Introduzione
Use this guide to replace the display panel on your Lenovo ThinkPad T470.
The display panel, also known as a screen, is the component that outputs visual information from a computer.
Some signs your display panel may be faulty include a blank or black screen, flickering, no backlight, or horizontal or vertical lines. A display panel replacement may be needed if it is cracked or physically damaged. Before attempting a display panel replacement, you may be able to resolve the issue using Lenovo’s troubleshooting guide.
Before replacing your display panel, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
Cosa ti serve
Place the laptop so that the bottom is facing upwards.
Slide the latch on the left side of the battery to the left until it clicks in place.
Use a Phillips #1 screwdriver to loosen the six captive screws on the bottom cover of the laptop.
Use your hands to pull up on the back cover and release the plastic clips starting on the bottom side of the battery compartment.
Use your hands to pull up on the right side of the bottom cover to release the plastic clips.
Use your hands to pull up on the left side of the bottom cover to release the plastic clips.
Use the flat end of a spudger to flip up the metal clip securing the LCD cable to the motherboard.
Use the iFixit opening tool to create a gap between the bezel and the display, starting in the upper left corner.
Continue to use the iFixit opening tool around the left side, bottom, and right side of the laptop to detach the clips securing the bezel to the display.
Use a Phillips #1 screwdriver to remove the four 3 mm screws from each corner of the screen.
2Commenti sulla guida
DO NOT WASTE YOUR TIME WITH THIS GUIDE. I am a certified repair technician and there is absolutely zero reason to disassemble the system and remove the motherboard for a panel swap. You can simply disconnect the antenna cables and EDP connectors; open the laptop and hang the LCD assembly over the edge of a table; then remove the hinge screws and lift it off. Nearly all ThinkPad models are like this. Please read the Hardware Maintenance Manual on the Lenovo support site for the correct way to do this. Page 93: https://download.lenovo.com/pccbbs/mobil...
Right, I was wondering why the nonsense that require me to remove all the mother board and things
