Salta al contenuto principale
Lenovo Ideapad Gaming 3 15ACH6 Lower Case Replacement
Cosa ti serve
  1. Lenovo Ideapad Gaming 3 15ACH6 Lower Case Replacement, Unfasten the lower case: passo 1, immagine 1 di 2 Lenovo Ideapad Gaming 3 15ACH6 Lower Case Replacement, Unfasten the lower case: passo 1, immagine 2 di 2
    • Use a Phillips screwdriver to remove the 10 screws securing the lower case:
    • Six 12 mm screws
    • Four 4.5 mm screws
  2. Lenovo Ideapad Gaming 3 15ACH6 Lower Case Replacement, Insert an opening pick: passo 2, immagine 1 di 2 Lenovo Ideapad Gaming 3 15ACH6 Lower Case Replacement, Insert an opening pick: passo 2, immagine 2 di 2
    • Insert an opening pick between the lower case and the chassis on the front right edge.
  3. Lenovo Ideapad Gaming 3 15ACH6 Lower Case Replacement, Release the clips: passo 3, immagine 1 di 3 Lenovo Ideapad Gaming 3 15ACH6 Lower Case Replacement, Release the clips: passo 3, immagine 2 di 3 Lenovo Ideapad Gaming 3 15ACH6 Lower Case Replacement, Release the clips: passo 3, immagine 3 di 3
    • Slide the pick along the front edge to release the clips securing the lower case.
    • Continue sliding the opening pick along the left and right edges to release the remaining clips.
  4. Lenovo Ideapad Gaming 3 15ACH6 Lower Case Replacement, Remove the lower case: passo 4, immagine 1 di 3 Lenovo Ideapad Gaming 3 15ACH6 Lower Case Replacement, Remove the lower case: passo 4, immagine 2 di 3 Lenovo Ideapad Gaming 3 15ACH6 Lower Case Replacement, Remove the lower case: passo 4, immagine 3 di 3
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
    May be important to note that the power button is in the middle top of the keyboard and thus it would be safest to open the lid sideways with the lid partly open on a clean surface as to not drop or touch the pcb/mother board with the work surface.
    The Muse - Replica
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo IdeaPad answers community for help.
Altre 4 persone hanno completato questa guida.
Spencer Day
Membro da: 09/14/22
95.833 Reputazione
662 Guide realizzate
iFixit Membro di iFixit
Staff
118 Membri
19.632 Guide realizzate
1Commento della guida
Could you disassemble the whole display assembly I've discovered the possibility of display cable damage and a more detailed guide would be greatly appreciated. Lenovo has an "explosion" schematic for this device but lacks valuable details.
The Muse - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 48
Ultimi 30 Giorni: 241
Tutti i Tempi: 6,254
