Salta al contenuto principale
LG Front Load Washing Machine Pump Assembly Replacement
Cosa ti serve
    1. LG Front Load Washing Machine Pump Assembly Replacement, Safety Precautions: passo 1, immagine 1 di 2 LG Front Load Washing Machine Pump Assembly Replacement, Safety Precautions: passo 1, immagine 2 di 2
      • Before you begin your repair, perform the following:
      • Turn off the main water supply
      • Unplug your washer
      • Disconnect all water connections at the rear of your washer
      Chiedi a FixBot
      Aggiungi Commento
    1. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the top panel: passo 2, immagine 1 di 3 LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the top panel: passo 2, immagine 2 di 3 LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the top panel: passo 2, immagine 3 di 3
      • Remove the screw(s) securing the top panel brackets to the back panel.
      • You don't need to remove the screws securing the brackets to the top panel.
      Chiedi a FixBot
      Aggiungi Commento
    2. LG Front Load Washing Machine Pump Assembly Replacement, Remove the top panel: passo 3, immagine 1 di 2 LG Front Load Washing Machine Pump Assembly Replacement, Remove the top panel: passo 3, immagine 2 di 2
      • Slide the top panel towards the rear of the device to disconnect its clips.
      Chiedi a FixBot
      Aggiungi Commento
    3. LG Front Load Washing Machine Pump Assembly Replacement: passo 4, immagine 1 di 2 LG Front Load Washing Machine Pump Assembly Replacement: passo 4, immagine 2 di 2
      • Tilt the top panel upward to completely disconnect it from the chassis.
      • Remove the top panel.
      Chiedi a FixBot
      Aggiungi Commento
    1. LG Front Load Washing Machine Pump Assembly Replacement, Remove the detergent drawer: passo 5, immagine 1 di 2 LG Front Load Washing Machine Pump Assembly Replacement, Remove the detergent drawer: passo 5, immagine 2 di 2
      • Pull the detergent drawer away from the chassis as far as it will go.
      Chiedi a FixBot
      Aggiungi Commento
    2. LG Front Load Washing Machine Pump Assembly Replacement: passo 6, immagine 1 di 3 LG Front Load Washing Machine Pump Assembly Replacement: passo 6, immagine 2 di 3 LG Front Load Washing Machine Pump Assembly Replacement: passo 6, immagine 3 di 3
      • Press down on the "Push" button to disengage the clips securing the detergent drawer.
      • Pull the drawer out of its slot on the chassis and remove it.
      Chiedi a FixBot
      Aggiungi Commento
    1. LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the control panel: passo 7, immagine 1 di 3 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the control panel: passo 7, immagine 2 di 3 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the control panel: passo 7, immagine 3 di 3
      • Disconnect the connectors attached to the control panel.
      • Always grip cables by their connectors and not the wires themselves.
      Chiedi a FixBot
      Aggiungi Commento
    2. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the control panel: passo 8, immagine 1 di 2 LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the control panel: passo 8, immagine 2 di 2
      • Remove the screw(s) securing the control panel to the top edge of the chassis.
      Chiedi a FixBot
      Aggiungi Commento
    3. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the detergent dispenser: passo 9, immagine 1 di 1
      • Remove the screw(s) securing the detergent dispenser.
      Chiedi a FixBot
      Aggiungi Commento
    4. LG Front Load Washing Machine Pump Assembly Replacement, Unclip the control panel: passo 10, immagine 1 di 3 LG Front Load Washing Machine Pump Assembly Replacement, Unclip the control panel: passo 10, immagine 2 di 3 LG Front Load Washing Machine Pump Assembly Replacement, Unclip the control panel: passo 10, immagine 3 di 3
      • Use a flathead screwdriver, or a pry tool, to unclip the control panel from the chassis.
      Chiedi a FixBot
      Aggiungi Commento
    5. LG Front Load Washing Machine Pump Assembly Replacement, Remove the control panel: passo 11, immagine 1 di 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the control panel: passo 11, immagine 2 di 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the control panel: passo 11, immagine 3 di 3
      • Remove the control panel, making sure to thread any cables through the chassis.
      Chiedi a FixBot
      Aggiungi Commento
    1. LG Front Load Washing Machine Pump Assembly Replacement, Open the door: passo 12, immagine 1 di 2 LG Front Load Washing Machine Pump Assembly Replacement, Open the door: passo 12, immagine 2 di 2
      • Open the front door completely.
      Chiedi a FixBot
      Aggiungi Commento
    2. LG Front Load Washing Machine Pump Assembly Replacement, Remove the boot ring: passo 13, immagine 1 di 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the boot ring: passo 13, immagine 2 di 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the boot ring: passo 13, immagine 3 di 3
      • Use needle nose pliers to grip the spring end of the metal ring at the bottom of the rubber boot.
