Salta al contenuto principale
Lenovo ThinkPad T470 Display Assembly Replacement
Cosa ti serve
  1. Lenovo ThinkPad T470 Display Assembly Replacement, External Battery: passo 1, immagine 1 di 3 Lenovo ThinkPad T470 Display Assembly Replacement, External Battery: passo 1, immagine 2 di 3 Lenovo ThinkPad T470 Display Assembly Replacement, External Battery: passo 1, immagine 3 di 3
    • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
    • Place the laptop so that the bottom is facing upwards.
    • Slide the latch on the left side of the battery to the left until it clicks in place.
  2. Lenovo ThinkPad T470 Display Assembly Replacement: passo 2, immagine 1 di 3 Lenovo ThinkPad T470 Display Assembly Replacement: passo 2, immagine 2 di 3 Lenovo ThinkPad T470 Display Assembly Replacement: passo 2, immagine 3 di 3
    • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
    • Use your other hand to slide the battery towards the back of the laptop.
    • Lift the battery up and away from the laptop.
  3. Lenovo ThinkPad T470 Display Assembly Replacement, Internal Components: passo 3, immagine 1 di 2 Lenovo ThinkPad T470 Display Assembly Replacement, Internal Components: passo 3, immagine 2 di 2
    • Use a Phillips #1 screwdriver to loosen the six captive screws on the bottom cover of the laptop.
  4. Lenovo ThinkPad T470 Display Assembly Replacement: passo 4, immagine 1 di 2 Lenovo ThinkPad T470 Display Assembly Replacement: passo 4, immagine 2 di 2
    • Place the laptop so that the top is facing upwards.
    • Open the lid of the laptop.
  5. Lenovo ThinkPad T470 Display Assembly Replacement: passo 5, immagine 1 di 2 Lenovo ThinkPad T470 Display Assembly Replacement: passo 5, immagine 2 di 2
    • Place your fingers on the bottom edge of the keyboard.
    • Use a small amount of pressure to push the keyboard towards the screen.
  6. Lenovo ThinkPad T470 Display Assembly Replacement: passo 6, immagine 1 di 3 Lenovo ThinkPad T470 Display Assembly Replacement: passo 6, immagine 2 di 3 Lenovo ThinkPad T470 Display Assembly Replacement: passo 6, immagine 3 di 3
    • Grab the bottom edge of the keyboard with your hands, and flip the keyboard upside-down, so it rests on the bottom of the laptop.
    • Potential for device damage: The keyboard is still attached to the rest of the laptop, so be gentle when flipping it over.
  7. Lenovo ThinkPad T470 Display Assembly Replacement: passo 7, immagine 1 di 2 Lenovo ThinkPad T470 Display Assembly Replacement: passo 7, immagine 2 di 2
    • Use the flat end of a spudger to flip up the locking flaps securing each of the two ribbon cables.
  8. Lenovo ThinkPad T470 Display Assembly Replacement: passo 8, immagine 1 di 2 Lenovo ThinkPad T470 Display Assembly Replacement: passo 8, immagine 2 di 2
    • Use your hands to lift the keyboard up and away from the laptop.
  9. Lenovo ThinkPad T470 Display Assembly Replacement: passo 9, immagine 1 di 1
    • Close the laptop's lid and flip the laptop over so that the bottom is facing upwards.
  10. Lenovo ThinkPad T470 Display Assembly Replacement: passo 10, immagine 1 di 3 Lenovo ThinkPad T470 Display Assembly Replacement: passo 10, immagine 2 di 3 Lenovo ThinkPad T470 Display Assembly Replacement: passo 10, immagine 3 di 3
    • Use your hands to pull up on the back cover and release the plastic clips starting on the bottom side of the battery compartment.
    • Potential for device damage: Be sure to detach the plastic clips in this area first. You risk cracking the bottom cover if you attempt to detach it from around the edges of the laptop first.
    • Use your hands to pull up on the right side of the bottom cover to release the plastic clips.
    • Use your hands to pull up on the left side of the bottom cover to release the plastic clips.
  11. Lenovo ThinkPad T470 Display Assembly Replacement: passo 11, immagine 1 di 1
    • Remove the bottom cover from the laptop.
  12. Lenovo ThinkPad T470 Display Assembly Replacement: passo 12, immagine 1 di 2 Lenovo ThinkPad T470 Display Assembly Replacement: passo 12, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove two 5 mm screws from the internal battery.
