Salta al contenuto principale
Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement
Cosa ti serve
  1. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Back Cover: passo 1, immagine 1 di 3 Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Back Cover: passo 1, immagine 2 di 3 Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Back Cover: passo 1, immagine 3 di 3
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Speakers: passo 2, immagine 1 di 1
    • Use a Phillips #00 head screwdriver to remove the four 4 mm screws above the battery.
  3. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement: passo 3, immagine 1 di 1
    • Lift the speaker modules on either side of the battery out of its pegs, and unwind the cable from the front of the battery.
    • Set the speaker modules out of the way.
  4. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Battery: passo 4, immagine 1 di 3 Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Battery: passo 4, immagine 2 di 3 Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Battery: passo 4, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Use tweezers to peel the plastic cover off the connector.
    • Use a spudger or your fingernail to pry up the battery straight up from the motherboard.
  5. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement: passo 5, immagine 1 di 1
    • Lift the battery out of the frame and remove it from the device.
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team S7-G3, Regan Winter 2020 Membro di Cal Poly, Team S7-G3, Regan Winter 2020
CPSU-REGAN-W20S7G3
4 Membri
8 Guide realizzate
2Commenti sulla guida
Could I use the same battery for my X1 Extreme Gen 1 laptop? Thanks.
Huy Tran - Replica
Thank you so much for this illustration on how to take off the battery. I was like already stuck at just the screws not coming off. This helped immensely.
Rafael Dolfe - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 40
Ultimi 30 Giorni: 270
Tutti i Tempi: 13,879
