Salta al contenuto principale
Lenovo Yoga 910-13IKB Battery Replacement
Cosa ti serve
  1. Lenovo Yoga 910-13IKB Battery Replacement, Back Panel: passo 1, immagine 1 di 2 Lenovo Yoga 910-13IKB Battery Replacement, Back Panel: passo 1, immagine 2 di 2
    • Turn the laptop over and remove the ten Torx T5 screws along the perimeter of the bottom panel using the T5 Torx Screwdriver.
    • Remove the back panel from the device exposing the components.
  2. Lenovo Yoga 910-13IKB Battery Replacement, Battery: passo 2, immagine 1 di 1
    • Remove the four 3 mm Phillips #0 screws holding the battery in place.
  3. Lenovo Yoga 910-13IKB Battery Replacement: passo 3, immagine 1 di 3 Lenovo Yoga 910-13IKB Battery Replacement: passo 3, immagine 2 di 3 Lenovo Yoga 910-13IKB Battery Replacement: passo 3, immagine 3 di 3
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery. The spudger tool may be needed to lift the flap seal.
    • Pull parallel to the battery, not straight up.
    • Pull evenly on the width of the cable so that no individual wire is overly strained.
    • Lift the battery out.
Conclusione
For optimal performance, after completing this guide, calibrate your newly installed battery.
Altre 9 persone hanno completato questa guida.
Cal Poly, Team S1-G5, White Winter 2020 Membro di Cal Poly, Team S1-G5, White Winter 2020
CPSU-WHITE-W20S1G5
4 Membri
14 Guide realizzate
4 Commenti
Step 3-6 are redundant to simply change the battery, correct?
oslodave - Replica
You're right! I fixed the guide to reflect this.
Arthur Shi -
Maybe I haven't seen many battery connectors, but this is one of the most annoying to reinsert.
Noah - Replica
Easy battery replacement on Yoga 910. The repair kit contains a variety of small repair tools and is very nice for the price. Found some small metallic discs when disassembled; they were spacers for the screws in the back casing and superglued them back to the casing before reassembly.
InfamousB - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 37
Ultimi 30 Giorni: 194
Tutti i Tempi: 10,251
