Salta al contenuto principale
Lasko CD08200 Disassembly
Cosa ti serve
  1. Lasko CD08200 Disassembly, Lasko CD08200 Disassembly: passo 1, immagine 1 di 2 Lasko CD08200 Disassembly, Lasko CD08200 Disassembly: passo 1, immagine 2 di 2
    • Turn over the device and place it on its head.
    • Remove the four 14mm screws holding the bottom using a TR15 screwdriver.
  2. Lasko CD08200 Disassembly: passo 2, immagine 1 di 1
    • Remove both 14mm screws from the power cord casing using a Phillips #2 screwdriver.
    • Remove the power cord casing from the device case.
  3. Lasko CD08200 Disassembly: passo 3, immagine 1 di 3 Lasko CD08200 Disassembly: passo 3, immagine 2 di 3 Lasko CD08200 Disassembly: passo 3, immagine 3 di 3
    • Cut the sticker on the right side of the device using a Jimmy.
    • Unscrew the four 14mm screws with a Phillips #2 bit on the back of the device.
    • If your screwdriver cannot reach the screw, you can use the metal spudger.
    • Remove the back casing from the device.
  4. Lasko CD08200 Disassembly: passo 4, immagine 1 di 3 Lasko CD08200 Disassembly: passo 4, immagine 2 di 3 Lasko CD08200 Disassembly: passo 4, immagine 3 di 3
    • Remove the four 14mm screws housing the fan using the Phillips #2 screwdriver.
    • Remove the top of the fan housing with the fan attached and place it on the table.
Conclusione
Un commento
Very helpful - thanks!
After two years of service my CD08200 started shutting down after 10 minutes on high. It is well built so I figured I would take it apart and try to fix. Why the designer used both Phillips and Torx security fasteners is a mystery but iFixit told me how to disassemble. Blowing out the heating element released a 1/4” thick mat of burnt dust - yikes! Go that and the motor vacuumed out and all seems to be working.
sPh - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 23
Tutti i Tempi: 450
