Salta al contenuto principale
LG G5 Battery Replacement
Cosa ti serve
  1. LG G5 Battery Replacement, Battery: passo 1, immagine 1 di 3 LG G5 Battery Replacement, Battery: passo 1, immagine 2 di 3 LG G5 Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Power down the phone by holding the power button for several seconds.
    • While holding the battery release button, pull the bottom end of the phone out of the body.
    Chiedi a FixBot
    Aggiungi Commento
  2. LG G5 Battery Replacement: passo 2, immagine 1 di 2 LG G5 Battery Replacement: passo 2, immagine 2 di 2
    • Separate the battery from bottom half.
    • Insert the new battery in the same position and orientation as the old battery. Match up the arrows to be sure the orientation is correct.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 22 persone hanno completato questa guida.
Sam Goldheart
Membro da: 10/18/12
477.489 Reputazione
538 guide realizzate
4Commenti sulla guida
Success. Excellent guide, thank you.
Cheers,
Richard.
rmgs - Rispondi Condividi
Was machen wenn Akku Snap In ab ist?
Ra Ku - Rispondi Condividi
Hallo, was machen wenn Snap In vom Akku ab ist und Akku im Gehäuse fest sitzt?
Absolutely great instructions. The battery I got for replacement comes uncharged (probably new shipping laws) so you might put in “Battery needs to be calibrated by fulling charging new battery to 100% then letting battery COMPLETELY run down to 0% before returning to normal use and charging.”
Michael Aarons - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 25
Ultimi 30 giorni: 108
Tutti i Tempi: 17,600
