Salta al contenuto principale
LG Front Load Washing Machine Rotor Replacement
Cosa ti serve
  1. LG Front Load Washing Machine Rotor Replacement, Safety Precautions: passo 1, immagine 1 di 2 LG Front Load Washing Machine Rotor Replacement, Safety Precautions: passo 1, immagine 2 di 2
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
    Chiedi a FixBot
    Aggiungi Commento
  2. LG Front Load Washing Machine Rotor Replacement, Unfasten the rear panel: passo 2, immagine 1 di 3 LG Front Load Washing Machine Rotor Replacement, Unfasten the rear panel: passo 2, immagine 2 di 3 LG Front Load Washing Machine Rotor Replacement, Unfasten the rear panel: passo 2, immagine 3 di 3
    • Remove the screw(s) securing the rear panel.
    Chiedi a FixBot
    Aggiungi Commento
  3. LG Front Load Washing Machine Rotor Replacement, Remove the rear panel: passo 3, immagine 1 di 3 LG Front Load Washing Machine Rotor Replacement, Remove the rear panel: passo 3, immagine 2 di 3 LG Front Load Washing Machine Rotor Replacement, Remove the rear panel: passo 3, immagine 3 di 3
    • Unclip the rear panel from the chassis.
    Chiedi a FixBot
    Aggiungi Commento
  4. LG Front Load Washing Machine Rotor Replacement: passo 4, immagine 1 di 1
    • Remove the rear panel.
    Chiedi a FixBot
    Aggiungi Commento
  5. LG Front Load Washing Machine Rotor Replacement, Unfasten the rotor: passo 5, immagine 1 di 2 LG Front Load Washing Machine Rotor Replacement, Unfasten the rotor: passo 5, immagine 2 di 2
    • Use an impact driver to remove the 17 mm nut securing the rotor.
    • Alternatively, you can use a wrench and a hammer to loosen the nut.
    • To secure the rotor, you can insert a screwdriver, or a similar tool, between the rotor and the stator. Make sure to brace the tool against one of the screw bosses on the stator.
    Chiedi a FixBot
    Aggiungi Commento
  6. LG Front Load Washing Machine Rotor Replacement, Remove the rotor: passo 6, immagine 1 di 2 LG Front Load Washing Machine Rotor Replacement, Remove the rotor: passo 6, immagine 2 di 2
    • The rotor is magnetically attracted to the stator.
    • Pull the rotor straight off the stator and drive shaft splines to remove it.
    • Wiggle the rotor as you pull to help disconnect it.
    • This may require significant force.
    • During reassembly, watch your fingers when aligning the rotor over the stator, as the rotor gets sucked in easily.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Repair didn’t go as planned? Ask our Answers community for help.
Altre 2 persone hanno completato questa guida.
Bill Gilbert
Membro da: 06/30/22
40.113 Reputazione
261 guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
27.603 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 20
Ultimi 30 giorni: 72
Tutti i Tempi: 2,272
