Salta al contenuto principale
LexiBook Tablet One Speaker Replacement
Cosa ti serve
    1. LexiBook Tablet One Speaker Replacement, Speaker: passo 1, immagine 1 di 3 LexiBook Tablet One Speaker Replacement, Speaker: passo 1, immagine 2 di 3 LexiBook Tablet One Speaker Replacement, Speaker: passo 1, immagine 3 di 3
      • Insert the blue plastic opening tool where the case has a seam. Move side to side until you hear a clip pop. Move around the edge of the case until all clips are separated. The clips are 1.5 in. apart within the case.
      Chiedi a FixBot
      Aggiungi Commento
    2. LexiBook Tablet One Speaker Replacement: passo 2, immagine 1 di 2 LexiBook Tablet One Speaker Replacement: passo 2, immagine 2 di 2
      • After successfully separating the casing insert a plastic spudger between the case and the speaker. Carefully pry the speaker out. Once the speaker is removed set the back casing aside.
      Chiedi a FixBot
      Aggiungi Commento
    3. LexiBook Tablet One Speaker Replacement: passo 3, immagine 1 di 1
      • Using a soldering gun, apply heat where the speaker wires meet the motherboard. Heat the solder around both the black and red wires until they easily slide away.
      • Be careful not to heat the motherboard too long so to avoid damaging other components. Also, care to avoid liquefying the solder on any near by components.
      • How to Solder is IFixIt's official guide to use a soldering gun.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Jordan
Membro da: 03/11/15
650 Reputazione
4 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 11
Ultimi 30 giorni: 28
Tutti i Tempi: 429
