Salta al contenuto principale
Lenovo ThinkPad T480s Fan Assembly Replacement
Cosa ti serve
  1. Lenovo ThinkPad T480s Fan Assembly Replacement, Bottom Cover: passo 1, immagine 1 di 2 Lenovo ThinkPad T480s Fan Assembly Replacement, Bottom Cover: passo 1, immagine 2 di 2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s Fan Assembly Replacement: passo 2, immagine 1 di 3 Lenovo ThinkPad T480s Fan Assembly Replacement: passo 2, immagine 2 di 3 Lenovo ThinkPad T480s Fan Assembly Replacement: passo 2, immagine 3 di 3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s Fan Assembly Replacement: passo 3, immagine 1 di 2 Lenovo ThinkPad T480s Fan Assembly Replacement: passo 3, immagine 2 di 2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s Fan Assembly Replacement, Fan Assembly: passo 4, immagine 1 di 2 Lenovo ThinkPad T480s Fan Assembly Replacement, Fan Assembly: passo 4, immagine 2 di 2
    • Use the spudger to disconnect the fan cable from the motherboard.
  5. Lenovo ThinkPad T480s Fan Assembly Replacement: passo 5, immagine 1 di 2 Lenovo ThinkPad T480s Fan Assembly Replacement: passo 5, immagine 2 di 2
    • Loosen the four captive screws attaching the fan assembly to the motherboard.
    • Do not attempt to remove the captive screws, as forcing them out may strip or damage them.
  6. Lenovo ThinkPad T480s Fan Assembly Replacement: passo 6, immagine 1 di 3 Lenovo ThinkPad T480s Fan Assembly Replacement: passo 6, immagine 2 di 3 Lenovo ThinkPad T480s Fan Assembly Replacement: passo 6, immagine 3 di 3
    • Lift the fan assembly from the system and remove it.
    • Follow our thermal paste application guide before you replace the fan assembly and are ready to reassemble your device.
Conclusione
Altre 4 persone hanno completato questa guida.
Sarah Westberg
Membro da: 03/11/19
34.893 Reputazione
71 Guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
23.623 Guide realizzate
2Commenti sulla guida
Danke. Perfekte Anweisung.
Hans R. Teterra - Replica
Thank you, @hansrteterra! I'm glad you found it helpful.
Sarah Westberg -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 32
Ultimi 30 Giorni: 130
Tutti i Tempi: 5,868
