Salta al contenuto principale
Lenovo ThinkPad T480s Motherboard Replacement
Cosa ti serve
  1. Lenovo ThinkPad T480s Motherboard Replacement, Bottom Cover: passo 1, immagine 1 di 2 Lenovo ThinkPad T480s Motherboard Replacement, Bottom Cover: passo 1, immagine 2 di 2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s Motherboard Replacement: passo 2, immagine 1 di 3 Lenovo ThinkPad T480s Motherboard Replacement: passo 2, immagine 2 di 3 Lenovo ThinkPad T480s Motherboard Replacement: passo 2, immagine 3 di 3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s Motherboard Replacement: passo 3, immagine 1 di 2 Lenovo ThinkPad T480s Motherboard Replacement: passo 3, immagine 2 di 2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s Motherboard Replacement, Battery: passo 4, immagine 1 di 2 Lenovo ThinkPad T480s Motherboard Replacement, Battery: passo 4, immagine 2 di 2
    • Use the Phillips #1 screwdriver to remove four 4.5mm screws that hold the battery down to the mid frame.
  5. Lenovo ThinkPad T480s Motherboard Replacement: passo 5, immagine 1 di 3 Lenovo ThinkPad T480s Motherboard Replacement: passo 5, immagine 2 di 3 Lenovo ThinkPad T480s Motherboard Replacement: passo 5, immagine 3 di 3
    • Lift the battery near the connector and remove it from the system.
  6. Lenovo ThinkPad T480s Motherboard Replacement, Keyboard: passo 6, immagine 1 di 3 Lenovo ThinkPad T480s Motherboard Replacement, Keyboard: passo 6, immagine 2 di 3 Lenovo ThinkPad T480s Motherboard Replacement, Keyboard: passo 6, immagine 3 di 3
    • Disable the battery, power down, and unplug your device before you begin.
    • Pry the left and right trackpad buttons up with a spudger.
  7. Lenovo ThinkPad T480s Motherboard Replacement: passo 7, immagine 1 di 2 Lenovo ThinkPad T480s Motherboard Replacement: passo 7, immagine 2 di 2
    • With a Phillips #0 screwdriver, loosen the two captive screws underneath the left and right trackpad buttons.
  8. Lenovo ThinkPad T480s Motherboard Replacement: passo 8, immagine 1 di 3 Lenovo ThinkPad T480s Motherboard Replacement: passo 8, immagine 2 di 3 Lenovo ThinkPad T480s Motherboard Replacement: passo 8, immagine 3 di 3
    • Wedge the spudger under the front edge of the keyboard to push the keyboard toward the back of the system.
    • Lift the front edge of the keyboard up by a few millimeters.
  9. Lenovo ThinkPad T480s Motherboard Replacement: passo 9, immagine 1 di 2 Lenovo ThinkPad T480s Motherboard Replacement: passo 9, immagine 2 di 2
    • Gently, pull the keyboard out from the bezel and flip it over.
    • It is connected to to the keyboard and trackpad cables so be sure not to yank it over to avoid tearing them.
  10. Lenovo ThinkPad T480s Motherboard Replacement: passo 10, immagine 1 di 3 Lenovo ThinkPad T480s Motherboard Replacement: passo 10, immagine 2 di 3 Lenovo ThinkPad T480s Motherboard Replacement: passo 10, immagine 3 di 3
    • Use the spudger to disconnect the trackpad cable from the system.
    • For more information on types of connectors, check out this guide.
  11. Lenovo ThinkPad T480s Motherboard Replacement: passo 11, immagine 1 di 3 Lenovo ThinkPad T480s Motherboard Replacement: passo 11, immagine 2 di 3 Lenovo ThinkPad T480s Motherboard Replacement: passo 11, immagine 3 di 3
    • Use the spudger to disconnect the keyboard cable from the system.
  12. Lenovo ThinkPad T480s Motherboard Replacement: passo 12, immagine 1 di 2 Lenovo ThinkPad T480s Motherboard Replacement: passo 12, immagine 2 di 2
    • Lift the keyboard off of the palm rest.
  13. Lenovo ThinkPad T480s Motherboard Replacement, SSD: passo 13, immagine 1 di 2 Lenovo ThinkPad T480s Motherboard Replacement, SSD: passo 13, immagine 2 di 2
    • Use the Phillips #1 screwdriver to remove one 2.8 mm screw securing the SSD.
  14. Lenovo ThinkPad T480s Motherboard Replacement: passo 14, immagine 1 di 3 Lenovo ThinkPad T480s Motherboard Replacement: passo 14, immagine 2 di 3 Lenovo ThinkPad T480s Motherboard Replacement: passo 14, immagine 3 di 3
    • Pull the SSD out of the socket.
  15. Lenovo ThinkPad T480s Motherboard Replacement, RAM: passo 15, immagine 1 di 3 Lenovo ThinkPad T480s Motherboard Replacement, RAM: passo 15, immagine 2 di 3 Lenovo ThinkPad T480s Motherboard Replacement, RAM: passo 15, immagine 3 di 3
    • Pull the plastic film back.
