Salta al contenuto principale
LG CF360 LCD Screen Replacement
Cosa ti serve
  1. LG CF360 LCD Screen Replacement, Battery: passo 1, immagine 1 di 2 LG CF360 LCD Screen Replacement, Battery: passo 1, immagine 2 di 2
    • On the back of the phone, place your thumb on the three raised bumps and slide the back cover upward.
    Chiedi a FixBot
    Aggiungi Commento
  2. LG CF360 LCD Screen Replacement: passo 2, immagine 1 di 1
    • Lift and remove the battery.
    Chiedi a FixBot
    Aggiungi Commento
  3. LG CF360 LCD Screen Replacement, Back Cover: passo 3, immagine 1 di 2 LG CF360 LCD Screen Replacement, Back Cover: passo 3, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    • Remove the two screw covers at the top of phone with tweezers.
    Chiedi a FixBot
    Aggiungi Commento
  4. LG CF360 LCD Screen Replacement: passo 4, immagine 1 di 1
    • Remove the six Phillips #000 (3mm) screws.
    Chiedi a FixBot
    Aggiungi Commento
  5. LG CF360 LCD Screen Replacement: passo 5, immagine 1 di 3 LG CF360 LCD Screen Replacement: passo 5, immagine 2 di 3 LG CF360 LCD Screen Replacement: passo 5, immagine 3 di 3
    • Use the plastic opening tool to pry the back cover off. Insert the tool between the back cover and red mid section and go around the entire phone.
    • The plastic side buttons fall out when you take the back cover off.
    • The back cover is connected to the speaker by red and black wires.
    Chiedi a FixBot
    Aggiungi Commento
  6. LG CF360 LCD Screen Replacement: passo 6, immagine 1 di 1
    • Use the tweezers to remove the red and black wires connecting the speaker to the green motherboard by pinching the sides of the plastic base near the motherboard.
    • Set the back cover with the speaker aside.
    Chiedi a FixBot
    Aggiungi Commento
  7. LG CF360 LCD Screen Replacement, Motherboard: passo 7, immagine 1 di 2 LG CF360 LCD Screen Replacement, Motherboard: passo 7, immagine 2 di 2
    • Use the plastic opening tool to gently lift the snapped-in motherboard from the front panel.
    • An orange ribbon from the LCD is connected to the underside of the motherboard, so do not force the motherboard from the rest of the phone yet.
    Chiedi a FixBot
    Aggiungi Commento
  8. LG CF360 LCD Screen Replacement: passo 8, immagine 1 di 1
    • Gently remove the blue transparent tape from the connector.
    Chiedi a FixBot
    Aggiungi Commento
  9. LG CF360 LCD Screen Replacement: passo 9, immagine 1 di 1
    • With the plastic opening tool, gently pry the LCD connector from the motherboard.
    • Set the motherboard aside.
    Chiedi a FixBot
    Aggiungi Commento
  10. LG CF360 LCD Screen Replacement, Front Case: passo 10, immagine 1 di 1
    • Take the front case and unscrew the four Phillips #000 (1mm) screws around the ribbon.
    Chiedi a FixBot
    Aggiungi Commento
  11. LG CF360 LCD Screen Replacement: passo 11, immagine 1 di 1
    • Gently pull the orange ribbon from the number pad casing.
    • Set the number pad case to the side once it is detached from the ribbon.
    Chiedi a FixBot
    Aggiungi Commento
  12. LG CF360 LCD Screen Replacement: passo 12, immagine 1 di 1
    • Remove the two red sticker screw coverings at the top corners with tweezers.
    Chiedi a FixBot
    Aggiungi Commento
  13. LG CF360 LCD Screen Replacement: passo 13, immagine 1 di 1
    • Unscrew the four Phillips #000 (3mm) screws at the corners of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  14. LG CF360 LCD Screen Replacement: passo 14, immagine 1 di 2 LG CF360 LCD Screen Replacement: passo 14, immagine 2 di 2
    • Pry the red sliding backing from the front cover by inserting the plastic opening tool in between the two sections and going around the entire phone.
    • Set the red sliding backing and front cover to the side.
    Chiedi a FixBot
    Aggiungi Commento
  15. LG CF360 LCD Screen Replacement, LCD Screen: passo 15, immagine 1 di 1
    • Be very careful to not damage the green keypad board when using the plastic opening tool.
    • Use a plastic opening tool to carefully disconnect the silver L-shaped LCD screen ribbon.
    Chiedi a FixBot
    Aggiungi Commento
  16. LG CF360 LCD Screen Replacement: passo 16, immagine 1 di 2 LG CF360 LCD Screen Replacement: passo 16, immagine 2 di 2
    • At this point, an orange ribbon is still connected to the white and black Zero Insertion Force (ZIF) connector on the keypad board. Be careful to not damage the ribbon.
    • Use tweezers to carefully pry up the black retainer on the connector.
    Chiedi a FixBot
    Aggiungi Commento
  17. LG CF360 LCD Screen Replacement: passo 17, immagine 1 di 2 LG CF360 LCD Screen Replacement: passo 17, immagine 2 di 2
    • Lift the keypad board away from the phone casing using a plastic opening tool.
    • Slowly rotate the keypad board towards you to disconnect the second orange LCD screen ribbon and remove the board.
    Chiedi a FixBot
    Aggiungi Commento
  18. LG CF360 LCD Screen Replacement: passo 18, immagine 1 di 1
    • If you have never soldered before, or need a refresher, take a look at iFixit's soldering guide before starting this step.
    • Use a soldering iron and a solder wick to de-solder the 4 wires connected to the LCD screen.
    • The LCD screen can easily be removed at this point by lifting it from the phone casing.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Ricky Wai
Membro da: 10/15/13
299 Reputazione
2 guide realizzate
Cal Poly, Team 4-27, Amido Fall 2013 Membro di Cal Poly, Team 4-27, Amido Fall 2013
CPSU-AMIDO-F13S4G27
4 Membri
19 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 2
Ultimi 30 giorni: 23
Tutti i Tempi: 1,611
