Salta al contenuto principale
Introduzione
If your Lenovo ThinkPad X1 Gen 1 Extreme (model number 20MF-000LUS) is having trouble charging, overheating, or not holding a charge, use this guide to replace the battery pack.
A battery in good condition will power the computer for 15 hour periods and charge to 80% capacity in an hour. A faulty battery will not charge properly and will lose power quicker than expected.
Before replacing the battery, refer to the trouble shooting page for the Lenovo ThinkPad Gen 1 Extreme to see if the problem is fixable without purchasing and installing another battery.
Please keep in mind that a swollen lithium ion battery is dangerous and read the page attached to the link before repair. Be sure to disconnect the computer from any power and turn the computer completely off. It is also important to be careful when removing the battery; any damage can easily make the computer not functional.
  1. Be sure to power off and unplug your device before you begin your repair. Orient the laptop so that it is bottom up, and the track pad is closest to you.
    • Be sure to power off and unplug your device before you begin your repair.
    • Orient the laptop so that it is bottom up, and the track pad is closest to you.
    • Unscrew the seven cover screws with a Phillips #00 head screwdriver. These screws will loosen, but will stay attached to the cover.
    • Slide the blue opening pick along the side of the laptop and pry off the one clip on each side.
    • The cover should easily come off.
  2. Use a Phillips #00 head screwdriver to remove the four, 4mm screws above the battery.
    • Use a Phillips #00 head screwdriver to remove the four, 4mm screws above the battery.
  3. Lift the speaker modules on either side of the battery out of its pegs, and unwind the cable from the front of the battery.
    • Lift the speaker modules on either side of the battery out of its pegs, and unwind the cable from the front of the battery.
    • Set the speaker modules out of the way.
  4. Using tweezers, peel the plastic cover off the connector. Use a spudger or your fingernail to pry up the battery straight up from the motherboard. Use a spudger or your fingernail to pry up the battery straight up from the motherboard.
    • Using tweezers, peel the plastic cover off the connector.
    • Use a spudger or your fingernail to pry up the battery straight up from the motherboard.
  5. Lift the battery out of the frame and remove it from the device.
    • Lift the battery out of the frame and remove it from the device.
Conclusione
Beckham Richmond
Membro da: 10/02/2020
368 Reputazione
3 Guide realizzate
Cal Poly, Team S7-G3, Regan Winter 2020 Membro di Cal Poly, Team S7-G3, Regan Winter 2020
CPSU-REGAN-W20S7G3
4 Membri
8 Guide realizzate
Could I use the same battery for my X1 Extreme Gen 1 laptop? Thanks.
Huy Tran - Replica
Thank you so much for this illustration on how to take off the battery. I was like already stuck at just the screws not coming off. This helped immensely.
Rafael Dolfe - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 45
Ultimi 30 Giorni: 171
Tutti i Tempi: 1,833
