Salta al contenuto principale
Lens Replacement
Cosa ti serve
  1. Lens Replacement, Removing the Battery: passo 1, immagine 1 di 3 Lens Replacement, Removing the Battery: passo 1, immagine 2 di 3 Lens Replacement, Removing the Battery: passo 1, immagine 3 di 3
    • Flip the small blue switch up to release the battery. Remove the battery.
    • Remove two Philips #000 screws. Place the screws on a magnetic pad or somewhere safe.
    • Insert a plastic opening tool in the corner by the Micro USB plug. This area will allow leverage in order to take off the outer case.
    Chiedi a FixBot
  2. Lens Replacement, Removing the Outer Casing: passo 2, immagine 1 di 3 Lens Replacement, Removing the Outer Casing: passo 2, immagine 2 di 3 Lens Replacement, Removing the Outer Casing: passo 2, immagine 3 di 3
    • Use the opening tool and your fingers to pry apart the outer case. Hold back camera as well as menu navigation buttons while you remove the case.
    • Unscrew two small Phillips screws holding the outer case to the motherboard. Use the opening tool to unhook the case from the plate covering the motherboard.
    • The second screw (top left) is under the control PCB. The PCB is mounted to a metal plate that is retained by some adhesive tape underneath and two prongs (bottom-left). You need to pry the plate from the top-right until the tape is broken, then slide the plate upwards (relative to photo). Take care not to pull or tear the ribbon cable.
    Chiedi a FixBot
  3. Lens Replacement, Removing the Ribbon: passo 3, immagine 1 di 2 Lens Replacement, Removing the Ribbon: passo 3, immagine 2 di 2
    • Disconnect the button casing ribbon cable from the motherboard.
    • Be gentle when removing the ribbon.
    • Lift up the metal casing with one hand and use the other hand to snap the ZIF connector back, in order to remove the display ribbon cable.
    Chiedi a FixBot
  4. Lens Replacement, Replacing the Lens: passo 4, immagine 1 di 3 Lens Replacement, Replacing the Lens: passo 4, immagine 2 di 3 Lens Replacement, Replacing the Lens: passo 4, immagine 3 di 3
    • Remove the display and buttons.
    • Release the clamp on the two ribbon cables connected to the camera lens.
    • Be gentle when removing the ribbons cables. They are fragile and can tear.
    • Pull the lens out of the camera base.
    Chiedi a FixBot
Conclusione
salome datong
Membro da: 09/26/16
104 Reputazione
Una guida realizzata
USF Tampa, Team 14-4, Eyestone Fall 2016 Membro di USF Tampa, Team 14-4, Eyestone Fall 2016
USFT-EYESTONE-F16S14G4
4 Membri
8 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 58
Tutti i Tempi: 1,921