    • Push the clips outward to release the RAM stick.
    • My device doesn't have RAM so you don't see it.
    • The RAM stick will pop out at an angle. Pull the RAM stick out at the same angle.
  16. Lenovo ThinkPad T480s Motherboard Replacement, Wi-Fi Card: passo 16, immagine 1 di 3 Lenovo ThinkPad T480s Motherboard Replacement, Wi-Fi Card: passo 16, immagine 2 di 3 Lenovo ThinkPad T480s Motherboard Replacement, Wi-Fi Card: passo 16, immagine 3 di 3
    • Using the nylon spudger, pop the coaxial antenna wires off the Wi-Fi card.
    • When reassembling, reattach the gray wire closest to the screw and the black wire on the other side of the gray wire.
  17. Lenovo ThinkPad T480s Motherboard Replacement: passo 17, immagine 1 di 2 Lenovo ThinkPad T480s Motherboard Replacement: passo 17, immagine 2 di 2
    • Use the Phillips #1 screwdriver to remove one 2.8mm screw holding the Wi-Fi card down to the motherboard.
  18. Lenovo ThinkPad T480s Motherboard Replacement: passo 18, immagine 1 di 3 Lenovo ThinkPad T480s Motherboard Replacement: passo 18, immagine 2 di 3 Lenovo ThinkPad T480s Motherboard Replacement: passo 18, immagine 3 di 3
    • Slide the Wi-Fi card out from the slot.
  19. Lenovo ThinkPad T480s Motherboard Replacement, WWAN Card: passo 19, immagine 1 di 3 Lenovo ThinkPad T480s Motherboard Replacement, WWAN Card: passo 19, immagine 2 di 3 Lenovo ThinkPad T480s Motherboard Replacement, WWAN Card: passo 19, immagine 3 di 3
    • Flip the cardboard cover off of the WWAN card.
    • Using the spudger, release the coaxial antenna wires from the WWAN card.
    • When reassembling, reattach the blue wire on the left and the orange wire on the right.
  20. Lenovo ThinkPad T480s Motherboard Replacement: passo 20, immagine 1 di 2 Lenovo ThinkPad T480s Motherboard Replacement: passo 20, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove one 2.8mm screw.
  21. Lenovo ThinkPad T480s Motherboard Replacement: passo 21, immagine 1 di 3 Lenovo ThinkPad T480s Motherboard Replacement: passo 21, immagine 2 di 3 Lenovo ThinkPad T480s Motherboard Replacement: passo 21, immagine 3 di 3
    • Slide the WWAN card out from the slot.
  22. Lenovo ThinkPad T480s Motherboard Replacement, Fan Assembly: passo 22, immagine 1 di 2 Lenovo ThinkPad T480s Motherboard Replacement, Fan Assembly: passo 22, immagine 2 di 2
    • Use the spudger to disconnect the fan cable from the motherboard.
  23. Lenovo ThinkPad T480s Motherboard Replacement: passo 23, immagine 1 di 2 Lenovo ThinkPad T480s Motherboard Replacement: passo 23, immagine 2 di 2
    • Loosen the six captive screws attaching the fan assembly to the motherboard.
    • This system was missing the two screws by the fan but I have highlighted them to show where they are located.
  24. Lenovo ThinkPad T480s Motherboard Replacement: passo 24, immagine 1 di 3 Lenovo ThinkPad T480s Motherboard Replacement: passo 24, immagine 2 di 3 Lenovo ThinkPad T480s Motherboard Replacement: passo 24, immagine 3 di 3
    • Lift the thermal fan assembly from the system and remove it.
  25. Lenovo ThinkPad T480s Motherboard Replacement, SIM Card Tray: passo 25, immagine 1 di 2 Lenovo ThinkPad T480s Motherboard Replacement, SIM Card Tray: passo 25, immagine 2 di 2
    • Insert the SIM eject bit or a paper clip in the hole of the SIM tray to eject it.
    • Remove the SIM tray.
  26. Lenovo ThinkPad T480s Motherboard Replacement, Motherboard: passo 26, immagine 1 di 3 Lenovo ThinkPad T480s Motherboard Replacement, Motherboard: passo 26, immagine 2 di 3 Lenovo ThinkPad T480s Motherboard Replacement, Motherboard: passo 26, immagine 3 di 3
    • Use the spudger to disconnect the LCD cable from the motherboard.
  27. Lenovo ThinkPad T480s Motherboard Replacement: passo 27, immagine 1 di 3 Lenovo ThinkPad T480s Motherboard Replacement: passo 27, immagine 2 di 3 Lenovo ThinkPad T480s Motherboard Replacement: passo 27, immagine 3 di 3
    • Use the spudger to disconnect the camera cable from the motherboard.