      • Pull the ring away from the chassis to separate it from the boot.
      Chiedi a FixBot
      Aggiungi Commento
    3. LG Front Load Washing Machine Pump Assembly Replacement: passo 14, immagine 1 di 3 LG Front Load Washing Machine Pump Assembly Replacement: passo 14, immagine 2 di 3 LG Front Load Washing Machine Pump Assembly Replacement: passo 14, immagine 3 di 3
      • Use your hand to completely pull the ring off the boot.
      • During reassembly, perform the following:
      • Insert one end of the ring into its groove along the boot's perimeter.
      • Use pliers to slowly stretch the ring around the boot's perimeter until it's completely nested in its groove.
      • Be sure the spring is centered at the bottom of the boot when you reinstall it.
      • This procedure will take significant force.
      Chiedi a FixBot
      Aggiungi Commento
    4. LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the boot: passo 15, immagine 1 di 3 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the boot: passo 15, immagine 2 di 3 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the boot: passo 15, immagine 3 di 3
      • Use your fingers to pull the boot off its lip on the front panel.
      Chiedi a FixBot
      Aggiungi Commento
    5. LG Front Load Washing Machine Pump Assembly Replacement: passo 16, immagine 1 di 3 LG Front Load Washing Machine Pump Assembly Replacement: passo 16, immagine 2 di 3 LG Front Load Washing Machine Pump Assembly Replacement: passo 16, immagine 3 di 3
      • Slide your fingers around the lip of the boot until it's completely separated from the panel.
      Chiedi a FixBot
      Aggiungi Commento
    6. LG Front Load Washing Machine Pump Assembly Replacement, Remove the filter panel: passo 17, immagine 1 di 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the filter panel: passo 17, immagine 2 di 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the filter panel: passo 17, immagine 3 di 3
      • Open the filter panel at the bottom of the front panel.
      • Unclip the filter panel.
      Chiedi a FixBot
      Aggiungi Commento
    7. LG Front Load Washing Machine Pump Assembly Replacement, Drain the machine: passo 18, immagine 1 di 3 LG Front Load Washing Machine Pump Assembly Replacement, Drain the machine: passo 18, immagine 2 di 3 LG Front Load Washing Machine Pump Assembly Replacement, Drain the machine: passo 18, immagine 3 di 3
      • Generally, you should drain your machine when you are repairing the pumps or any hoses leading to or from them.
      • Place a bowl next to the machine.
      • Pull the drain filter hose out of its slot in the chassis enough to lay over the bowl.
      • Remove the plug at the end of the drain filter hose to release excess water into the bowl.
      • During reassembly, re-plug the drain filter hose and thread it back through its slot in the chassis.
      Chiedi a FixBot
      Aggiungi Commento
    8. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the filter trim: passo 19, immagine 1 di 1
      • Remove the screw(s) securing the filter trim.
      Chiedi a FixBot
      Aggiungi Commento
    9. LG Front Load Washing Machine Pump Assembly Replacement, Remove the filter trim: passo 20, immagine 1 di 2 LG Front Load Washing Machine Pump Assembly Replacement, Remove the filter trim: passo 20, immagine 2 di 2
      • Pull the filter trim straight off the front panel to remove it.
      Chiedi a FixBot
      Aggiungi Commento
    10. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the lower front panel: passo 21, immagine 1 di 1
      • Remove the screw(s) securing the lower front panel.
      Chiedi a FixBot
      Aggiungi Commento
    11. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the door latch: passo 22, immagine 1 di 1
      • Remove the screw(s) securing the door latch.
      Chiedi a FixBot
      Aggiungi Commento
    12. LG Front Load Washing Machine Pump Assembly Replacement, Remove the door latch: passo 23, immagine 1 di 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the door latch: passo 23, immagine 2 di 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the door latch: passo 23, immagine 3 di 3
      • Pull the door latch through its slot in the chassis and let it hang on its wire.
      Chiedi a FixBot
      Aggiungi Commento
    13. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the front panel: passo 24, immagine 1 di 3 LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the front panel: passo 24, immagine 2 di 3 LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the front panel: passo 24, immagine 3 di 3
      • Hold the front panel against the chassis while performing this step to prevent it from falling.
      • Remove the screw(s) securing the front panel.
      Chiedi a FixBot
      Aggiungi Commento
    14. LG Front Load Washing Machine Pump Assembly Replacement, Remove the front panel: passo 25, immagine 1 di 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the front panel: passo 25, immagine 2 di 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the front panel: passo 25, immagine 3 di 3
      • Lift the front panel upward to separate it from its clips on the bottom of the chassis.
      • Pull the front panel away from the chassis to completely separate the front panel.
