Introduzione
Use this guide to remove or to replace a worn-out battery in the LG G3 (B855).
If your battery is swollen, take appropriate precautions.
Cosa ti serve
Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
Pry the back cover up to separate its plastic clips.
Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
For optimal performance, calibrate your newly installed battery: Charge it to 100%, and keep charging it for at least two more hours. Then, use it until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Altre 21 persone hanno completato questa guida.
