Salta al contenuto principale
LG Refrigerator Ice Auger Motor Run Capacitor Replacement
Cosa ti serve
  1. LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Unplug your refrigerator: passo 1, immagine 1 di 1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Unfasten the control board cover: passo 2, immagine 1 di 1
    • Use a Phillips screwdriver to remove the screws securing the control board cover.
  3. LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Remove the control board cover: passo 3, immagine 1 di 3 LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Remove the control board cover: passo 3, immagine 2 di 3 LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Remove the control board cover: passo 3, immagine 3 di 3
    • Tilt the top edge of the cover toward you and lift it off.
  4. LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Disconnect the wiring harness: passo 4, immagine 1 di 3 LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Disconnect the wiring harness: passo 4, immagine 2 di 3 LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Disconnect the wiring harness: passo 4, immagine 3 di 3
    • Squeeze and pull the connectors to disconnect them:
    • Connectors from the control board
    • Connectors from the refrigerator
    • Some connectors can remain connected as the wires attached to them don't get in the way. There is no harm if they are disconnected. Remember to reconnect them if disconnected.
  5. LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Reposition the wiring harness: passo 5, immagine 1 di 2 LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Reposition the wiring harness: passo 5, immagine 2 di 2
    • Reposition the wiring harness away from the capacitor.
  6. LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Disconnect the capacitor: passo 6, immagine 1 di 3 LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Disconnect the capacitor: passo 6, immagine 2 di 3 LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Disconnect the capacitor: passo 6, immagine 3 di 3
    • Pull the two connectors straight off the capacitor to disconnect it.
    • Handle the capacitor carefully as it may still be charged, and can give a dangerous and painful electrical shock. Avoid touching the terminals with your fingers or hands.
    • Information on capacitor safety.
  7. LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Remove the capacitor: passo 7, immagine 1 di 2 LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Remove the capacitor: passo 7, immagine 2 di 2
    • Use a Phillips screwdriver to remove the screw securing the capacitor to the refrigerator.
    • Remove the capacitor.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
Membro da: 06/30/22
30.088 Reputazione
213 Guide realizzate
iFixit Membro di iFixit
Staff
136 Membri
17.430 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 19
Tutti i Tempi: 103
