
    • Press the tape firmly into place on the squares and remove the liner.
  11. Logitech G915 Wireless (Clicky) Battery Replacement: passo 11, immagine 1 di 1
    • Lay your new battery into its recess in the keyboard so the cable is on the left edge, near the battery connector.
  12. Logitech G915 Wireless (Clicky) Battery Replacement, Reconnect the battery: passo 12, immagine 1 di 2 Logitech G915 Wireless (Clicky) Battery Replacement, Reconnect the battery: passo 12, immagine 2 di 2
    • Insert the new battery's connector into its socket so the side with exposed pins is on the bottom.
    • Use a spudger to push the battery connector fully into its socket.
  13. Logitech G915 Wireless (Clicky) Battery Replacement, Install the battery cover: passo 13, immagine 1 di 1
    • Set the battery cover into place and firmly press down around its edges to engage all the clips.
    • You should feel and hear "clicks" as the clips engage.
  14. Logitech G915 Wireless (Clicky) Battery Replacement, Install the battery cover screws: passo 14, immagine 1 di 2 Logitech G915 Wireless (Clicky) Battery Replacement, Install the battery cover screws: passo 14, immagine 2 di 2
    • Use a Phillips screwdriver to install the two 4 mm‑long screws securing the battery cover.
  15. Logitech G915 Wireless (Clicky) Battery Replacement, Apply the battery cover sticker: passo 15, immagine 1 di 1
    • Use your fingers to apply the sticker to the battery cover.
    • To help the sticker adhere better, you can apply some heat with an iOpener or hair dryer.
Conclusione
Spencer Day
Membro da: 09/14/22
149.771 Reputazione
995 Guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
23.638 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 76
Tutti i Tempi: 1,419
