Introduzione
Is your Cuisinart coffee maker producing cold coffee because the heating element contacts are disconnected? If so, this guide will provide instructions on how to reconnect contacts to the heating element. To complete this task, you'll need a soldering iron, soldering wire and a T10 driver bit.
Cosa ti serve
Flip the coffee maker over so the bottom is facing upwards.
Use the T10 Torx screwdriver to remove all four 17 mm-long screws.
Lift the bottom cover off the bottom of the coffee maker.
Strumento utilizzato in questo passaggio:FixHub Smart Soldering Iron$79.95
If heating element contacts are disconnected, use soldering iron with soldering wire to re-bond the contacts.
1Commento della guida
Cuisinart Drip Coffee Maker:
Model CBC-6500PCC
In use:
Less than one year.
Problem:
Not heating
Cause:
Blown thermal fuse (240C) connected in series with one side of heating element (there are two, each one connected in series and attached directly to each side of the heating element.) Not replaceable by itself.
Remedy:
Replacement under warranty or purchase a used one at Goodwill, Salvation Army, Value Village, local online personal seller, etc.
