Salta al contenuto principale
Instant Pot IP-DUO80 V2 LED Display Replacement
Cosa ti serve
  1. Instant Pot IP-DUO80 V2 LED Display Replacement, LED Display: passo 1, immagine 1 di 3 Instant Pot IP-DUO80 V2 LED Display Replacement, LED Display: passo 1, immagine 2 di 3 Instant Pot IP-DUO80 V2 LED Display Replacement, LED Display: passo 1, immagine 3 di 3
    • Open the lid by turning it counter-clockwise and lifting up.
    • Remove the inner pot.
  2. Instant Pot IP-DUO80 V2 LED Display Replacement: passo 2, immagine 1 di 3 Instant Pot IP-DUO80 V2 LED Display Replacement: passo 2, immagine 2 di 3 Instant Pot IP-DUO80 V2 LED Display Replacement: passo 2, immagine 3 di 3
    • Turn the Instant Pot upside down.
    • Remove the single 12-mm screw by using the T-15 head screwdriver and turning it counter-clockwise.
    • Turn the plate counter-clockwise and lift it off the Instant Pot.
  3. Instant Pot IP-DUO80 V2 LED Display Replacement: passo 3, immagine 1 di 2 Instant Pot IP-DUO80 V2 LED Display Replacement: passo 3, immagine 2 di 2
    • Remove the three 19-mm screws in the black plastic base's edge using the PH-1 head screwdriver and twisting counter-clockwise.
  4. Instant Pot IP-DUO80 V2 LED Display Replacement: passo 4, immagine 1 di 2 Instant Pot IP-DUO80 V2 LED Display Replacement: passo 4, immagine 2 di 2
    • Pull the power cord out of its slot.
    • Pull up on the edge of the black plastic base to remove the base.
    Tengo una olla Instant por necesito repararla está con golpe
    sonialrodriguezv - Replica
  5. Instant Pot IP-DUO80 V2 LED Display Replacement: passo 5, immagine 1 di 3 Instant Pot IP-DUO80 V2 LED Display Replacement: passo 5, immagine 2 di 3 Instant Pot IP-DUO80 V2 LED Display Replacement: passo 5, immagine 3 di 3
    • Disconnect the two green-striped yellow wires that are connected onto the bottom of the heating element. Use a PH-1 head screwdriver and turn counter-clockwise to remove the 10-mm screw holding them in place.
    • Be careful not to lose the small washer that comes with this screw.
    • Pull up on the cn101 connection to detach the LED display from the motherboard.
  6. Instant Pot IP-DUO80 V2 LED Display Replacement: passo 6, immagine 1 di 1
    • Lift the silver outer shell off of the top black ring.
  7. Instant Pot IP-DUO80 V2 LED Display Replacement: passo 7, immagine 1 di 3 Instant Pot IP-DUO80 V2 LED Display Replacement: passo 7, immagine 2 di 3 Instant Pot IP-DUO80 V2 LED Display Replacement: passo 7, immagine 3 di 3
    • Remove the two 10-mm screws connecting the LED display to the outer shell using a PH-1 head screwdriver and twisting counter clockwise.
    • Pull out the LED display by pulling on it gently.
    You say no parts? But I don’t see how you rectified the issue just by removing the LED display. Do you need a replacement LED display?
    bryonkarren - Replica
    Okay..took instant pot apart as shown..do I need to buy a new led display..if so, where? Or do I just reinstall the old one?
    g locke - Replica
Conclusione
Altre 6 persone hanno completato questa guida.
Cal Poly, Team S18-G2, Livingston Winter 2018 Membro di Cal Poly, Team S18-G2, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G2
4 Membri
10 Guide realizzate
2 Commenti
Where can I get the replacement for the display?
Starfish Doodle - Replica
Hola disculpa, donde puedo conseguir la pantalla led de mi instat pot DUO PLUS MULTI-COOKER 9in 1
Evaristo - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 39
Tutti i Tempi: 6,730