  13. Lenovo ThinkPad T470 Display Assembly Replacement: passo 13, immagine 1 di 3 Lenovo ThinkPad T470 Display Assembly Replacement: passo 13, immagine 2 di 3 Lenovo ThinkPad T470 Display Assembly Replacement: passo 13, immagine 3 di 3
    • Use your hands to lift the battery up and away from the laptop.
  14. Lenovo ThinkPad T470 Display Assembly Replacement: passo 14, immagine 1 di 2 Lenovo ThinkPad T470 Display Assembly Replacement: passo 14, immagine 2 di 2
    • Use your fingers to flip the black flap covering the top stick of RAM down.
  15. Lenovo ThinkPad T470 Display Assembly Replacement: passo 15, immagine 1 di 2 Lenovo ThinkPad T470 Display Assembly Replacement: passo 15, immagine 2 di 2
    • Use your thumbs to push the metal clips on either end of the RAM outwards.
    • The RAM will pop up by a few millimeters.
  16. Lenovo ThinkPad T470 Display Assembly Replacement: passo 16, immagine 1 di 2 Lenovo ThinkPad T470 Display Assembly Replacement: passo 16, immagine 2 di 2
    • Use your fingers to lift the RAM out of its socket and away from the laptop to remove it.
  17. Lenovo ThinkPad T470 Display Assembly Replacement: passo 17, immagine 1 di 3 Lenovo ThinkPad T470 Display Assembly Replacement: passo 17, immagine 2 di 3 Lenovo ThinkPad T470 Display Assembly Replacement: passo 17, immagine 3 di 3
    • Use your fingers to flip the black flap covering the bottom stick of RAM up.
  18. Lenovo ThinkPad T470 Display Assembly Replacement: passo 18, immagine 1 di 2 Lenovo ThinkPad T470 Display Assembly Replacement: passo 18, immagine 2 di 2
  19. Lenovo ThinkPad T470 Display Assembly Replacement: passo 19, immagine 1 di 2 Lenovo ThinkPad T470 Display Assembly Replacement: passo 19, immagine 2 di 2
    • Use the flat end of a spudger to flip up the metal clip securing the SSD connector to the motherboard.
  20. Lenovo ThinkPad T470 Display Assembly Replacement: passo 20, immagine 1 di 2 Lenovo ThinkPad T470 Display Assembly Replacement: passo 20, immagine 2 di 2
    • Use the flat end of a spudger to separate the connector from its socket.
  21. Lenovo ThinkPad T470 Display Assembly Replacement: passo 21, immagine 1 di 2 Lenovo ThinkPad T470 Display Assembly Replacement: passo 21, immagine 2 di 2
    • Grab the tab on the left side of the hard drive, and pull up to remove it from the laptop.
  22. Lenovo ThinkPad T470 Display Assembly Replacement: passo 22, immagine 1 di 2 Lenovo ThinkPad T470 Display Assembly Replacement: passo 22, immagine 2 di 2
    • Use a finger to press the black flap covering the Wi-Fi card down.
  23. Lenovo ThinkPad T470 Display Assembly Replacement: passo 23, immagine 1 di 3 Lenovo ThinkPad T470 Display Assembly Replacement: passo 23, immagine 2 di 3 Lenovo ThinkPad T470 Display Assembly Replacement: passo 23, immagine 3 di 3
    • Use the flat end of a spudger to disconnect the two coaxial wires from the Wi-Fi card.
    • When reassembling, reattach the gray wire on the left and the black wire on the right.
  24. Lenovo ThinkPad T470 Display Assembly Replacement: passo 24, immagine 1 di 2 Lenovo ThinkPad T470 Display Assembly Replacement: passo 24, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove the single 4 mm screw from the Wi-Fi card.
  25. Lenovo ThinkPad T470 Display Assembly Replacement: passo 25, immagine 1 di 3 Lenovo ThinkPad T470 Display Assembly Replacement: passo 25, immagine 2 di 3 Lenovo ThinkPad T470 Display Assembly Replacement: passo 25, immagine 3 di 3
    • Use your fingers to lift the Wi-Fi card up and out of its slot.
    • This laptop does not include a WWAN card, but if yours does, follow the same procedure as Steps 9-12 to remove it.
  26. Lenovo ThinkPad T470 Display Assembly Replacement: passo 26, immagine 1 di 2 Lenovo ThinkPad T470 Display Assembly Replacement: passo 26, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Use a pair of blunt nose tweezers to pull the white connector out of its socket.