      Chiedi a FixBot
      Aggiungi Commento
    15. LG Front Load Washing Machine Pump Assembly Replacement: passo 26, immagine 1 di 1
      • Remove the front panel.
      Chiedi a FixBot
      Aggiungi Commento
    1. LG Front Load Washing Machine Pump Assembly Replacement, Remove the pump filter: passo 27, immagine 1 di 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the pump filter: passo 27, immagine 2 di 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the pump filter: passo 27, immagine 3 di 3
      • Twist and remove the pump filter.
      Chiedi a FixBot
      Aggiungi Commento
    2. LG Front Load Washing Machine Pump Assembly Replacement, Reposition the drain hose: passo 28, immagine 1 di 3 LG Front Load Washing Machine Pump Assembly Replacement, Reposition the drain hose: passo 28, immagine 2 di 3 LG Front Load Washing Machine Pump Assembly Replacement, Reposition the drain hose: passo 28, immagine 3 di 3
      • Push the drain hose through its hole in the chassis until it's completely inside the device.
      Chiedi a FixBot
      Aggiungi Commento
    3. LG Front Load Washing Machine Pump Assembly Replacement, Unwrap the pump assembly cables: passo 29, immagine 1 di 3 LG Front Load Washing Machine Pump Assembly Replacement, Unwrap the pump assembly cables: passo 29, immagine 2 di 3 LG Front Load Washing Machine Pump Assembly Replacement, Unwrap the pump assembly cables: passo 29, immagine 3 di 3
      • Use diagonal cutters, or scissors, to remove any cable ties securing the plastic wrap on the pump assembly cable connector(s).
      Chiedi a FixBot
      Aggiungi Commento
    4. LG Front Load Washing Machine Pump Assembly Replacement: passo 30, immagine 1 di 2 LG Front Load Washing Machine Pump Assembly Replacement: passo 30, immagine 2 di 2
      • Fold the plastic wrap away from the cables, enough to expose the connector(s).
      • During reassembly, replace the cable ties to ensure a water-tight fit for the plastic wrap.
      Chiedi a FixBot
      Aggiungi Commento
    5. LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the pump cable: passo 31, immagine 1 di 2 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the pump cable: passo 31, immagine 2 di 2
      • Disconnect the connector(s) attached to the pump cable.
      Chiedi a FixBot
      Aggiungi Commento
    6. LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the drain hose: passo 32, immagine 1 di 3 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the drain hose: passo 32, immagine 2 di 3 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the drain hose: passo 32, immagine 3 di 3
      • Use slip joint pliers to pinch the drain hose clamp and slide it up the hose away from the pump assembly.
      Chiedi a FixBot
      Aggiungi Commento
    7. LG Front Load Washing Machine Pump Assembly Replacement: passo 33, immagine 1 di 3 LG Front Load Washing Machine Pump Assembly Replacement: passo 33, immagine 2 di 3 LG Front Load Washing Machine Pump Assembly Replacement: passo 33, immagine 3 di 3
      • Use slip joint pliers to rotate the drain hose back and forth around its connection and loosen it.
      • Pull the drain hose straight off its connection on the assembly.
      Chiedi a FixBot
      Aggiungi Commento
    8. LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the pump hose: passo 34, immagine 1 di 3 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the pump hose: passo 34, immagine 2 di 3 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the pump hose: passo 34, immagine 3 di 3
      • Repeat the last two steps for the pump hose.
      Chiedi a FixBot
      Aggiungi Commento
    9. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the pump assembly: passo 35, immagine 1 di 2 LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the pump assembly: passo 35, immagine 2 di 2
      • Remove the screw(s) securing the pump assembly to the bottom lip of the washer.
      Chiedi a FixBot
      Aggiungi Commento
    10. LG Front Load Washing Machine Pump Assembly Replacement, Remove the pump assembly: passo 36, immagine 1 di 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the pump assembly: passo 36, immagine 2 di 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the pump assembly: passo 36, immagine 3 di 3
      • Lift the pump assembly out of its location in the frame to remove it.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Repair didn’t go as planned? Ask our Answers community for help.
Altre 4 persone hanno completato questa guida.
Bill Gilbert
Membro da: 06/30/22
40.168 Reputazione
261 guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
41.948 guide realizzate
2Commenti sulla guida
Hi Bill, Fantastic instructions - thanks for taking the time to put these together!
Ken Adams - Rispondi Condividi
Wow, that's intense. I wonder if I can just prop it up and get to that pump from the bottom? I don't have a jack stand or anything but I saw someone lean it back into a metal step stool.
Doyle Stadt - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 11
Ultimi 7 giorni: 65
Ultimi 30 giorni: 220
Tutti i Tempi: 5,209