  28. Lenovo ThinkPad T480s Motherboard Replacement: passo 28, immagine 1 di 3 Lenovo ThinkPad T480s Motherboard Replacement: passo 28, immagine 2 di 3 Lenovo ThinkPad T480s Motherboard Replacement: passo 28, immagine 3 di 3
    • Remove all antenna cables from their routing.
  29. Lenovo ThinkPad T480s Motherboard Replacement: passo 29, immagine 1 di 3 Lenovo ThinkPad T480s Motherboard Replacement: passo 29, immagine 2 di 3 Lenovo ThinkPad T480s Motherboard Replacement: passo 29, immagine 3 di 3
    • Use the spudger to disconnect the SD card reader/audio card cable from the board.
    • The cable is attached to the board with adhesive so you will need to peel the cable up.
  30. Lenovo ThinkPad T480s Motherboard Replacement: passo 30, immagine 1 di 3 Lenovo ThinkPad T480s Motherboard Replacement: passo 30, immagine 2 di 3 Lenovo ThinkPad T480s Motherboard Replacement: passo 30, immagine 3 di 3
    • Use a connector puller or spudger to disconnect the coin cell battery from the board and pull the cable from the notch.
  31. Lenovo ThinkPad T480s Motherboard Replacement: passo 31, immagine 1 di 3 Lenovo ThinkPad T480s Motherboard Replacement: passo 31, immagine 2 di 3 Lenovo ThinkPad T480s Motherboard Replacement: passo 31, immagine 3 di 3
    • Use the spudger to disconnect the trackpad cable, the Hall sensor cable, and the smart card reader cable from the motherboard.
  32. Lenovo ThinkPad T480s Motherboard Replacement: passo 32, immagine 1 di 3 Lenovo ThinkPad T480s Motherboard Replacement: passo 32, immagine 2 di 3 Lenovo ThinkPad T480s Motherboard Replacement: passo 32, immagine 3 di 3
    • Disconnect the USB Card cable from the motherboard using the spudger.
  33. Lenovo ThinkPad T480s Motherboard Replacement: passo 33, immagine 1 di 2 Lenovo ThinkPad T480s Motherboard Replacement: passo 33, immagine 2 di 2
    • Use the spudger to disconnect the power button cable from the motherboard.
  34. Lenovo ThinkPad T480s Motherboard Replacement: passo 34, immagine 1 di 2 Lenovo ThinkPad T480s Motherboard Replacement: passo 34, immagine 2 di 2
    • Use the Phillips #1 screwdriver to remove the 4.6 mm screw from the USB-C bracket.
  35. Lenovo ThinkPad T480s Motherboard Replacement: passo 35, immagine 1 di 2 Lenovo ThinkPad T480s Motherboard Replacement: passo 35, immagine 2 di 2
    • Lift the USB-C bracket from the system.
  36. Lenovo ThinkPad T480s Motherboard Replacement: passo 36, immagine 1 di 2 Lenovo ThinkPad T480s Motherboard Replacement: passo 36, immagine 2 di 2
    • Use the Phillips #1 screwdriver to remove the 4.7 mm screw from the trap door.
  37. Lenovo ThinkPad T480s Motherboard Replacement: passo 37, immagine 1 di 2 Lenovo ThinkPad T480s Motherboard Replacement: passo 37, immagine 2 di 2
    • Lift the trap door out.
  38. Lenovo ThinkPad T480s Motherboard Replacement: passo 38, immagine 1 di 2 Lenovo ThinkPad T480s Motherboard Replacement: passo 38, immagine 2 di 2
    • Remove the 4.4 mm screw from the HDMI bracket using the Phillips #1 screwdriver.
  39. Lenovo ThinkPad T480s Motherboard Replacement: passo 39, immagine 1 di 3 Lenovo ThinkPad T480s Motherboard Replacement: passo 39, immagine 2 di 3 Lenovo ThinkPad T480s Motherboard Replacement: passo 39, immagine 3 di 3
    • Remove the HDMI bracket from the motherboard using your fingers.
  40. Lenovo ThinkPad T480s Motherboard Replacement: passo 40, immagine 1 di 3 Lenovo ThinkPad T480s Motherboard Replacement: passo 40, immagine 2 di 3 Lenovo ThinkPad T480s Motherboard Replacement: passo 40, immagine 3 di 3
    • Using the Phillips #1 screwdriver, remove four 3.1 mm screws from the motherboard.
  41. Lenovo ThinkPad T480s Motherboard Replacement: passo 41, immagine 1 di 2 Lenovo ThinkPad T480s Motherboard Replacement: passo 41, immagine 2 di 2
    • Lift the motherboard from the chassis to remove it from the device.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Altre 2 persone hanno completato questa guida.
Sarah Westberg
Membro da: 03/11/19
23.257 Reputazione
70 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
17.243 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 28
Ultimi 30 Giorni: 135
Tutti i Tempi: 3,409