  27. Lenovo ThinkPad T470 Display Assembly Replacement: passo 27, immagine 1 di 3 Lenovo ThinkPad T470 Display Assembly Replacement: passo 27, immagine 2 di 3 Lenovo ThinkPad T470 Display Assembly Replacement: passo 27, immagine 3 di 3
    • Grab the wire attached to the coin cell battery, and lift it up and out of the laptop.
  28. Lenovo ThinkPad T470 Display Assembly Replacement: passo 28, immagine 1 di 2 Lenovo ThinkPad T470 Display Assembly Replacement: passo 28, immagine 2 di 2
    • Use a pair of blunt nose tweezers to pull the white fan connector out of its socket on the motherboard.
  29. Lenovo ThinkPad T470 Display Assembly Replacement: passo 29, immagine 1 di 1
    • Use a Phillips #1 screwdriver to loosen the first pair of captive screws on the fan and heat sink assembly in a crosswise pattern.
    • Use a Phillips #1 screwdriver to loosen the second pair of captive screws on the fan and heat sink assembly in a crosswise pattern.
  30. Lenovo ThinkPad T470 Display Assembly Replacement: passo 30, immagine 1 di 2 Lenovo ThinkPad T470 Display Assembly Replacement: passo 30, immagine 2 di 2
    • Use your hand to pull the fan and heat sink assembly up and away from the laptop.
    • Clean the thermal paste from the heatsink and CPU and reapply fresh paste before reassembling.
  31. Lenovo ThinkPad T470 Display Assembly Replacement, Motherboard: passo 31, immagine 1 di 2 Lenovo ThinkPad T470 Display Assembly Replacement, Motherboard: passo 31, immagine 2 di 2
    • Use the flat end of a spudger to flip up the metal clip securing the LCD cable to the motherboard.
  32. Lenovo ThinkPad T470 Display Assembly Replacement: passo 32, immagine 1 di 2 Lenovo ThinkPad T470 Display Assembly Replacement: passo 32, immagine 2 di 2
    • Use the flat end of a spudger to disconnect the LCD cable from its socket on the motherboard.
  33. Lenovo ThinkPad T470 Display Assembly Replacement: passo 33, immagine 1 di 2 Lenovo ThinkPad T470 Display Assembly Replacement: passo 33, immagine 2 di 2
    • Use the flat end of a spudger to flip the power button cable's black tab up.
  34. Lenovo ThinkPad T470 Display Assembly Replacement: passo 34, immagine 1 di 2 Lenovo ThinkPad T470 Display Assembly Replacement: passo 34, immagine 2 di 2
    • Use the flat end of a spudger to slide the power button cable out of its connector on the motherboard.
  35. Lenovo ThinkPad T470 Display Assembly Replacement: passo 35, immagine 1 di 3 Lenovo ThinkPad T470 Display Assembly Replacement: passo 35, immagine 2 di 3 Lenovo ThinkPad T470 Display Assembly Replacement: passo 35, immagine 3 di 3
    • Use your fingers to detach the red and blue antenna cables from their slots.
  36. Lenovo ThinkPad T470 Display Assembly Replacement: passo 36, immagine 1 di 2 Lenovo ThinkPad T470 Display Assembly Replacement: passo 36, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove the two 4 mm screws from the USB bracket.
  37. Lenovo ThinkPad T470 Display Assembly Replacement: passo 37, immagine 1 di 3 Lenovo ThinkPad T470 Display Assembly Replacement: passo 37, immagine 2 di 3 Lenovo ThinkPad T470 Display Assembly Replacement: passo 37, immagine 3 di 3
    • Use your fingers to lift the USB bracket up and away from the laptop.
  38. Lenovo ThinkPad T470 Display Assembly Replacement: passo 38, immagine 1 di 2 Lenovo ThinkPad T470 Display Assembly Replacement: passo 38, immagine 2 di 2
    • Use a pair of blunt nose tweezers to disconnect the DC-in cable from its socket on the motherboard.
  39. Lenovo ThinkPad T470 Display Assembly Replacement: passo 39, immagine 1 di 2 Lenovo ThinkPad T470 Display Assembly Replacement: passo 39, immagine 2 di 2
    • Use the flat end of a spudger to flip up the metal bracket securing the camera cable to the motherboard.
  40. Lenovo ThinkPad T470 Display Assembly Replacement: passo 40, immagine 1 di 2 Lenovo ThinkPad T470 Display Assembly Replacement: passo 40, immagine 2 di 2
    • Use the flat end of a spudger to disconnect the camera cable from its socket on the motherboard.
  41. Lenovo ThinkPad T470 Display Assembly Replacement: passo 41, immagine 1 di 2 Lenovo ThinkPad T470 Display Assembly Replacement: passo 41, immagine 2 di 2
    • Use a pair of blunt nose tweezers to disconnect the speaker cable from its socket on the motherboard.
