Salta al contenuto principale
Lenovo IdeaPad S145-14IWL Battery Replacement
Cosa ti serve
  1. Lenovo IdeaPad S145-14IWL Battery Replacement, Lower Case: passo 1, immagine 1 di 3 Lenovo IdeaPad S145-14IWL Battery Replacement, Lower Case: passo 1, immagine 2 di 3 Lenovo IdeaPad S145-14IWL Battery Replacement, Lower Case: passo 1, immagine 3 di 3
    • Use a Phillips #0 screwdriver to remove the ten screws that secure the lower case.
    • Insert an opening tool into the gap between the lower case and chassis.
    • Pry around the perimeter of the device until the lower case fully releases.
    • Remove the lower case.
  2. Lenovo IdeaPad S145-14IWL Battery Replacement, Lenovo IdeaPad S145-14IWL Battery Disconnection: passo 2, immagine 1 di 1
    • Use angled tweezers to gently pull the battery connector directly out of its socket.
  3. Lenovo IdeaPad S145-14IWL Battery Replacement, Battery: passo 3, immagine 1 di 3 Lenovo IdeaPad S145-14IWL Battery Replacement, Battery: passo 3, immagine 2 di 3 Lenovo IdeaPad S145-14IWL Battery Replacement, Battery: passo 3, immagine 3 di 3
    • Use a Phillips #0 screwdriver to remove the screws securing the battery.
    • Lift the battery up and out of the chassis.
Conclusione
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting.
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 21
Tutti i Tempi: 119
