Introduzione
If your laptop will not start up or stay charged you may need to replace the battery. It is not a difficult project and the hardest part will be prying the back piece off.
For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Shut down and unplug your device before beginning.
Cosa ti serve
Remove the thirteen 6.5 mm screws from the base plate using a Phillips #00 screwdriver.
Altre 16 persone hanno completato questa guida.
6Commenti sulla guida
I’ve damaged mine at step 4 and i don’t know how. Now the plug is loose and at the slightest touch, it goes into failure…I don’t now how to solve this, maybe replace the socket on the board by a new one. :(
Has anyone had issues with Legion Y520 laptop saying that the "battery isn't recognized" (with the x through it via the icon in the taskbar) after swapping the battery? I have tried three different ones that all do the same thing (one is even an OEM Lenovo Legion Y520 battery). I am thinking that either, the machine wants it to be an OEM one (not a third party one) and has some sort of check done after POST to verify if it is an official battery or not (and the one I have is just DOA?) or that there is an issue with the connector on the board itself?