  42. Lenovo ThinkPad T470 Display Assembly Replacement: passo 42, immagine 1 di 2 Lenovo ThinkPad T470 Display Assembly Replacement: passo 42, immagine 2 di 2
    • Use the flat end of a spudger to flip up the black tabs on the trackpad and fingerprint reader cables.
  43. Lenovo ThinkPad T470 Display Assembly Replacement: passo 43, immagine 1 di 2 Lenovo ThinkPad T470 Display Assembly Replacement: passo 43, immagine 2 di 2
    • Use a pair of blunt nose tweezers to slide the trackpad and fingerprint reader cables out of their connectors on the motherboard.
  44. Lenovo ThinkPad T470 Display Assembly Replacement: passo 44, immagine 1 di 2 Lenovo ThinkPad T470 Display Assembly Replacement: passo 44, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove the three 4 mm screws from the I/O bracket.
  45. Lenovo ThinkPad T470 Display Assembly Replacement: passo 45, immagine 1 di 3 Lenovo ThinkPad T470 Display Assembly Replacement: passo 45, immagine 2 di 3 Lenovo ThinkPad T470 Display Assembly Replacement: passo 45, immagine 3 di 3
    • Use your fingers to slide the I/O bracket to the left.
    • Lift the I/O bracket up and away from the laptop.
  46. Lenovo ThinkPad T470 Display Assembly Replacement: passo 46, immagine 1 di 2 Lenovo ThinkPad T470 Display Assembly Replacement: passo 46, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove the six 4 mm screws from the motherboard.
    • This laptop does not have an NFC cable, but if yours does, use the flat end of a spudger to flip up the tab and slide the cable out of its connector.
  47. Lenovo ThinkPad T470 Display Assembly Replacement: passo 47, immagine 1 di 3 Lenovo ThinkPad T470 Display Assembly Replacement: passo 47, immagine 2 di 3 Lenovo ThinkPad T470 Display Assembly Replacement: passo 47, immagine 3 di 3
    • Use both hands to lift the motherboard up and away from the laptop.
  48. Lenovo ThinkPad T470 Display Assembly Replacement, Display Assembly: passo 48, immagine 1 di 2 Lenovo ThinkPad T470 Display Assembly Replacement, Display Assembly: passo 48, immagine 2 di 2
    • Use your fingers to remove the camera cable from its slot.
  49. Lenovo ThinkPad T470 Display Assembly Replacement: passo 49, immagine 1 di 3 Lenovo ThinkPad T470 Display Assembly Replacement: passo 49, immagine 2 di 3 Lenovo ThinkPad T470 Display Assembly Replacement: passo 49, immagine 3 di 3
    • Use your fingers to lift the black and blue wires out of their slots along the top of the laptop.
  50. Lenovo ThinkPad T470 Display Assembly Replacement: passo 50, immagine 1 di 2 Lenovo ThinkPad T470 Display Assembly Replacement: passo 50, immagine 2 di 2
    • Use your fingers to lift the red and gray wires out of their slots.
  51. Lenovo ThinkPad T470 Display Assembly Replacement: passo 51, immagine 1 di 2 Lenovo ThinkPad T470 Display Assembly Replacement: passo 51, immagine 2 di 2
    • Use your fingers to lift the LCD cable out of its slot.
  52. Lenovo ThinkPad T470 Display Assembly Replacement: passo 52, immagine 1 di 2 Lenovo ThinkPad T470 Display Assembly Replacement: passo 52, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove three 4.5 mm screws from the hinge in the upper right corner.
  53. Lenovo ThinkPad T470 Display Assembly Replacement: passo 53, immagine 1 di 2 Lenovo ThinkPad T470 Display Assembly Replacement: passo 53, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove two 4.5 mm screws from the hinge in the upper left corner.
  54. Lenovo ThinkPad T470 Display Assembly Replacement: passo 54, immagine 1 di 3 Lenovo ThinkPad T470 Display Assembly Replacement: passo 54, immagine 2 di 3 Lenovo ThinkPad T470 Display Assembly Replacement: passo 54, immagine 3 di 3
    • Use both hands to lift the laptop body up and away from the display assembly.
Conclusione
Kristen Gismondi
Membro da: 11/12/14
92.627 Reputazione
241 Guide realizzate
iFixit Membro di iFixit
Staff
118 Membri
19.647 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 33
Tutti i Tempi: 1,300
