Salta al contenuto principale
LeapFrog LeapPad2 Explorer Front Camera Replacement
Cosa ti serve
  1. LeapFrog LeapPad2 Explorer Front Camera Replacement, Battery: passo 1, immagine 1 di 2 LeapFrog LeapPad2 Explorer Front Camera Replacement, Battery: passo 1, immagine 2 di 2
    • Before disassembling your LeapPad, ensure your device is shut off.
    • Push outward on the plastic side panels to remove and reveal battery.
    • The panels should detach fully from the main device.
    Chiedi a FixBot
    Aggiungi Commento
  2. LeapFrog LeapPad2 Explorer Front Camera Replacement: passo 2, immagine 1 di 3 LeapFrog LeapPad2 Explorer Front Camera Replacement: passo 2, immagine 2 di 3 LeapFrog LeapPad2 Explorer Front Camera Replacement: passo 2, immagine 3 di 3
    • Push down from the positive end of the battery towards the negative end to pry the battery up out of its dispenser.
    • Remove all four AA alkaline batteries from the device.
    Chiedi a FixBot
    Aggiungi Commento
  3. LeapFrog LeapPad2 Explorer Front Camera Replacement, Back Cover: passo 3, immagine 1 di 2 LeapFrog LeapPad2 Explorer Front Camera Replacement, Back Cover: passo 3, immagine 2 di 2
    • This step will void your device warranty.
    • Remove the following screws securing the back cover to the main device:
    • Two 10.0 mm Phillips screws
    • Four 4.0 mm Phillips screws
    • Three 3.0 mm Phillips screws
    Chiedi a FixBot
    Aggiungi Commento
  4. LeapFrog LeapPad2 Explorer Front Camera Replacement: passo 4, immagine 1 di 3 LeapFrog LeapPad2 Explorer Front Camera Replacement: passo 4, immagine 2 di 3 LeapFrog LeapPad2 Explorer Front Camera Replacement: passo 4, immagine 3 di 3
    • Insert a plastic opening tool into the seam between the front and rear covers to detach the back cover from the rest of the device.
    • Move the plastic opening tool around the perimeter of the LeapPad2.
    • Lift up and remove the rear case from the tablet.
    • A butter knife can help when prying the device.
    Chiedi a FixBot
    Aggiungi Commento
  5. LeapFrog LeapPad2 Explorer Front Camera Replacement, Front Cover: passo 5, immagine 1 di 2 LeapFrog LeapPad2 Explorer Front Camera Replacement, Front Cover: passo 5, immagine 2 di 2
    • Remove the following screws securing the front cover to the main device:
    • Three 6.0 mm Phillips screws
    • Three 7.0 mm Phillips screws
    • Three 7.0 mm Phillips screws (bulkier screw head than other 7.0 mm Phillips screws)
    • The white plastic component holding the speaker must be removed to reach the third 7.0 mm Phillips screw. Refer to Step 2.
    Chiedi a FixBot
    Aggiungi Commento
  6. LeapFrog LeapPad2 Explorer Front Camera Replacement: passo 6, immagine 1 di 2 LeapFrog LeapPad2 Explorer Front Camera Replacement: passo 6, immagine 2 di 2
    • Unscrew the white plastic piece to expose the third 7.0 mm Phillips screw mentioned.
    Chiedi a FixBot
    Aggiungi Commento
  7. LeapFrog LeapPad2 Explorer Front Camera Replacement: passo 7, immagine 1 di 2 LeapFrog LeapPad2 Explorer Front Camera Replacement: passo 7, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    • When unscrewing the game cartridge screws, you will find a loose black plastic component underneath the game cartridge.
    • Use tweezers to remove the piece.
    • In case the piece falls out unexpectedly, refer to this step to make sure you put this piece back in place during the reassembly of your device.
    Chiedi a FixBot
    Aggiungi Commento
  8. LeapFrog LeapPad2 Explorer Front Camera Replacement: passo 8, immagine 1 di 2 LeapFrog LeapPad2 Explorer Front Camera Replacement: passo 8, immagine 2 di 2
    • Desolder the through hole-components in power plugs on both sides of the device where the batteries were once connected.
    • Do not refer to the pictures in this step for correct soldering and de-soldering techniques. They are solely for illustration purposes.
    • For proper soldering and desoldering techniques reference Come saldare e dissaldare componenti elettrici.
    • Soldering requires the iron to be at hot temperatures and can cause burns. Wear safety glasses as needed.
    • Be extremely careful with the cables in this step as they could melt, burn, or break.
    Chiedi a FixBot
    Aggiungi Commento
  9. LeapFrog LeapPad2 Explorer Front Camera Replacement: passo 9, immagine 1 di 2 LeapFrog LeapPad2 Explorer Front Camera Replacement: passo 9, immagine 2 di 2
    • Pry the power cables from the device using your fingers or tweezers.
    • Now you should be able to lift up the front cover, leaving you with the motherboard and screen.
    Chiedi a FixBot
    Aggiungi Commento
  10. LeapFrog LeapPad2 Explorer Front Camera Replacement, Front Camera: passo 10, immagine 1 di 3 LeapFrog LeapPad2 Explorer Front Camera Replacement, Front Camera: passo 10, immagine 2 di 3 LeapFrog LeapPad2 Explorer Front Camera Replacement, Front Camera: passo 10, immagine 3 di 3
    • Lift the screen from the motherboard by pulling the board out from the three metal tabs.
    • Do not be too aggressive when separating the components, as the parts are still connected.
    Chiedi a FixBot
    Aggiungi Commento
  11. LeapFrog LeapPad2 Explorer Front Camera Replacement: passo 11, immagine 1 di 1
    • Separate the screen from the motherboard and lay the device's components flat open like a book.
    Chiedi a FixBot
    Aggiungi Commento
  12. LeapFrog LeapPad2 Explorer Front Camera Replacement: passo 12, immagine 1 di 2 LeapFrog LeapPad2 Explorer Front Camera Replacement: passo 12, immagine 2 di 2
    • Peel off tape covering the camera's connection ribbon to the circuit.
    Chiedi a FixBot
    Aggiungi Commento
  13. LeapFrog LeapPad2 Explorer Front Camera Replacement: passo 13, immagine 1 di 1
    • To safely remove the ribbon cable, you must first pull up the retaining flap.
    • Failing to do this step could result in damage to the cable and/or connector.
    Chiedi a FixBot
    Aggiungi Commento
  14. LeapFrog LeapPad2 Explorer Front Camera Replacement: passo 14, immagine 1 di 1
    • Gently pull outward, to remove the ribbon from the socket on the circuit board.
    • If the flap is up as shown in the picture, no force should be required to remove the ribbon cable.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Nupur Garg
Membro da: 04/12/14
867 Reputazione
7 guide realizzate
Cal Poly, Team 8-10, Regan Spring 2014 Membro di Cal Poly, Team 8-10, Regan Spring 2014
CPSU-REGAN-S14S8G10
4 Membri
16 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 18
Tutti i Tempi: 835
